[quote user="rpk2006"]Oh sorry I erased the error description. It displays: "Connection Time Out", even when it internet is ON and it has successfully downloaded the few. In the error window, after scrolling down it displays: "Socket Timed Out".[/quote]
Increase the Timeout on Tools => Internet options => General and on the POP3/SMTP definitions for the respective connection.
[quote user="rpk2006"]That said, I tried "Selective Mail Download" from the Files menu, but it also crashed after 44 mail headers.[/quote]
You didn't say it crashed in your first post, just that an error occured? And, BTW, that's one of the issues that selective download is for: If any single message causes Pegasus Mail to fail you can download only a couple of them manually to figure out which one causes trouble without Pegasus Mail reloading the same messages over and over again.
And an addition with regard to filtering: You may apply each filter manually to any folder via Tools => Mail filtering rules => Apply general rule set to folder after doing selective downloads.
And if you really encounter a crash: Please consider using my MiniDump extension for providing debugging details for David Harris.
<p>[quote user="rpk2006"]Oh sorry I erased the error description. It displays: "Connection Time Out", even when it internet is ON and it has successfully downloaded the few. In the error window, after scrolling down it displays: "Socket Timed Out".[/quote]</p><p>Increase the Timeout on <em>Tools =&gt; Internet options =&gt; General</em> and on the POP3/SMTP definitions for the respective connection.</p><p>[quote user="rpk2006"]That said, I tried "Selective Mail Download" from the Files menu, but it also crashed after 44 mail headers.[/quote]</p><p>You didn't say it crashed in your first post, just that an error occured? And, BTW, that's one of the issues that selective download is for: If any single message causes Pegasus Mail to fail you can download only a couple of them manually to figure out which one causes trouble without Pegasus Mail reloading the same messages over and over again.</p><p>And an addition with regard to filtering: You may apply each filter manually to any folder via <em>Tools =&gt; Mail filtering rules =&gt; Apply general rule set to folder</em> after doing selective downloads.</p><p>And if you really encounter a crash: Please consider using my <a href="/files/folders/community_add-ons_for_pegasus_mail/tags/MiniDump/default.aspx" mce_href="/files/folders/community_add-ons_for_pegasus_mail/tags/MiniDump/default.aspx" target="_blank">MiniDump extension</a> for providing debugging details for David Harris.</p>
