we run Mercury32 4.72 in NDS Mode on Windows Server 2008 with Novell Client 2 SP1 IR3. After some run time, the IMAP server seems to take very long to process new logins. It takes often 30 seconds, sometimes many minutes for a new imap login. Since most IMAP client regularly create new login connections during normal work, this has a serious impact on users. We use stunnel for ssl offloading and especially to use a correct ssl certificate, but the problem persists whether the stunnel runs on the same machine or on another.
Furhter things we see: Since login requests are not processed, the Mercury screen shows dozens of [Not logged in] connections, they often pile up faster than old ones are processed.
Any ideas? How can I check what takes Mercury so long?
Greetings
Markus Borst
<p>Hi,</p><p>
</p><p>we run Mercury32 4.72 in NDS Mode on Windows Server 2008 with Novell Client 2 SP1 IR3. After some run time, the IMAP server seems to take very long to process new logins. It takes often 30 seconds, sometimes many minutes for a new imap login. Since most IMAP client regularly create new login connections during normal work, this has a serious impact on users. We use stunnel for ssl offloading and especially to use a correct ssl certificate, but the problem persists whether the stunnel runs on the same machine or on another.</p><p>Furhter things we see: Since login requests are not processed, the Mercury screen shows dozens of [Not logged in] connections, they often pile up faster than old ones are processed.</p><p>Any ideas? How can I check what takes Mercury so long?</p><p>
</p><p>Greetings</p><p>Markus Borst</p><p>
