Thanks for the suggestions about SquirrelMail and Telaen, I am looking into getting a web server with PHP set up inhouse here to support them.
Meanwhile the SMTP problem is solved it was an issue with the way our firewall was set, it only allows connections from our ISP's relay system. They have a secure SMTP relay we can use so that is what we are doing as the firewall setting would seem to give us extra security. Thanks for all the help we got on this.
<p>Thanks for the suggestions about SquirrelMail and Telaen, I am looking into getting a web server with PHP set up inhouse here to support them.</p><p>&nbsp;Meanwhile the SMTP problem is solved it was an issue with the way our firewall was set, it only allows connections from our ISP's relay system.&nbsp;&nbsp; They have a secure SMTP relay we can use so that is what we are doing as the firewall setting would seem to give us extra security.&nbsp;&nbsp; Thanks for all the help we got on this.
</p><p>&nbsp;</p>
