Very good idea. To bad this feature is not tie to the Identities.
I could of clone my main Identity with only that difference (frequent check)
Wait a second, it still can be done, I will both clone my ID and the IMAP profiles.
The "OFFLINE" ID will use the IMAP clones with the "Periodically update the INBOX" off.
Flipping ID's is much more user friendly.
Thanks a lot, your recommendation lead to a great workaround.
BTW - Do you think trying to poll IMAP profiles during OFFLINE qualifies as a bug?
<p>Very good idea. To bad this feature is not tie to the Identities.</p><p>I could of clone my main Identity with only that difference (frequent check)</p><p>Wait a second, it still can be done, I will both clone my ID and the IMAP profiles.</p><p>The "OFFLINE" ID will use the IMAP clones with the "Periodically update the INBOX" off.</p><p>Flipping ID's is much more user friendly. </p><p>Thanks a lot, your recommendation lead to a great workaround.</p><p>BTW - Do you think trying to poll IMAP profiles during OFFLINE qualifies as a bug?</p>
