> I don't want to change or create a new directory. I just want to map
> the my second install of PMAIL to directories on a network.
Ok you do NOT want to use the Pegasus Mail move then to move the home mail directory.
> PMAIL doesn't seem compatible with mapping to networks?
Sure it is, I'm running Pegasus Mail with mailboxes on remote Netware, Linux and Windows servers. No problem at all. You just use pconfig.exe to change the home and new mail directory spec to the remote location. Here my system info on this Pegasus Mail installation. The program in this case is installed locally with a split home and new mail directory structure on a windows system.
Copyright (C) 1992-2011, David Harris, all rights reserved
WinPMail version: Version 4.61 (Win32), Feb 5 2011
Extension Manager version: 1.13
User name and ID: support, 0
Windows version: 5.1
WINPMAIL.EXE directory: C:\pmail
Home mailbox location: \\tstephenson\c_drive\pmail\mail\thomas
New mailbox location: \\tstephenson\c_drive\PMAIL\MAIL\support
TMP environment variable: c:\Temp
TEMP environment variable: c:\Temp
- WINSOCK path: C:\WINDOWS\system32\WSOCK32.DLL
Commandline: -a -i support -ms
Active -Z options: 32768
PMR variable: (None)
PML variable: (None)
MAI variable: (None)
NB variable: (None)
Autofiltering folders: 9 (9 active, 0 inactive)
Last new mail count: 51
> Please see this diagram: http://i54.tinypic.com/n2juo3.png
BTW, on Linux I run both Pegasus Mail and Mercury and other Windows programs over Wine, works pretty well for me.
> I can't use pconfig.exe, because its not compatible with Windows 7, even with its compatibility mode. Do you know what file it writes to?
> I could try writing to it in a text editor.
Pconfig.exe is compatible with Win7, it is not compatible with any Win64 systems since they removed the 16-bit support. Pconfig.exe writes the directory specs to pmail.cfg. Get a copy of DOSBox for running all your 16 bit applications in a 64 bit environment. I use it on both Window and Linux to run 16 bit MSDOS type programs. http://www.dosbox.com/
<p>&gt; I don't want to change or create a new directory. I just want to map
&gt; the my second install of PMAIL to directories on a network.
&gt; PMAIL doesn't seem compatible with mapping to networks?
Sure it is, I'm running Pegasus Mail with mailboxes on remote Netware, Linux and Windows servers.&nbsp; No problem at all.&nbsp; You just use pconfig.exe to change the home and new mail directory spec to the remote location.&nbsp; Here my system info on this Pegasus Mail installation.&nbsp; The program in this case is installed locally with a split home and new mail directory structure on a windows system.
WinPMail version: Version 4.61 (Win32), Feb&nbsp; 5 2011
<b>WINPMAIL.EXE directory: C:\pmail
New mailbox location: \\tstephenson\c_drive\PMAIL\MAIL\support</b>
&nbsp; - WINSOCK version: WinSock 2.0
&nbsp; - WINSOCK path: C:\WINDOWS\system32\WSOCK32.DLL
NB variable: (None)
&gt; Please see this diagram: http://i54.tinypic.com/n2juo3.png
&gt;
&gt; I can't use pconfig.exe, because its not compatible with Windows 7, even with its compatibility mode. Do you know what file it writes to?
&gt; I could try writing to it in a text editor.
Pconfig.exe is compatible with Win7, it is not compatible with any Win64 systems since they removed the 16-bit support.&nbsp; Pconfig.exe writes the directory specs to pmail.cfg.&nbsp; Get a copy of DOSBox for running all your 16 bit applications in a 64 bit environment.&nbsp; I use it on both Window and Linux to run 16 bit MSDOS type programs.&nbsp; <a href="http://www.dosbox.com/" title="http://www.dosbox.com/" mce_href="http://www.dosbox.com/">http://www.dosbox.com/</a></p><p>&nbsp;</p>
