Thank you.
Ah, well, it was worth a try.
The reason I am trying to do this is because we use MessageLabs for two of our three domains, and as I mentioned here http://community.pmail.com/forums/thread/24407.aspx we are having problems with undesirable mail (spam-bots) using the lowest MX record to deliver mail directly to our IP address.
I know I can remove the last MX record, but I wanted to avoid doing this if possible.
<p>Thank you.</p><p>Ah, well, it was worth a try.</p><p>The reason I am trying to do this is because we use MessageLabs for two of our three domains, and as I mentioned here&nbsp;<a href="http://community.pmail.com/forums/thread/24407.aspx">http://community.pmail.com/forums/thread/24407.aspx</a>&nbsp;we are having problems with undesirable mail (spam-bots) using the lowest MX record to deliver mail directly to our IP address.</p><p>I know I can remove the last MX record, but I wanted to avoid doing this if possible.&nbsp;</p>
