> Greetings,
> At the moment I am running my copy of Mercury on my Desktop
> while I build a dedicated server. My desktop has Symantec
> SystemWorks 2005 with Norton AntiVirus 2006 updated over the
> top. I have had a couple people suggest that the Symantec
> products are the causes of some of my problems, yet I have
> been fortunate and never really had any problems with
> Symantec/Norton products. My personal experience with McAfee
> is not that good, though...
First of all if you run the Norton software keep it away from anything important on your system. Do not let it access any directory that is used by Mercury or Pegasus Mail. Getting Norton off you system is a real challenge and so I'd just leave it alone until you have a lot of time available.
> So if I were to change AntiVirus products, what have other
> Mercury Admins had good luck with?
ClamAV with ClamWall works well.
> Are there any other products, that as a Mercury Admin you
> would recommend putting into the equation for a secure and
> stable Email System?
ClamWall, Greywall and Spamwall for starters. I personally use POPFileD with POPFile instead of SpamWall but that's my personal preference based on the spam I get. Both work at the 99% level of effectiveness with a FPR under 0.05%. All these will be available when v4.51 comes out (real soon now). The reason I like these is that both are designed to work as daemons with Mercury/32 rather than external system that may or many not be that compatible.
Tom, thanx for the input. As I said, in the past, Symantec has never given me any troubles and I am certainly not convinced that it is the culprit here, either. I know some packages mess with your system based more on the types of programs installed. I am not a gamer, mostly all business and development software as I am a database programmer. Maybe that is why I have never had any issues with it. That aside... where are the products you referenced available?
ClamWall, GreyWall, SpamWall, PopFileD, etc. AND will these work with Mercury/32 v4.01b/c OR would I have to wait for v4.5 to use them?
I am waiting for v4.5 and pricing to determine which way to go... I hope "real soon now" is RSN so I can make the final decision and get on with it ! ! !
Regards,
Keith
<P>[quote user="Thomas R. Stephenson"]
&gt; Greetings,
&gt;
&gt; At the moment I am running my copy of Mercury on my Desktop
&gt; while I build a dedicated server.&nbsp; My desktop has Symantec
&gt; SystemWorks 2005 with Norton AntiVirus 2006 updated over the
&gt; top.&nbsp; I have had a couple people suggest that the Symantec
&gt; products are the causes of some of my problems, yet I have
&gt; been fortunate and never really had any problems with
&gt; Symantec/Norton products.&nbsp; My personal experience with McAfee
&gt; is not that good, though...
First of all if you run the Norton software keep it away from anything important on your system.&nbsp; Do not let it access any directory that is used by Mercury or Pegasus Mail.&nbsp;&nbsp; Getting Norton off you system is a real challenge and so I'd just leave it alone until you have a lot of time available.
&gt; So if I were to change AntiVirus products, what have other
&gt; Mercury Admins had good luck with?
ClamAV with ClamWall works well.&nbsp;&nbsp;</P>
<P>
&gt; Are there any other products, that as a Mercury Admin you
&gt; would recommend putting into the equation for a secure and
&gt; stable Email System?
ClamWall, Greywall and Spamwall for starters.&nbsp; I personally use POPFileD with POPFile instead of SpamWall but that's my personal preference based on the spam I get.&nbsp; Both work at the 99% level of effectiveness with a FPR under 0.05%.&nbsp; All these will be available when v4.51 comes out (real soon now).&nbsp;&nbsp;&nbsp; The reason I like these is that both are designed to work as daemons with Mercury/32 rather than external system that may or many not be that compatible.
[/quote]</P>
<P>Tom, thanx for the input.&nbsp; As I said, in the past, Symantec has never given me any troubles and I am certainly not convinced that it is the culprit here, either.&nbsp; I know some packages mess with your system based more on the types of programs installed.&nbsp; I am not a gamer, mostly all business and development software as I am a database programmer.&nbsp; Maybe that is why I have never had any issues with it.&nbsp; That aside... where are the products you referenced available?</P>
<P>ClamWall, GreyWall, SpamWall, PopFileD, etc.&nbsp; AND &nbsp;will these work with Mercury/32 v4.01b/c &nbsp;OR&nbsp; would I have to wait for v4.5 to use them?</P>
<P>I am waiting for v4.5 and pricing to determine which way to go... I hope "real soon now" is RSN so I can make the final decision and get on with it ! ! !</P>
<P>Regards,</P>
<P>Keith</P>
