i am using mercury + imap since serveral years..
(not sure if this is the last year i will use it ... ;-)
i have only 2 users
so it is a REALY SMALL email server!
try to keep inbox "small" (not too many messages)
but have other folders (sent, trash, archive) with 2000 msg a year
MAIL folder is only 2GByte
using 4.72
a) it is SLOW!
doing "somthing" with imap, MOST times results in 100% CPU usage.. over several minutes
(even if it seems to be not file-based anymore, like some versions ago,?)
resuting in: sometimes looking vor new email in inbox is very fast, somtimes takes a minute..
b) since using android phone it is even worth
c) i have/had the "many copies of sent email in sent folder" when sending email from android phone (with android mail) problem
d) "solved" it usind KMail, but now have, "email does not get marked as read" problem.. (seems to do somithing called :append ? but does not work, ..)
e) using smartphone, there is ALWAYS a connenction (most time there are 5-6 connections per user), so e-mail NEVER get deleted... (solved by "sweet dreams", wich disconnects wlan/3g from 24:00 to 01:00)
<p>i am using mercury + imap since serveral years..</p><p>(not sure if this is the last year i will use it&nbsp; ... ;-)</p><p>&nbsp;</p><p>i have only 2 users</p><p>so it is a REALY SMALL email server!
</p><p>try to keep inbox "small" (not too many messages)</p><p>but have other folders (sent, trash, archive) with&nbsp; 2000 msg a year</p><p>MAIL folder is only 2GByte</p><p>&nbsp;</p><p>using 4.72
</p><p>a) it is SLOW!
</p><p>doing "somthing" with imap, MOST times results in 100%&nbsp; CPU usage.. over several minutes
</p><p>&nbsp;(even if it seems to be not file-based anymore, like some versions ago,?) </p><p>resuting in: sometimes looking vor new email in inbox is very fast, somtimes takes a minute..
</p><p>b) since using android phone it is even worth
</p><p>&nbsp;</p><p>c) i have/had the "many copies of sent email in sent folder" when sending email from android phone (with android mail) problem</p><p>d) "solved"&nbsp; it usind KMail, but now have, "email does not get marked as read" problem.. (seems to do somithing called :append ? but does not work, ..)</p><p>&nbsp;e) using smartphone, there is ALWAYS a connenction (most time there are 5-6 connections per user), so e-mail NEVER get deleted... (solved by "sweet dreams", wich disconnects wlan/3g from 24:00 to 01:00)</p><p>&nbsp;</p><p>&nbsp;</p><p>&nbsp;</p><p>&nbsp;</p><p>&nbsp;
</p><p>&nbsp;</p>
