> Is there a way to rename the "Quick Action #1" entry?
> Is there a way to make a custom button or pull-down menu on the toolbar that would display the predefined actions (as a reminder)?
Check out bpanel.txt in the resource directory for the toolbar.pm file. Here's a toolbar.pm with a number of quick moves.
0,801,0,1801,"Compose a new mail message"
0,802,0,1802,"Open or re-scan your new mail folder"
0,803,0,1803,"Work with your mail folders"
0,804,0,1804,"Open or manage address books"
0,805,0,1805,"Edit or manage distribution (mailing) lists"
0,806,0,1806,"Open a list of local people on your system"
0,807,0,1807,"Create or manage rules for filtering your new mail"
0,808,0,1808,"Open or browse noticeboards"
2,840,0,"Identities"
0,823,0,1823,"Print the current window"
0,824,0,1824,"Select a font for the current window"
0,828,0,1828,"Send all queued mail"
0,827,0,1827,"Check your POP3 host for new mail"
0,829,0,1829,"Both check and send mail in one operation"
0,835,0,1835,"Selective Mail Download"
0,10274,0,1836,"Sort Folder by Thread"
0,10311,0,1845,"Move to WinPMail Tester Folder"
0,10312,0,1858,"Move to the Mun's Folder"
0,10313,0,1207,"Move to the Teacher Folder"
0,10314,0,1844,"Move to the Gurke Folder"
0,10315,0,1173,"Move to the McCormick Folder"
I picked the icons out of the icons in the png folder so that they would match the other icons on the toolbars.
> Is there a way to add a renamed "Quick Action #1" entry to a right-click mouse menu?
No.
> I see a mention of "Quick Folders" in the help files. But I cannot find the Quick copy/move submenu of the Folder menu that it refers to
> and the "Quick Folders" define button takes me right back to my already defined "Quick Actions".
Huh? When the folders are open under the top level menu "Messages" there the a menu Quick copy/move and a sub menu to edit the quick move functions.
> There's a nice menu bar displayed in the help files that looks like what I'm looking for. Is this something that will only appear in v5?
Not at all.
No.
Not at all.
