Hi.
I am experiencing a problem when printing to our printer. No matter what I do I can only get it to print on paper from tray 1. It doesn't matter if I tell it to use tray 2. When it is printed it still uses tray 1.
All other programs (word, notepad, excel and so on) works just fine. I can print on which ever tray I choose to use. So the problem seems to be only with Pegasus.
We are running Pegasus 4.41 on a Windows XP with SP2 and have installed it to be used in a network environment so all three people here can use it.
We used to run version 4.31 in a Novell 3.12 environment, and in that setup printing worked just fine. The issue seems to have appeared after switching to XP instead of Novell 3.12 and Pegasus 4.41 instead of 3.31.
I have spent quite some time on this now, and there is just no way that the choise I make about what tray to use, when printing from pegasus has any influence at all. It just prints from tray 1 no matter what I choose.
Have I missed something in the setup, or is this a known issue when running Pegasus 4.41 in a Windows network environment ?
The printer is attached to a Linksys printserver. But since all other applications can print just fine, I just don't see why the printserver could be the problem. Pegasus printing is the only one that behaves in this way.
Right now I just choose to print to our PDF driver, and then print to the printer from there. But that really shouldn't be the way to do it.
Thanks in advance
Rene
<P>Hi.</P>
<P>I am experiencing a problem when printing to our printer. No matter what I do I can only get it to print on paper from tray 1. It doesn't matter if I tell it to use tray 2. When it is printed it still uses tray 1.</P>
<P>All other programs (word, notepad, excel and so on) works just fine. I can print on which ever tray I choose to use. So the problem seems to be only with Pegasus.</P>
<P>We are running Pegasus 4.41 on a Windows XP with SP2 and have installed it to be used in a network environment so all three people here can use it.</P>
<P>We used to run version 4.31 in a Novell 3.12 environment, and in that setup printing worked just fine. The issue seems to have appeared after switching to XP instead of Novell 3.12 and Pegasus 4.41 instead of 3.31.</P>
<P>I have spent quite some time on this now, and there is just no way that the choise I make about what tray to use, when printing from pegasus has any influence at all. It just prints from tray 1 no matter what I choose.</P>
<P>Have I missed something in the setup, or is this a known issue when running Pegasus 4.41 in a Windows network environment ?</P>
<P>The printer is attached to a Linksys printserver. But since all other applications can print just fine, I just don't see why the printserver could be the problem. Pegasus printing is the only one that behaves in this way.</P>
<P>Right now I just choose to print to our PDF driver, and then print to the printer from there. But that really shouldn't be the way to do it.</P>
<P>Thanks in advance</P>
<P>Rene</P>
<P mce_keep="true">&nbsp;</P>
