Install problem on 4.52
I decided to install 4.52 from 4.41 (xp). The install box truncayted at 3/4 across. That meant that I couldn't see the dialog boxes. I wasn't able to do the settings part of setup.
 I found the Internet options menu had the same problem. This means I can't see the dialog boxes and use it.
 No problem I thought I just re-intall the original. But the problem wont go away. What's could be causing it?
Regards
<p>I decided to install 4.52 from 4.41 (xp). The install box truncayted at 3/4 across. That meant that I couldn't see the dialog boxes. I wasn't able to do the settings part of setup.</p><p> I found the Internet options menu had the same problem. This means I can't see the dialog boxes and use it.</p><p> No problem I thought I just re-intall the original. But the problem wont go away. What's could be causing it? </p><p> </p><p>Regards </p>
[quote user="pmfrm"]Any takers?[/quote]
Can you please post a screenshot, I have no idea what you're talking about.
<p>[quote user="pmfrm"]Any takers?[/quote]</p><p>Can you please post a screenshot, I have no idea what you're talking about.</p>
I tried all available sizes. Made no diff. I just want to know what it did to my system
Regards
<p>I tried all available sizes. Made no diff. I just want to know what it did to my system</p><p>Regards </p>
