Renaming Mailbox Problem
No biggie. Case closed. Regards.
[quote user="Steffan"]Not that I know of, sorry.[/quote]
<p>No biggie. Case closed. Regards.</p><p>[quote user="Steffan"]Not that I know of, sorry.[/quote]</p>
I'm having problems to rename my main mailbox.
I tried from the GUI, the options and even from pmail.ini. Any ideas?
Thanks.
<p>I'm having problems to rename my main mailbox.</p><p>I tried from the GUI, the options and even from pmail.ini. Any ideas?</p><p>Thanks.</p><p> </p>
Shut down Pegasus and open the hierarch.pm file in a text editor like Notepad. Now change the name printed in bold in the following line:
2,1,"78161447:My mailbox","","Mailbox"
<P>Shut down Pegasus and open the hierarch.pm file in a text editor like Notepad. Now change the name printed in bold in the following line:</P> <P>2,1,"78161447:My mailbox","","<STRONG>Mailbox</STRONG>"</P> <P>Cheers!</P>
Oh yes... THANKS
Open the hierarch.pm (...) change the name in bold in the following : 2,1,"78161447:My mailbox","","Mailbox"
While we are there and speaking of hierarchy. I also have a IMAP mailbox with very few folders. I would like to have it on top of "Mailbox" instead of under. Is there a way to change the order?
Regards,
<p>Oh yes... THANKS</p><p>[quote user="Steffan"]</p><p>Open the hierarch.pm (...) change the name in bold in the following : 2,1,"78161447:My mailbox","","<strong>Mailbox</strong>"</p> <p>[/quote]</p><p>While we are there and speaking of hierarchy. I also have a IMAP mailbox with very few folders. I would like to have it on top of "Mailbox" instead of under. Is there a way to change the order?</p><p>Regards,</p>
<P>Not that I know of, sorry.</P> <P>Cheers!</P>
