Disable MercuryX unless you actually use it. If you use it you will need to download this patch:
http://community.pmail.com/files/folders/patches/entry24194.aspx
<p>Disable MercuryX unless you actually use it. If you use it you will need to download this patch:</p><p>http://community.pmail.com/files/folders/patches/entry24194.aspx</p><p>/Rolf&nbsp;</p>
