[quote user="Jerry Wise"]
Let's try to go one step at a time as it gets confusing First of all look carefully at the Reply button on the toolbar when you have a message open for reading or you are in a messages folder. Run the mouse cursor across the button surface slowly, the button is split, and then click on the right portion. You have descriptive text and a choice to be made there. [/quote]
You've shown me something already. I never knew that option existed! I see where you are going (I think...).
[quote user="Jerry Wise"] The default with no items checked in the reply dialog is to reply to the From address or use the default reply address one if present. If the reply address is checked but then there is none present in the next message a reply to the From address is used. Are you confused yet<G>? [/quote]
Confused? Just a little, but it's not hard! [;)] I now have some options to play with and I just need to get an email with multiple addressees so I can experiment with this new-found knowledge. I'm still surprised I never noticed that little down arrow on the right side of the "reply" button before. But thanks for the tip!
I will see if my selections remain checked after using these options next time. IAC, I can select my choice easily even if the settings don't stick, courtesy of the arrow on the "reply" button. Thank you so much for pointing this out to me and giving me something to use to see if I can make things work like they used to. Thanks again!
[quote user="Jerry Wise"]<p>Let's try to go one step at a time as it gets confusing&nbsp; First of all look carefully at the Reply button on&nbsp; the toolbar when&nbsp; you have a message open for reading or you are in a messages folder. Run the mouse cursor across the button surface slowly, the button is split, and then click on the right portion. You have descriptive text and a choice to be made there. [/quote]</p><p>You've shown me something already. I never knew that option existed! I see where you are going (I think...).
</p><p>[quote user="Jerry Wise"] The default with no items checked in the reply dialog is to reply to the From address or use the default reply address one if present. If the reply address is checked but then there is none present in the next message a reply to the From address is used. Are you confused yet&lt;G&gt;? [/quote]</p><p>Confused? Just a little, but it's not hard!&nbsp;[;)] I now have some options to play with and I just need to get an email with multiple addressees so I can experiment with this new-found knowledge. I'm still surprised I never noticed that little down arrow on the right side of the "reply" button before. But thanks for the tip!</p><p>I will see if my selections remain checked after using these options next time. IAC, I can select my choice easily even if the settings <i>don't</i> stick, courtesy of the arrow on the "reply" button. Thank you so much for pointing this out to me and giving me something to use to see if I can make things work like they used to. Thanks again!
