Connection established to
>> 0044 +OK (kcpop01) Maillennium POP3/UNIBOX #560
<< 0021 USER >> 0010 +OK user
<< 0015 PASS
8: Socket read timeout.Is that related to the same thing?
I have two different email addresses with attglobal.net and I run
them both through Pegasus. Could that be part of the problem, that
Pegasus is trying to check the second account before the first one has
actually closed?
The same POP3 account before it was closed. Not a second account since the error message was an error saying you were trying to make a connection to an open POP3 account. This other error is saying that the POP3 server did not respond before the timeout elapsed. In this case check the POP3 account setting timeout. It should be at least 90 seconds when connecting to a internet host.
Timeout: The length of time Pegasus Mail should wait on a reply from the host before concluding that there is a communication problem and giving up. If you enter zero (0) in this field, Pegasus Mail will use the default timeout that appears on the General Internet mail settings page of the Internet Options dialog.
<blockquote>Connection established to
&gt;&gt; 0044 +OK (kcpop01) Maillennium POP3/UNIBOX #560
&lt;&lt; 0021 USER &gt;&gt; 0010 +OK user
&lt;&lt; 0015 PASS
<p>Is that related to the same thing?</p><p>I have two different email addresses with attglobal.net and I run
them both through Pegasus.&nbsp; Could that be part of the problem, that
actually closed?</p></blockquote><p>The <b>same</b> POP3 account before it was closed.&nbsp;&nbsp; Not a second account since the error message was an error saying you were trying to make a connection to an open POP3 account.&nbsp; This other error is saying that the POP3 server did not respond before the timeout elapsed. In this case check the POP3 account setting timeout.&nbsp; It should be at least 90 seconds when connecting to a internet host.</p><b>Timeout</b>:&nbsp; <b><i>The length of time Pegasus Mail should wait on a reply from the host before concluding that there is a communication problem and giving up. If you enter zero (0) in this field, Pegasus Mail will use the default timeout that appears on the General Internet mail settings&nbsp; page of the Internet Options dialog.</i></b><p>&nbsp;</p>
