for incoming emails
[quote user="forum user"]ive reinstalled the program and unchecked "do not permit SMTP ...."(like before)[/quote]
You should have this control box checked, and the one below it 'Use strict local relaying restrictions' as well.  Otherwise you are likely to become an open relay and used by spam senders anywhere.  Read the help to understand why.
If that causes a problem with using the server for your outgoing mail, you may have to allow relaying from your internal address block.
<P>[quote user="forum user"]ive reinstalled the program and unchecked "do not permit SMTP ...."(like before)[/quote]</P> <P>You <STRONG>should</STRONG> have this control box <STRONG>checked</STRONG>, and the one below it 'Use strict local relaying restrictions' as well.  Otherwise you are likely to become an open relay and used by spam senders anywhere.  Read the help to understand why.</P> <P>If that causes a problem with using the server for your outgoing mail, you may have to allow relaying from your internal address block.</P> <P mce_keep="true"> </P>
hello,
i just installed  mercury/32
im receiving emails for half a year on a computer(linux) .
i try to receive on windows(another computer).
they have in commun the mx address, the domain, the a address.
on linux i have the mails delivered ok.
here i think something isnt ok. for example when i try to send i get "SMTP server response: 553 We do not relay non-local mail,
sorry"
im trying to receive here
<p>hello,</p><p> </p><p>i just installed  mercury/32</p><p>im receiving emails for half a year on a computer(linux) .</p><p>i try to receive on windows(another computer).</p><p>they have in commun the mx address, the domain, the a address.</p><p>on linux i have the mails delivered ok.</p><p>here i think something isnt ok. for example when i try to send i get "<font size="1">SMTP server response: 553 We do not relay non-local mail, sorry"</font> </p><p>im trying to receive here </p>
ok i got some logs:
T 20110316 234546 4d814925 Connection from 66.163.179.173
T 20110316 234546 4d814925 HELO web35804.mail.mud.yahoo.com
T 20110316 234546 4d814925 MAIL FROM:<xxxx4@yahoo.com>
T 20110316 234546 4d814925 RCPT TO:<xxxx@xxxx.com>
E 20110316 234546 4d814925 RCPT from 66.163.179.173 - user <xxxx@xxxx.com> not known.
T 20110316 234546 4d814925 QUIT
T 20110316 234546 4d814925 Connection closed with 66.163.179.173, 0 sec. elapsed.
what to see next?
&lt;p&gt;ok i got some logs:&lt;/p&gt;&lt;p&gt;T 20110316 234546 4d814925 Connection from 66.163.179.173 T 20110316 234546 4d814925 HELO web35804.mail.mud.yahoo.com T 20110316 234546 4d814925 MAIL FROM:&amp;lt;xxxx4@yahoo.com&amp;gt; T 20110316 234546 4d814925 RCPT TO:&amp;lt;xxxx@xxxx.com&amp;gt; E 20110316 234546 4d814925 RCPT from 66.163.179.173 - user &amp;lt;xxxx@xxxx.com&amp;gt; not known. T 20110316 234546 4d814925 QUIT T 20110316 234546 4d814925 Connection closed with 66.163.179.173, 0 sec. elapsed. &lt;/p&gt;&lt;p&gt;what to see next? &lt;/p&gt;
ok i got some logs:
what to see next?
I'm guessing since you munged some very critical information.  Looks like you are trying to send mail where there is no match in the domain listing so this is non-local mail.  You are blocking relaying (really good idea) so it is rejecting because you have not turned on ESMTP authorization to allow the authorized sender to relay mail off the server.  Check out Configuration | MercuryS | Connection control | Help for additional details.
You also might post your mercury.ini file without changes so that we can help you get this properly configured.
&lt;p&gt;ok i got some logs:&lt;/p&gt;&lt;p&gt;T 20110316 234546 4d814925 Connection from 66.163.179.173 T 20110316 234546 4d814925 HELO web35804.mail.mud.yahoo.com T 20110316 234546 4d814925 MAIL FROM:&amp;lt;xxxx4@yahoo.com&amp;gt; T 20110316 234546 4d814925 RCPT TO:&amp;lt;xxxx@xxxx.com&amp;gt; E 20110316 234546 4d814925 RCPT from 66.163.179.173 - user &amp;lt;xxxx@xxxx.com&amp;gt; not known. T 20110316 234546 4d814925 QUIT T 20110316 234546 4d814925 Connection closed with 66.163.179.173, 0 sec. elapsed. &lt;/p&gt;&lt;p&gt;what to see next? &lt;/p&gt;&lt;p&gt;I&#039;m guessing since you munged some very critical information.&amp;nbsp; Looks like you are trying to send mail where there is no match in the domain listing so this is non-local mail.&amp;nbsp; You are blocking relaying (really good idea) so it is rejecting because you have not turned on ESMTP authorization to allow the authorized sender to relay mail off the server.&amp;nbsp; Check out Configuration | MercuryS | Connection control | Help for additional details.&lt;/p&gt;&lt;p&gt;You also might post your mercury.ini file without changes so that we can help you get this properly configured.&lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;
ok, thank you very much
i checked there a few options. i see the receiving emails but they are in the queue folder inside a long logs and after a minute they have the name changed.
basically im trying to stabilize the situation and to send them to a mailbox.(cant find them in C:\PMAIL\MAIL\ADMIN)
#  Sample Bindery Mode / Standalone Mode MERCURY.INI file.
#  This sample file implements most of the possible switches for each
#  module, but you can edit it to do less if you wish.
#  Anything after a '#' to the end of the line is a comment and
#  is stripped out before parsing. Trailing and leading whitespace
#  is also stripped before parsing. Many sample commands have been
#  left in this file commented out for reference purposes.
#  Note that in general, manual modification of this file is NOT
#  RECOMMENDED - use the Mercury "Configuration" menu to change the
#  program's settings wherever possible.
[General]
myname:          mydomain123.com    # Canonical name for this server
timezone:        +0000    # Time Zone to add to date fields
file_api:        1    # Use the file api instead of queues
mailqueue:       C:\MERCURY\QUEUE    # Where mail should be put for delivery
smtpqueue:       C:\MERCURY\QUEUE    # Where the SMTP client should look for mail
newmail_path:    C:\PMAIL\MAIL\ADMIN    # Where to find the users' WinPMail mailboxes.
[Protocols]
C:\MERCURY\mercurys.dll
C:\MERCURY\mercurye.dll
[Mercury]
failfile:      C:\MERCURY\Mercury\FAILURE.MER    # Delivery failure notification template
confirmfile:   C:\MERCURY\Mercury\CONFIRM.MER    # Delivery confirmation template
aliasfile:     C:\MERCURY\Mercury\ALIAS.MER    # System-wide alias file
synfile:       C:\MERCURY\Mercury\SYNONYM.MER    # User synonym database
listfile:      C:\MERCURY\Mercury\LISTS.MER    # List of lists
logfile:       C:\MERCURY\Logs\Core\~y-~m-~d.log    # Traffic logging file
logwidth:      30    # Width of address fields in logfile
retpath:       1    # Do/Don't use 'return-path' for errors
maxhops:       30    # Used to detect mailing loops
gullible:      0    # If NZ, don't validate 'From' fields
poll:          10   # Seconds between queue polling cycles
scratch:       C:\MERCURY\Scratch    # Where we can write temp files
returnlines:   15    # How many lines of failed messages to return
postmaster:    mail    # NetWare UIC of postmaster
broadcast:     1    # Yes, we want broadcast notifications, but
receipts:      0    # ... no broadcasts for receipt confirmations
PM_notify:     1    # Do/Don't send errors to the postmaster
change_owner:  1    # Change message ownership to recipient
auto_tzone:    1    # If NZ, obtain timezone information from OS
LogLevel:      15    # System message reporting level
LogMax:        100    # Maximum number of system messages to store
RetryPeriod:   30    # Period between job retries (minutes)
MaxRetries:    16    # Maximum number of times a job can fail
TwoPasses:     1    # If NZ, process submission queue in 2 passes
Autoaddress:   0    # If NZ, auto-generate user addresses based on name
Daily_exit:    0    # If NZ, auto-restart each day after maintenance
No_Areply:     0    # If NZ, disable automatic replies system-wide
Alt_Forward:   0    # If NZ, allow alternate forwarding specification
Maint_hour:    2    # Hour for daily maintenance (24-hour clock)
Maint_min:     0    # Minute for daily maintenance
Retry_Mode:    0    # If NZ, use progressive backoff for queue retries
Local_DSNs:    1    # If NZ generate Delivery Status for local users only
DSN_time1:     10800    # Seconds deferred before first DSN is sent
DSN_time2:     86400    # Seconds deferred before second DSN is sent
DSN_time3:     259200    # Seconds deferred before third DSN is sent
Host_in_title: 0    # If NZ, show hostname in system tray and taskbar
Lingering:     0    # Enable or disable 'lingering mailboxes'
Linger_Timeout: 60   # Seconds before a lingering mailbox is shut down
Alert_Host:    notify.pmail.com    # Host to check for licensee advisories
Alert_Interval: 720   # Frequency in minutes (min 240) for checks
Alert_Flags:   3    # Flags controlling advisory checks
[MercuryC]
logfile : C:\MERCURY\Logs\MercuryC\~y-~m-~d.log   # Traffic logging file
Session_logging : C:\MERCURY\Sessions\MercuryC\    # Directory for session log files
Session_logmode : 0
host:             # mail mail host which relays for us
scratch:     C:\MERCURY\scratch           # Where we can write temp files
poll:        30                   # Seconds between queue polling cycles
failfile:    C:\MERCURY\Mercury\FAILURE.MER  # Delivery failure template
esmtp:       1                    # Yes, we want to use ESMTP extensions
[MercuryE]
Poll : 15
Timeout : 60
logfile : C:\MERCURY\Logs\MercuryE\~y-~m-~d.log   # Traffic logging file
Session_logging : C:\MERCURY\Sessions\MercuryE\   # Directory for session log files
Session_logmode : 0
# Nameservers : 139.80.64.1
[MercuryD]
Session_logging : C:\MERCURY\Sessions\MercuryD\    # Directory for session log files
Session_logmode : 0
# Timeout : 30
# Poll : 120               # How often to check hosts for new mail (seconds)
[MercuryS]
Debug : 1
Logfile : C:\MERCURY\Logs\MercuryS\~y-~m-~d.log
Timeout : 30
Relay : 1
Strict_Relay : 0
8BitMime : 1
Allow_Illegals : 1
SMTP_Authentication : 0
Session_logging : C:\MERCURY\Sessions\MercuryS
Session_logmode : 0
Compliance_Settings : 0
Maximum_Failed_Rcpts : 4
Max_Relay_Attempts : 4
SSL_Mode : 0
ST_Blacklisting : 288
No_VRFY : 0
SMTP_ConnFlags : 0
[MercuryP]
logfile : C:\MERCURY\Logs\MercuryP\~y-~m-~d.log   # Traffic logging file
Session_logging : C:\MERCURY\Sessions\MercuryP\   # Directory for session log files
Session_logmode : 0
Timeout : 60
UIDL_nul_list : 1
New_UIDs : 1
No_NUL_passwords : 1
[MercuryX]
Drain_queues: 1
# Cmd_Delay: 10
# Cmd_Wait: 1
# IE4_Dialling: 0
# Use_ETRN: 1
# Clients_only: 1
# [Groups]
# testgroup            :     TESTGRP
[Domains]
mydomain123.com: mydomain123.com
mail.mydomain123.com: mail.mydomain123.com
[Maiser]
Helpfile:        C:\MERCURY\Mercury\MAISER.HLP   # Help sent on failed maiser requests
Lookupfile:      C:\MERCURY\Mercury\MAISER.LKP   # Format file for the 'lookup' command
Send_dir:        C:\MERCURY\Mercury\SENDABLE   # Directory for the 'send' command
Logfile:         C:\MERCURY\Logs\Maiser\~y-~m-~d.LOG   # Mail server log file
Notify:          C:\MERCURY\Mercury\TMP   # Dir. for pending 'notify' commands
[MercuryH]
logfile : C:\MERCURY\Logs\MercuryH\~y-~m-~d.log   # Traffic logging file
Timeout : 30
[MercuryI]
logfile : C:\MERCURY\Logs\MercuryI\~y-~m-~d.log   # Traffic logging file
Session_logging : C:\MERCURY\Sessions\MercuryI\   # Directory for session log files
Session_logmode : 0
Timeout : 120
Server_Port : 143
Idle_Timeout : 1800
[MercuryB]
logfile : C:\MERCURY\Logs\MercuryB\~y-~m-~d.log   # Traffic logging file
Session_logging : C:\MERCURY\Sessions\MercuryB\   # Directory for session log files
Session_logmode : 0
Timeout : 120
Server_Port : 80
Idle_Timeout : 1800
[Groups]
[Rewrite]
[Statistics]
StatFlags:    0  # Statistical reporting settings
STF_Hours:    24  # How often to write stat log files
STM_Hours:    24  # How often to e-mail stat log files
&lt;p&gt;ok, thank you very much &lt;/p&gt;&lt;p&gt;i checked there a few options. i see the receiving emails but they are in the queue folder inside a long logs and after a minute they have the name changed.&lt;/p&gt;&lt;p&gt;basically im trying to stabilize the situation and to send them to a mailbox.(cant find them in C:\PMAIL\MAIL\ADMIN)&lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;p&gt;#&amp;nbsp; MERCURY.INI generated by Mercury Setup # # #&amp;nbsp; Sample Bindery Mode / Standalone Mode MERCURY.INI file. #&amp;nbsp; This sample file implements most of the possible switches for each #&amp;nbsp; module, but you can edit it to do less if you wish. # #&amp;nbsp; Anything after a &#039;#&#039; to the end of the line is a comment and #&amp;nbsp; is stripped out before parsing. Trailing and leading whitespace #&amp;nbsp; is also stripped before parsing. Many sample commands have been #&amp;nbsp; left in this file commented out for reference purposes. # #&amp;nbsp; Note that in general, manual modification of this file is NOT #&amp;nbsp; RECOMMENDED - use the Mercury &quot;Configuration&quot; menu to change the #&amp;nbsp; program&#039;s settings wherever possible. # [General] myname:&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; mydomain123.com&amp;nbsp;&amp;nbsp;&amp;nbsp; # Canonical name for this server timezone:&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; +0000&amp;nbsp;&amp;nbsp;&amp;nbsp; # Time Zone to add to date fields file_api:&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; 1&amp;nbsp;&amp;nbsp;&amp;nbsp; # Use the file api instead of queues mailqueue:&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; C:\MERCURY\QUEUE&amp;nbsp;&amp;nbsp;&amp;nbsp; # Where mail should be put for delivery smtpqueue:&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; C:\MERCURY\QUEUE&amp;nbsp;&amp;nbsp;&amp;nbsp; # Where the SMTP client should look for mail newmail_path:&amp;nbsp;&amp;nbsp;&amp;nbsp; C:\PMAIL\MAIL\ADMIN&amp;nbsp;&amp;nbsp;&amp;nbsp; # Where to find the users&#039; WinPMail mailboxes. [Protocols] C:\MERCURY\mercurys.dll C:\MERCURY\mercurye.dll [Mercury] failfile:&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; C:\MERCURY\Mercury\FAILURE.MER&amp;nbsp;&amp;nbsp;&amp;nbsp; # Delivery failure notification template confirmfile:&amp;nbsp;&amp;nbsp; C:\MERCURY\Mercury\CONFIRM.MER&amp;nbsp;&amp;nbsp;&amp;nbsp; # Delivery confirmation template aliasfile:&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; C:\MERCURY\Mercury\ALIAS.MER&amp;nbsp;&amp;nbsp;&amp;nbsp; # System-wide alias file synfile:&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; C:\MERCURY\Mercury\SYNONYM.MER&amp;nbsp;&amp;nbsp;&amp;nbsp; # User synonym database listfile:&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; C:\MERCURY\Mercury\LISTS.MER&amp;nbsp;&amp;nbsp;&amp;nbsp; # List of lists logfile:&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; C:\MERCURY\Logs\Core\~y-~m-~d.log&amp;nbsp;&amp;nbsp;&amp;nbsp; # Traffic logging file logwidth:&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; 30&amp;nbsp;&amp;nbsp;&amp;nbsp; # Width of address fields in logfile retpath:&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; 1&amp;nbsp;&amp;nbsp;&amp;nbsp; # Do/Don&#039;t use &#039;return-path&#039; for errors maxhops:&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; 30&amp;nbsp;&amp;nbsp;&amp;nbsp; # Used to detect mailing loops gullible:&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; 0&amp;nbsp;&amp;nbsp;&amp;nbsp; # If NZ, don&#039;t validate &#039;From&#039; fields poll:&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; 10&amp;nbsp;&amp;nbsp; # Seconds between queue polling cycles scratch:&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; C:\MERCURY\Scratch&amp;nbsp;&amp;nbsp;&amp;nbsp; # Where we can write temp files returnlines:&amp;nbsp;&amp;nbsp; 15&amp;nbsp;&amp;nbsp;&amp;nbsp; # How many lines of failed messages to return postmaster:&amp;nbsp;&amp;nbsp;&amp;nbsp; mail&amp;nbsp;&amp;nbsp;&amp;nbsp; # NetWare UIC of postmaster broadcast:&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; 1&amp;nbsp;&amp;nbsp;&amp;nbsp; # Yes, we want broadcast notifications, but receipts:&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; 0&amp;nbsp;&amp;nbsp;&amp;nbsp; # ... no broadcasts for receipt confirmations PM_notify:&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; 1&amp;nbsp;&amp;nbsp;&amp;nbsp; # Do/Don&#039;t send errors to the postmaster change_owner:&amp;nbsp; 1&amp;nbsp;&amp;nbsp;&amp;nbsp; # Change message ownership to recipient auto_tzone:&amp;nbsp;&amp;nbsp;&amp;nbsp; 1&amp;nbsp;&amp;nbsp;&amp;nbsp; # If NZ, obtain timezone information from OS LogLevel:&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; 15&amp;nbsp;&amp;nbsp;&amp;nbsp; # System message reporting level LogMax:&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; 100&amp;nbsp;&amp;nbsp;&amp;nbsp; # Maximum number of system messages to store RetryPeriod:&amp;nbsp;&amp;nbsp; 30&amp;nbsp;&amp;nbsp;&amp;nbsp; # Period between job retries (minutes) MaxRetries:&amp;nbsp;&amp;nbsp;&amp;nbsp; 16&amp;nbsp;&amp;nbsp;&amp;nbsp; # Maximum number of times a job can fail TwoPasses:&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; 1&amp;nbsp;&amp;nbsp;&amp;nbsp; # If NZ, process submission queue in 2 passes Autoaddress:&amp;nbsp;&amp;nbsp; 0&amp;nbsp;&amp;nbsp;&amp;nbsp; # If NZ, auto-generate user addresses based on name Daily_exit:&amp;nbsp;&amp;nbsp;&amp;nbsp; 0&amp;nbsp;&amp;nbsp;&amp;nbsp; # If NZ, auto-restart each day after maintenance No_Areply:&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; 0&amp;nbsp;&amp;nbsp;&amp;nbsp; # If NZ, disable automatic replies system-wide Alt_Forward:&amp;nbsp;&amp;nbsp; 0&amp;nbsp;&amp;nbsp;&amp;nbsp; # If NZ, allow alternate forwarding specification Maint_hour:&amp;nbsp;&amp;nbsp;&amp;nbsp; 2&amp;nbsp;&amp;nbsp;&amp;nbsp; # Hour for daily maintenance (24-hour clock) Maint_min:&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; 0&amp;nbsp;&amp;nbsp;&amp;nbsp; # Minute for daily maintenance Retry_Mode:&amp;nbsp;&amp;nbsp;&amp;nbsp; 0&amp;nbsp;&amp;nbsp;&amp;nbsp; # If NZ, use progressive backoff for queue retries Local_DSNs:&amp;nbsp;&amp;nbsp;&amp;nbsp; 1&amp;nbsp;&amp;nbsp;&amp;nbsp; # If NZ generate Delivery Status for local users only DSN_time1:&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; 10800&amp;nbsp;&amp;nbsp;&amp;nbsp; # Seconds deferred before first DSN is sent DSN_time2:&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; 86400&amp;nbsp;&amp;nbsp;&amp;nbsp; # Seconds deferred before second DSN is sent DSN_time3:&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; 259200&amp;nbsp;&amp;nbsp;&amp;nbsp; # Seconds deferred before third DSN is sent Host_in_title: 0&amp;nbsp;&amp;nbsp;&amp;nbsp; # If NZ, show hostname in system tray and taskbar Lingering:&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; 0&amp;nbsp;&amp;nbsp;&amp;nbsp; # Enable or disable &#039;lingering mailboxes&#039; Linger_Timeout: 60&amp;nbsp;&amp;nbsp; # Seconds before a lingering mailbox is shut down Alert_Host:&amp;nbsp;&amp;nbsp;&amp;nbsp; notify.pmail.com&amp;nbsp;&amp;nbsp;&amp;nbsp; # Host to check for licensee advisories Alert_Interval: 720&amp;nbsp;&amp;nbsp; # Frequency in minutes (min 240) for checks Alert_Flags:&amp;nbsp;&amp;nbsp; 3&amp;nbsp;&amp;nbsp;&amp;nbsp; # Flags controlling advisory checks [MercuryC] logfile : C:\MERCURY\Logs\MercuryC\~y-~m-~d.log&amp;nbsp;&amp;nbsp; # Traffic logging file Session_logging : C:\MERCURY\Sessions\MercuryC\&amp;nbsp;&amp;nbsp;&amp;nbsp; # Directory for session log files Session_logmode : 0 host:&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; # mail mail host which relays for us scratch:&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; C:\MERCURY\scratch&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; # Where we can write temp files poll:&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; 30&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; # Seconds between queue polling cycles returnlines: 15&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; # How many lines of failed messages to return failfile:&amp;nbsp;&amp;nbsp;&amp;nbsp; C:\MERCURY\Mercury\FAILURE.MER&amp;nbsp; # Delivery failure template esmtp:&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; 1&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; # Yes, we want to use ESMTP extensions [MercuryE] Poll : 15 Timeout : 60 logfile : C:\MERCURY\Logs\MercuryE\~y-~m-~d.log&amp;nbsp;&amp;nbsp; # Traffic logging file Session_logging : C:\MERCURY\Sessions\MercuryE\&amp;nbsp;&amp;nbsp; # Directory for session log files Session_logmode : 0 # Nameservers : 139.80.64.1 [MercuryD] Session_logging : C:\MERCURY\Sessions\MercuryD\&amp;nbsp;&amp;nbsp;&amp;nbsp; # Directory for session log files Session_logmode : 0 Scratch : C:\MERCURY\Scratch\MercuryD # Timeout : 30 # Poll : 120&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; # How often to check hosts for new mail (seconds) [MercuryS] Debug : 1 Logfile : C:\MERCURY\Logs\MercuryS\~y-~m-~d.log Timeout : 30 Relay : 1 Strict_Relay : 0 8BitMime : 1 Allow_Illegals : 1 SMTP_Authentication : 0 Session_logging : C:\MERCURY\Sessions\MercuryS Session_logmode : 0 Compliance_Settings : 0 Maximum_Failed_Rcpts : 4 Max_Relay_Attempts : 4 SSL_Mode : 0 ST_Blacklisting : 288 No_VRFY : 0 SMTP_ConnFlags : 0 [MercuryP] logfile : C:\MERCURY\Logs\MercuryP\~y-~m-~d.log&amp;nbsp;&amp;nbsp; # Traffic logging file Session_logging : C:\MERCURY\Sessions\MercuryP\&amp;nbsp;&amp;nbsp; # Directory for session log files Session_logmode : 0 Scratch : C:\MERCURY\Scratch\MercuryP Timeout : 60 UIDL_nul_list : 1 New_UIDs : 1 No_NUL_passwords : 1 [MercuryX] Drain_queues: 1 # Cmd_Delay: 10 # Cmd_Wait: 1 # IE4_Dialling: 0 # Use_ETRN: 1 # Clients_only: 1 # Sunday: 0800,1800,3,15,30,60 # Monday: 0830,2100,5,15,60,60 # Tuesday: 0830,2100,5,15,60,60 # Wednesday: 1500,1900,2,30,5,30 # Thursday: 0900,1900,2,30,0,0 # Friday: 0830,2100,5,15,60,60 # Saturday: 1031,1035,2,45,-1,0 # [Groups] # testgroup&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; :&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; TESTGRP [Domains] mydomain123.com: mydomain123.com mail.mydomain123.com: mail.mydomain123.com [Maiser] Maiser:&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; Maiser&amp;nbsp;&amp;nbsp; # &#039;Username&#039; of mail server account Helpfile:&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; C:\MERCURY\Mercury\MAISER.HLP&amp;nbsp;&amp;nbsp; # Help sent on failed maiser requests Lookupfile:&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; C:\MERCURY\Mercury\MAISER.LKP&amp;nbsp;&amp;nbsp; # Format file for the &#039;lookup&#039; command Send_dir:&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; C:\MERCURY\Mercury\SENDABLE&amp;nbsp;&amp;nbsp; # Directory for the &#039;send&#039; command Logfile:&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; C:\MERCURY\Logs\Maiser\~y-~m-~d.LOG&amp;nbsp;&amp;nbsp; # Mail server log file Notify:&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; C:\MERCURY\Mercury\TMP&amp;nbsp;&amp;nbsp; # Dir. for pending &#039;notify&#039; commands NoList:&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; N&amp;nbsp;&amp;nbsp; # If &#039;Y&#039;, disable the &#039;list&#039; command Local_only:&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; Y&amp;nbsp;&amp;nbsp; # If &#039;Y&#039;, local &#039;notify&#039; commands only [MercuryH] logfile : C:\MERCURY\Logs\MercuryH\~y-~m-~d.log&amp;nbsp;&amp;nbsp; # Traffic logging file # Addressbook : \\CLIO\SYS\SYSTEM\MERCURY\PH.PMR # MOTD : \\CLIO\SYS\SYSTEM\MERCURY\PH-MOTD.TXT # Administrator : postmaster@clio.pmail.gen.nz Timeout : 30 [MercuryI] Scratch : C:\MERCURY\Scratch\MercuryI logfile : C:\MERCURY\Logs\MercuryI\~y-~m-~d.log&amp;nbsp;&amp;nbsp; # Traffic logging file Session_logging : C:\MERCURY\Sessions\MercuryI\&amp;nbsp;&amp;nbsp; # Directory for session log files Session_logmode : 0 Timeout : 120 Server_Port : 143 Idle_Timeout : 1800 [MercuryB] Scratch : C:\MERCURY\Scratch\MercuryB logfile : C:\MERCURY\Logs\MercuryB\~y-~m-~d.log&amp;nbsp;&amp;nbsp; # Traffic logging file Session_logging : C:\MERCURY\Sessions\MercuryB\&amp;nbsp;&amp;nbsp; # Directory for session log files Session_logmode : 0 Timeout : 120 Server_Port : 80 Idle_Timeout : 1800 # URL_Base : enter_your_domain_here [Groups] [Rewrite] [Statistics] StatFlags:&amp;nbsp;&amp;nbsp;&amp;nbsp; 0&amp;nbsp; # Statistical reporting settings STF_Hours:&amp;nbsp;&amp;nbsp;&amp;nbsp; 24&amp;nbsp; # How often to write stat log files STM_Hours:&amp;nbsp;&amp;nbsp;&amp;nbsp; 24&amp;nbsp; # How often to e-mail stat log files &amp;nbsp;&lt;/p&gt;
the lines are now coming in the queue folder along with other logs in the same file (and it seems that i have them in multiple files) and then the file has another name.
i try to find a way to separate the incoming plain text from other logs in the same file.
T 20110317 000624 4d814f4a Connection from 66.163.179.177
T 20110317 000625 4d814f4a HELO web35808.mail.mud.yahoo.com
T 20110317 000625 4d814f4a MAIL FROM:<xxxx@yahoo.com>
T 20110317 000625 4d814f4a RCPT TO:<xxxx@xxxx.com>
T 20110317 000625 4d814f4a DATA
T 20110317 000626 4d814f4a DATA - 38 lines, 2221 bytes.
T 20110317 000626 4d814f4a QUIT
T 20110317 000626 4d814f4a Connection closed with 66.163.179.177, 2 sec. elapsed.
i mean i think the solution is with the redirection to a mailbox but im looking forward for a resolvation
&lt;p&gt;the lines are now coming in the queue folder along with other logs in the same file (and it seems that i have them in multiple files) and then the file has another name.&lt;/p&gt;&lt;p&gt;i try to find a way to separate the incoming plain text from other logs in the same file. &lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;p&gt;T 20110317 000624 4d814f4a Connection from 66.163.179.177 T 20110317 000625 4d814f4a HELO web35808.mail.mud.yahoo.com T 20110317 000625 4d814f4a MAIL FROM:&amp;lt;xxxx@yahoo.com&amp;gt; T 20110317 000625 4d814f4a RCPT TO:&amp;lt;xxxx@xxxx.com&amp;gt; T 20110317 000625 4d814f4a DATA T 20110317 000626 4d814f4a DATA - 38 lines, 2221 bytes. T 20110317 000626 4d814f4a QUIT T 20110317 000626 4d814f4a Connection closed with 66.163.179.177, 2 sec. elapsed.&lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;p&gt;i mean i think the solution is with the redirection to a mailbox but im looking forward for a resolvation &lt;/p&gt;
i already have 1300 files in QUEUE and i see the plain text lines (the incoming email)
inside the logs.
i put Local mailbox directory path: (C:\PMAIL\MAIL\ADMIN)
to C:\123
in pegasus mail i moved home mailbox folder to C:\123
in mercury i try to use Manage local users... add, completed all but noting happen
&lt;p&gt;i already have 1300 files in QUEUE and i see the plain text lines (the incoming email) inside the logs.&amp;nbsp; &lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;p&gt;i put Local mailbox directory path: (C:\PMAIL\MAIL\ADMIN)&lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;p&gt;to C:\123&lt;/p&gt;&lt;p&gt;in pegasus mail i moved home mailbox folder to C:\123&lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;p&gt;in mercury i try to use Manage local users... add, completed all but noting happen &lt;/p&gt;
ok ive started with a sending procedure (right in the first place, and then the incoming email comes) so now i simple canot stop it and i have a lot of logs.
how to stop the messages that im trying to send?
&lt;p&gt;ok ive started with a sending procedure (right in the first place, and then the incoming email comes) so now i simple canot stop it and i have a lot of logs.&lt;/p&gt;&lt;p&gt;how to stop the messages that im trying to send? &lt;/p&gt;
ive sended an email to mercury.
 it is the text incuding:
T 20110317 014255 4d8166d6 DATA - 40 lines, 2258 bytes.
and then the program try to send back something:
included text: "RCPT TO:<senderaddress@yahoo.com>"
"Message accepted for delivery"
and then i got many:"Processing failed deliveries" and "Notification discarded - potential loop" and the queue box is growing.
how to not send something back when i got the email?
&lt;p&gt;ive reinstalled the program and unchecked &quot;do not permit SMTP ....&quot;(like before)&lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;p&gt;ive sended an email to mercury.&lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;p&gt;&amp;nbsp;it is the text incuding:&lt;/p&gt;&lt;p&gt; T 20110317 014255 4d8166d6 DATA - 40 lines, 2258 bytes.&lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;p&gt;and then the program try to send back something:&lt;/p&gt;&lt;p&gt;included text: &quot;RCPT TO:&amp;lt;senderaddress@yahoo.com&amp;gt;&quot;&lt;/p&gt;&lt;p&gt;&quot;Message accepted for delivery&quot;&lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;p&gt;and then i got many:&quot;Processing failed deliveries&quot; and &quot;Notification discarded - potential loop&quot; and the queue box is growing.&lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;p&gt;how to not send something back when i got the email? &lt;/p&gt;
ive unchecked "send copies of all errors to the postmaster"
the loop is ending
but after the process the emails are deleted from the queue and i dont know how to retrive it.
so i only have a small window to see the email
the email isnt in Local mailbox
how to keep the incoming email?
&lt;p&gt;ive unchecked &quot;send copies of all errors to the postmaster&quot;&lt;/p&gt;&lt;p&gt;the loop is ending&lt;/p&gt;&lt;p&gt;but after the process the emails are deleted from the queue and i dont know how to retrive it.&lt;/p&gt;&lt;p&gt;so i only have a small window to see the email&lt;/p&gt;&lt;p&gt;the email isnt in Local mailbox &lt;/p&gt;&lt;p&gt;how to keep the incoming email? &lt;/p&gt;
the last resort for the problem was to add special permission as a windows admin to the files in the folder and to prevent the program from removing them. now i can use both linux and windows
