IE Control installation question
[quote user="edg"]Our Office setup has the Pegasus mail binaries installed in a common shared folder on the network, with individual users having their mail message (and .ini's etc) files in their own private folder elsewhere.
My question is in regards  to installing this control. If I do so, will it automatically replace bearhtml and configure the IE control for all users? Or is there a way to configure it to be enabled on a per user basis?[/quote]
See this thread.
[quote user="edg"]Our Office setup has the Pegasus mail binaries installed in a common shared folder on the network, with individual users having their mail message (and .ini's etc) files in their own private folder elsewhere.<p>My question is in regards  to installing this control. If I do so, will it automatically replace bearhtml and configure the IE control for all users? Or is there a way to configure it to be enabled on a per user basis?[/quote]</p>See <a href="/forums/thread/25108.aspx" target="_blank" mce_href="/forums/thread/25108.aspx">this thread</a>.
I wasn't sure whether to post this here or in the extensions forum...
In any case,  my question is in regards to installing the IE Control replacement for the BearHtml renderer.
<p>I wasn't sure whether to post this here or in the extensions forum... </p><p>In any case,  my question is in regards to installing the IE Control replacement for the BearHtml renderer.</p><p>Our Office setup has the Pegasus mail binaries installed in a common shared folder on the network, with individual users having their mail message (and .ini's etc) files in their own private folder elsewhere.</p><p>My question is in regards  to installing this control. If I do so, will it automatically replace bearhtml and configure the IE control for all users? Or is there a way to configure it to be enabled on a per user basis?</p><p>  </p>
