Requesting Urgent help
I don't understand... I do not want to use any external host. Why must I use smtp.gmail.com? I am only trying to run my own mail server, and testing whether it can receive outside mail.
I am planning on running my own email server.
Firstly, my ISP is blocking port 25 outbound traffic so I cannot send
emails to the outside anyway. I am planning to possibly upgrade to a
business account.
However I should be able to receive emails from my gmail account.
I wanted to test this so I sent an email to daemonturk@mydomain,
using pegagsus as a client to receive it. I got a POP3 error. Here is
the log:
--- Tue, 16 Nov 2010 17:30:18 ---
Connect to 'imagineandthink.zapto.org' port 110, timeout 15.
17:30:19.320 15: Peer connect failure (the host has refused the connection).
No matter what I try, I still get this error (actually, two of these error/logs appear per email sent).
I
am using a free domain service (no-ip) and I'm also not sure about MX
records. The norm seems to be to use mail.domainname, but how can I use
that if it doesn't exist?
I would appreciate it if you could tell me what to type in the MX record
section of my domain settings, and maybe tell me a bit about them.
 My domain name (imagineandthink.zapto.org)
is linked to my external IP, which I have a feeling is dynamic. However
it rarely changes, it only changes when I reboot the modem.
If you need more info then just ask, but my MercuryP
settings are probably ok. I still think the root of this problem is still Mercury/domain/network problems.
<p>I am planning on running my own email server.</p><p>Firstly, my ISP is blocking port 25 outbound traffic so I cannot send emails to the outside anyway. I am planning to possibly upgrade to a business account. However I should be able to receive emails from my gmail account. I wanted to test this so I sent an email to daemonturk@mydomain, using pegagsus as a client to receive it. I got a POP3 error. Here is the log: <b> --- Tue, 16 Nov 2010 17:30:18 --- Connect to '<a href="http://imagineandthink.zapto.org/" target="_blank">imagineandthink.zapto.org</a>' port 110, timeout 15. 17:30:19.320 15: Peer connect failure (the host has refused the connection).</b></p><p> No matter what I try, I still get this error (actually, two of these error/logs appear per email sent). I am using a free domain service (no-ip) and I'm also not sure about MX records. The norm seems to be to use mail.domainname, but how can I use that if it doesn't exist? I would appreciate it if you could tell me what to type in the MX record section of my domain settings, and maybe tell me a bit about them.  My domain name (<a href="http://imagineandthink.zapto.org/" target="_blank">imagineandthink.zapto.org</a>) is linked to my external IP, which I have a feeling is dynamic. However it rarely changes, it only changes when I reboot the modem. If you need more info then just ask, but my MercuryP settings are probably ok. I still think the root of this problem is still Mercury/domain/network problems. </p>
I suppose you'll get a quicker reply on the Mercury support forum ...
I suppose you'll get a quicker reply on the <a href="/forums/9/ShowForum.aspx" mce_href="/forums/9/ShowForum.aspx" target="_blank">Mercury support forum</a> ...
> log:
> connection).
Configuration | MercuryC and enter the following :
  Smart host name: smtp.gmail.com
  Connection port: 465
  Connection type: SSL encryption using via direct connection
  Credentials for SMTP Authentication: Login to the SMTP server using POP3
  username/password
Note: If you send via you GMail account it will always use the GMail default username for the From: address unless you go into the GMail Settings | Accounts and imports | Send mail as: and enter all of the e-mail addresses that you will use in Mercury.
To receive via MercuryD use
  Server host name: pop.gmail.com
  User name: <your_user_name>@gmail.com  Password: <your_password>
  Local user: local user@your.domain.com  Default user:  <postmaster user>
  Server TCP/IP port: 995  SSL connection via direct connect
  Enable server certificate fingerprint tracking: checked
&amp;gt; I wanted to test this so I sent an email to daemonturk@mydomain, using &amp;gt; pegagsus as a client to receive it. I got a POP3 error. Here is the &amp;gt; log: &amp;gt; &amp;gt; --- Tue, 16 Nov 2010 17:30:18 --- &amp;gt; Connect to &#039;imagineandthink.zapto.org&#039; port 110, timeout 15. &amp;gt; 17:30:19.320 15: Peer connect failure (the host has refused the &amp;gt; connection). Configuration | MercuryC and enter the following : &amp;nbsp; Smart host name: smtp.gmail.com &amp;nbsp; Connection port: 465 &amp;nbsp; Connection type: SSL encryption using via direct connection &amp;nbsp; Credentials for SMTP Authentication: Login to the SMTP server using POP3 &amp;nbsp; username/password Note: If you send via you GMail account it will always use the GMail default username for the From: address unless you go into the GMail Settings | Accounts and imports | Send mail as: and enter all of the e-mail addresses that you will use in Mercury. To receive via MercuryD use &amp;nbsp; Server host name: pop.gmail.com &amp;nbsp; User name: &amp;lt;your_user_name&amp;gt;@gmail.com&amp;nbsp; Password: &amp;lt;your_password&amp;gt; &amp;nbsp; Local user: local user@your.domain.com&amp;nbsp; Default user:&amp;nbsp; &amp;lt;postmaster user&amp;gt; &amp;nbsp; Server TCP/IP port: 995&amp;nbsp; SSL connection via direct connect &amp;nbsp; Enable server certificate fingerprint tracking: checked
