> I have been using pmail for years, but recently have encountered two problems. The first is that in the date time column for sorting
> messages, every e-mail received since the beginning of the month is listed as January 11. The second is that most of the time after
> moving messages to a folder, I can no longer access that folder without having to first reindex or in many cases, reindex, close the
> program and reopen it. Any suggestions would be greatly appreciated.
> Thanks.
1. Move all the messages you want to save to a temp folder and delete all the messages in the original folder.
2. Use the right click "recover deleted space" to remove all messages from the folder.
3. If step 2 works then simply move all of the messages from the temp folder back to the original folder and delete the temp folder.
4. If step 2 fails then delete the original folder and rename the temp folder to match the original name. Reset any filter pointing to this folder.
> Thanks.
