Intermittently, Mercury 4.72's IMAP window stats showing [Not-logged-in] or "SSL direct connect failure from x.x.x.x". The only solution I have found is to restart Mercury. This problem may occur a couple of days after a Mercury restart, or today it happened after several hours. It always works after Mercury is restarted.
Here are the session logs for each type of connection:
08:43:37.796: Connection from 97.239.79.164, Sat Jun 19 08:43:37 2010<lf>
08:43:37.796: << * OK po.pi-usa.us IMAP4rev1 Mercury/32 v4.72 server ready.<cr><lf>
08:43:37.937: >> 1496 STARTTLS<cr><lf>
08:43:37.937: << 1496 OK Begin SSL/TLS negotiation now.<cr><lf>
08:43:37.937: 20: Error -3 creating CryptLib session.
08:43:37.937: --- Connection closed normally at Sat Jun 19 08:43:37 2010. ---
08:43:37.937:
08:48:47.515: Connection from 67.223.76.217, Sat Jun 19 08:48:47 2010<lf>
08:48:47.515: 20: Error -3 creating CryptLib session.
08:48:47.531: --- Connection closed normally at Sat Jun 19 08:48:47 2010. ---
08:48:47.531:
If I connect to the IMAP via the Apache web server on the same machine, I can connect even when the other connections are failing.
Any ideas what is wrong?
Thanks.
-jeff
<p>Intermittently, Mercury 4.72's IMAP window stats showing [Not-logged-in] or "SSL direct connect failure from x.x.x.x". The only solution I have found is to restart Mercury. This problem may occur a couple of days after a Mercury restart, or today it happened after several hours. It always works after Mercury is restarted.</p><p><img src="file:///C:/DOCUME%7E1/Jeff/LOCALS%7E1/Temp/moz-screenshot.png" mce_src="file:///C:/DOCUME%7E1/Jeff/LOCALS%7E1/Temp/moz-screenshot.png" alt=""><img src="file:///C:/DOCUME%7E1/Jeff/LOCALS%7E1/Temp/moz-screenshot-1.png" mce_src="file:///C:/DOCUME%7E1/Jeff/LOCALS%7E1/Temp/moz-screenshot-1.png" alt=""> </p><p>Here are the session logs for each type of connection:</p><p>08:43:37.796: Connection from 97.239.79.164, Sat Jun 19 08:43:37 2010&lt;lf&gt;
08:43:37.796: &lt;&lt; * OK po.pi-usa.us IMAP4rev1 Mercury/32 v4.72 server ready.&lt;cr&gt;&lt;lf&gt;
08:43:37.937: &gt;&gt; 1496 STARTTLS&lt;cr&gt;&lt;lf&gt;
08:43:37.937: &lt;&lt; 1496 OK Begin SSL/TLS negotiation now.&lt;cr&gt;&lt;lf&gt;
08:43:37.937:
</p><p>08:48:47.515: Connection from 67.223.76.217, Sat Jun 19 08:48:47 2010&lt;lf&gt;
08:48:47.531:
</p><p>If I connect to the IMAP via the Apache web server on the same machine, I can connect even when the other connections are failing.
</p><p>Any ideas what is wrong?</p><p>Thanks.</p><p>&nbsp;-jeff
</p><p>&nbsp;</p><p>&nbsp;</p>
