Well, it looks like a simple SMTP server(!).
You need to tell us if the installation is local or on another computer. You will need to create a gateway using pconfig.exe that points to the computer that hosts the program. The help file will help you with this. You will need to set the path to the server and the format that the mail should take when being sent. This will allow you to send mail.
You also need to make sure the SMTP software is correctly configured so that it delivers downloaded mail into the folder that Pegasus Mails polls for mail.
As Sharkfin says, tell us more about your setup, but also take the time to read the Pegasus Mail manual as that will help explain the settings and what you can achieve. Setting up SMTP for the first time can be a little daunting. It is essential that you do the required research to ensure that you not only understand what the pconfig settings and the SMTP settings do, but that you also understand the SMTP process of delivery and receipt. If you do not do this, you risk running around in circles and potentially losing email.
<P>Well, it looks like a simple SMTP server(!).</P>
<P>You need to tell us if the installation is local or on another computer. You will need to create a gateway using pconfig.exe that points to the&nbsp;computer that hosts the program. The help file will help you with this. You will need to set the path to the server and the format that the mail should take when being sent.&nbsp;This will allow you to send mail.</P>
<P>&nbsp;You also need to make sure the SMTP software is correctly configured so that it delivers downloaded mail into the folder that Pegasus Mails polls for mail.</P>
<P>As Sharkfin says, tell us more about your setup, but also take the time to read the Pegasus Mail manual as that will help explain the settings and what you can achieve. Setting up SMTP for the first time can be a little daunting. It is essential that you do the required research to ensure that you not only understand what the pconfig settings and the SMTP settings do, but that you also understand the SMTP process of delivery and receipt. If you do not do this, you risk running around in circles and potentially losing email.</P>
