Would be nice to get this long standing bug fixed:
When you perform a search and the search finishes and takes you to the search results folder, the date column in the string grid is always about 10 or 20 pixels too narrow so you can't see the day of the month. Every time I search, I have to click and drag the date column to make it wider. Worse, you can only drag a few pixels to the right at a time when widening the date column so you have to drag several times. While dragging the column widths in existing folders sticks, each new search creates a new search results folder and it appears you need to update your default column widths in your stringgrid so that the entire date can be seen: either that or remember the last user setting and use it for the default in future searches (better).
Regards,
Mike
<p>Would be nice to get this long standing bug fixed:</p><p>When you perform a search and the search finishes and takes you to the search results folder, the date column in the string grid is always about 10 or 20&nbsp; pixels too narrow so you can't see the day of the month.&nbsp; Every time I search, I have to click and drag the date column to make it wider.&nbsp; Worse, you can only drag a few pixels to the right at a time when widening the date column so you have to drag several times.&nbsp; While dragging the column widths in existing folders sticks, each new search creates a new search results folder and it appears you need to update your default column widths in your stringgrid so that the entire date can be seen: either that or remember the last user setting and use it for the default in future searches (better).</p><p>&nbsp;</p><p>Regards,</p><p>Mike
