small problem after upgrading to version 4.61
[quote user="kalu"]Thanks! i feel so lame :(
Don't.  My explanation should have been better.
James Quigley
<P>[quote user="kalu"]Thanks! i feel so lame :( [/quote]</P> <P>Don't.  My explanation should have been better.</P> <P>-- </P> <P>James Quigley</P>
Dear Friends
           I have updated the Pegasus Mail version from
4.5 to 4.61. the looks is fine but there is small problem or i should say small problem while reading the
received mails. . The problem is that the received mail all
appears in the single line, no breakage of paragraph format and justified body.
We must scrool left to right for reading the whole mail in a single
line.
           Is there any way out for this sort of problem
? Awaiting for your conclusive reply.
With
Regards.
kalu
<font size="2" face="Arial"><span style="FONT-SIZE: 10pt">Dear Friends </span></font> <div align="justify"><font size="2" face="Arial"><span style="FONT-SIZE: 10pt">           I have updated the Pegasus Mail version from 4.5 to 4.61. the looks is fine but there is small problem or i should say small problem while reading the received mails. . <b>The problem is that the received mail all appears in the single line, no breakage of paragraph format and justified body. We must scrool left to right for reading the whole mail in a single line.</b></span></font></div> <div align="justify"><font size="2" face="Arial"><span style="FONT-SIZE: 10pt">           Is there any way out for this sort of problem ? Awaiting for your conclusive reply.</span></font></div> <div align="justify"><font size="2" face="Arial"><span style="FONT-SIZE: 10pt"> </span></font></div> <div align="justify"><font size="2" face="Arial"><span style="FONT-SIZE: 10pt"> </span></font></div> <div align="justify"><font size="2" face="Arial"><span style="FONT-SIZE: 10pt">With Regards.</span></font></div>kalu <div align="left"><font size="2" face="Arial"><span style="FONT-SIZE: 10pt"> </span></font></div> <div align="left">  </div>
hi
jimwolfe6 thankyou verymuch that solved my problem but may i know what's the gui settings for shortcut "CTRL + F5" ?
i mean like tools->options->receving->wordwrap.
thankyou very much
kalu
<p>hi <span class="inlineLink">jimwolfe6 thankyou verymuch that solved my problem but may i know what's the gui settings for shortcut "CTRL + F5" ?</span></p><p>i mean like tools->options->receving->wordwrap. </p><p>thankyou very much</p><p>kalu </p>
In the Message Reader on the Toolbar select "Wrap long lines" or right click in the open message for available options.
The following is from the "Help Files"
"Wrap long lines, Reformat long lines.
Periodically, you will probably receive mail from other mail systems where the lines are extremely long, and hence can't
easily be read. These two options allow you to deal with malformatted mail of this kind - which of the two you will use depends on the message.
Wrap long lines simply chops the line at the nearest space to the right margin until the line is shorter than the right margin. This option is simplistic, but will work well if
the sender's mail program sends whole paragraphs as a single line.
Reformat long lines applies a much more complex reformatting approach that tries to estimate how the message was intended to appear:
it will usually do a better job of most messages than simple wrapping, but may scramble tables or figures that depend on long lines.
After atime, you will work out which of these settings suits the particular types of mail you receive. Whichever you turn on will
remain turned on for subsequent messages until you turn it off or select the alternative method."
James Quigley
<p>In the Message Reader on the Toolbar select "Wrap long lines" or right click in the open message for available options.</p><p>The following is from the "Help Files"</p><p><em>"Wrap long lines, Reformat long lines.</em></p><p><em>Periodically, you will probably receive mail from other mail systems where the lines are extremely long, and hence can't  easily be read. These two options allow you to deal with malformatted mail of this kind - which of the two you will use depends on the message.</em></p><p><em>Wrap long lines simply chops the line at the nearest space to the right margin until the line is shorter than the right margin. This option is simplistic, but will work well if the sender's mail program sends whole paragraphs as a single line.</em></p><p><em>Reformat long lines applies a much more complex reformatting approach that tries to estimate how the message was intended to appear:</em></p><p><em>it will usually do a better job of most messages than simple wrapping, but may scramble tables or figures that depend on long lines.</em></p><p><em>After atime, you will work out which of these settings suits the particular types of mail you receive. Whichever you turn on will  remain turned on for subsequent messages until you turn it off or select the alternative method."</em></p> <p>-- </p> <p>James Quigley </p>
Hello friend
but there is no *Message Reader* in the toolbar. only Message have a glance at my tool bar
%20%20Uploaded%20with%20ImageShack.us" mce_src=" Uploaded with ImageShack.us">
thanks
kalu
<p>Hello friend</p> <p>but there is no *Message Reader* in the toolbar. only Message have a glance at my tool bar</p><p><img src="[URL=http://img848.imageshack.us/i/barh.jpg/][IMG]http://img848.imageshack.us/img848/6659/barh.jpg[/IMG][/URL]%20%20Uploaded%20with%20[URL=http://imageshack.us]ImageShack.us[/URL]" mce_src="[URL=http://img848.imageshack.us/i/barh.jpg/][IMG]http://img848.imageshack.us/img848/6659/barh.jpg[/IMG][/URL] Uploaded with [URL=http://imageshack.us]ImageShack.us[/URL]"> </p><p>thanks</p><p>kalu </p>
[quote user="kalu"]
thankyou very much
 Ctrl-F5 (Wrap) and F5 (Reformat) "toggle" those features on and off with each press of the key. They will remain in the last setting even after closing and re-opening PMail. I don't believe there are settings for them in the Tools > Options menus.
[quote user="kalu"]<p><span class="inlineLink">may i know what's the gui settings for shortcut "CTRL + F5" ?</span></p><p>i mean like tools->options->receving->wordwrap. </p><p>thankyou very much</p><p> </p><p>[/quote]</p><p> Ctrl-F5 (Wrap) and F5 (Reformat) "toggle" those features on and off with each press of the key. They will remain in the last setting even after closing and re-opening PMail. I don't believe there are settings for them in the Tools > Options menus. </p>
[quote user="jimwolfe6"][quote user="kalu"]
thankyou very much
The setting is in the Reader Menu not the Tools Menu. See my previous post.
James Quigley
[quote user="jimwolfe6"][quote user="kalu"] <P><SPAN class=inlineLink>may i know what's the gui settings for shortcut "CTRL + F5" ?</SPAN></P> <P>i mean like tools->options->receving->wordwrap. </P> <P>thankyou very much</P> <P> </P> <P>[/quote]</P> <P> Ctrl-F5 (Wrap) and F5 (Reformat) "toggle" those features on and off with each press of the key. They will remain in the last setting even after closing and re-opening PMail. I don't believe there are settings for them in the Tools > Options menus. </P> <P>[/quote]</P> <P>The setting is in the Reader Menu not the Tools Menu. See my previous post.</P> <P>-- </P> <P>James Quigley</P>
Hello Kalu,
Open a message and you will see the Reader.
<div>Hello Kalu,</div><div> </div><div>Open a message and you will see the Reader.</div><div> </div>
