Hi Steffan,
thank you. Additionally I've found by reading the Pegasus-Help (Thanks David [:)]) that an environmet variable must or can be used to define the common "pml-directory".
PML="Path\dir\dir\..."
So it is not necessary to use the method with public folders.
Tfl - Ronald.
<p>Hi Steffan,</p><p>&nbsp;</p><p>thank you. Additionally I've found by reading the Pegasus-Help (Thanks David [:)]) that an environmet variable must or can be used to define the common "pml-directory".</p><p>PML="Path\dir\dir\..."&nbsp; </p><p>So it is not necessary to use the method with public folders.</p><p>Tfl - Ronald.
