I have an idea for a workflow improvement feature that I think could be completely unique to Pegasus. Something that would actually improve the productivity of E-Mail itself (which has become a daily drudge for most people).
Most of us file away old e-mails by sender, project, client or vendor - but it's nearly impossible to file using all four criteria simultaneously. When it comes time to SEARCH for e-mails at some future date, you really want to be able to look for e-mails that fit MULTIPLE categories/criteria. For example, I might want to see all of the e-mails that "John" sent to me when we worked together on that "Widget" project for "Acme Corporation". Similarly, you could imagine a case where you might want to search for e-mails that ANY "vendor" sent to you while you were working on the "widget" project. Or....you could imagine a case where you want to search for all e-mail "receipts" received when working on the "widget" project.
You get the idea. That would be a way more useful search criteria and tool.
So my suggestion is to add the abilility to tag messages by arbitrary fields such as "project name", "client name", "vendor name", "issue", "business", "personal", etc... Then allow us to search for all e-mails that fit some matching pattern of these tags.
<p>I have an idea for a workflow improvement feature that I think could be completely unique to Pegasus. Something that would actually improve the productivity of E-Mail itself (which has become a daily drudge for most people).</p><p>Most of us file away old e-mails by sender, project, client or vendor - but it's nearly impossible to file using all four criteria simultaneously. When it comes time to SEARCH for e-mails at some future date, you really want to be able to look for e-mails that fit MULTIPLE categories/criteria. For example, I might want to see all of the e-mails that "John" sent to me when we worked together on that "Widget" project for "Acme Corporation". Similarly, you could imagine a case where you might want to search for e-mails that ANY "vendor" sent to you while you were working on the "widget" project. Or....you could imagine a case where you want to search for all e-mail "receipts" received when working on the "widget" project.</p><p>You get the idea. That would be a way more useful search criteria and tool.</p><p>So my suggestion is to add the abilility to tag messages by arbitrary fields such as "project name", "client name", "vendor name", "issue", "business", "personal", etc... Then allow us to search for all e-mails that fit some matching pattern of these tags.</p><p>
</p><p>
