A number of my users (including me) move our Pegasus Mail around a bit on external disks, flash sticks etc. I use the -ROAM switch, which happily lets Pegasus find my mail on the same disk letter as the program. However, I also have organisation address books and distribution lists. They are in a separate folder under PMAIL.
x:\PMAIL\PROGRAMS - the Pegasus program stuff
x:\PMAIL\USERS\... - all the user identities with their mail
x:\PMAIL\LISTS - all the organisation-wide shared address books and distribution lists
x:\PMAIL\PROGRAMS\PEGASUS.INI contains lines like:
pmr=c:\pmail\lists
pml=c:\pmail\lists
Having the AB&DLs in a separate folder to "programs" makes it easy to remove them all and replace them with new ones distributed centrally.
Of course, when I put my flash stick into another computer, it might become drive D, E, F, G or whatever.
The -ROAM switch does not seem to override the drive letter specified in PEGASUS.INI - I have to edit PEGASUS.INI and update the drive letter so I can see the address books and distribution lists.
Is there some smarter way I can avoid this?
Can I put something in place of "C" in PEGASUS.INI to tell it to substitute the current drive letter?
Is there a way I can tell Pegasus to "roam" everything - that ALL references to drive letters in any INI files, environment variables etc should be changed to the drive letter from which Pegasus started?
Thanks, Phil
<p>A number of my users (including me) move our Pegasus Mail around a bit on external disks, flash sticks etc. I use the -ROAM switch, which happily lets Pegasus find my mail on the same disk letter as the program. However, I also have organisation address books and distribution lists. They are in a separate folder under PMAIL.</p><p>&nbsp;x:\PMAIL\PROGRAMS - the Pegasus program stuff</p><p>x:\PMAIL\USERS\... - all the user identities with their mail</p><p>x:\PMAIL\LISTS - all the organisation-wide shared address books and distribution lists</p><p>&nbsp;x:\PMAIL\PROGRAMS\PEGASUS.INI contains lines like:</p><p>pmr=c:\pmail\lists</p><p>pml=c:\pmail\lists</p><p>Having the AB&amp;DLs in a separate folder to "programs" makes it easy to remove them all and replace them with new ones distributed centrally.
</p><p>Of course, when I put my flash stick into another computer, it might become drive D, E, F, G or whatever.</p><p>The -ROAM switch does not seem to override the drive letter specified in PEGASUS.INI - I have to edit PEGASUS.INI and update the drive letter so I can see the address books and distribution lists.</p><p>Is there some smarter way I can avoid this?</p><p>Can I put something in place of "C" in PEGASUS.INI to tell it to substitute the current drive letter?</p><p>Is there a way I can tell Pegasus to "roam" everything - that ALL references to drive letters in any INI files, environment variables etc should be changed to the drive letter from which Pegasus started?</p><p>Thanks, Phil</p><p>
