"Take a look at this thread http://community.pmail.com/forums/thread/21403.aspx
You need dosbox or similar to run these apps on 64-bit Windows."
Well... it worked so far as being able to make rescom function, but my variable sigs are still not showing up in the outgoing messages. Yes, the converted file resides in the proper location and the signature has ~! where the variation needs to be.
Any suggestions?
<p>You need dosbox or similar to run these apps on 64-bit Windows."
</p><p>
</p><p>Well... it worked so far as being able to make rescom function, but my variable sigs are still not showing up in the outgoing messages. Yes, the converted file resides in the proper location and the signature has ~! where the variation needs to be.</p><p>Any suggestions?</p>
