Local computer engmonitor-01a @ 10.2.13.96
# MERCURY.INI generated by Mercury Setup
# Sample Bindery Mode / Standalone Mode MERCURY.INI file.
# This sample file implements most of the possible switches for each
# module, but you can edit it to do less if you wish.
# Anything after a '#' to the end of the line is a comment and
# is stripped out before parsing. Trailing and leading whitespace
# is also stripped before parsing. Many sample commands have been
# left in this file commented out for reference purposes.
# Note that in general, manual modification of this file is NOT
# RECOMMENDED - use the Mercury "Configuration" menu to change the
# program's settings wherever possible.
[General]
myname: 10.2.13.96 # Canonical name for this server
timezone: +0000 # Time Zone to add to date fields
mailqueue: C:\MERCURY\QUEUE # Where mail should be put for delivery
smtpqueue: C:\MERCURY\QUEUE # Where the SMTP client should look for mail
newmail_path: C:\MERCURY\MAIL\~N # Where to find the users' WinPMail mailboxes.
[Protocols]
MERCURYS.DLL
# MERCURYP.DLL
# MERCURYE.DLL
MERCURYC.DLL
# MERCURYD.DLL
# MERCURYH.DLL
# MERCURYF.DLL
# MERCURYW.DLL
# MERCURYX.DLL
# MERCURYI.DLL
# MERCURYB.DLL
[Mercury]
failfile: C:\MERCURY\Mercury\FAILURE.MER # Delivery failure notification template
confirmfile: C:\MERCURY\Mercury\CONFIRM.MER # Delivery confirmation template
aliasfile: C:\MERCURY\Mercury\ALIAS.MER # System-wide alias file
synfile: C:\MERCURY\Mercury\SYNONYM.MER # User synonym database
listfile: C:\MERCURY\Mercury\LISTS.MER # List of lists
logfile: C:\MERCURY\Logs\Core\~y-~m-~d.log # Traffic logging file
retpath: 1 # Do/Don't use 'return-path' for errors
poll: 10 # Seconds between queue polling cycles
scratch: C:\MERCURY\Scratch # Where we can write temp files
postmaster: PA User # NetWare UIC of postmaster
broadcast: 1 # Yes, we want broadcast notifications, but
PM_notify: 1 # Do/Don't send errors to the postmaster
change_owner: 1 # Change message ownership to recipient
RetryPeriod: 30 # Period between job retries (minutes)
MaxRetries: 16 # Maximum number of times a job can fail
TwoPasses: 1 # If NZ, process submission queue in 2 passes
Autoaddress: 0 # If NZ, auto-generate user addresses based on name
Daily_exit: 0 # If NZ, auto-restart each day after maintenance
Alt_Forward: 0 # If NZ, allow alternate forwarding specification
Maint_hour: 2 # Hour for daily maintenance (24-hour clock)
Retry_Mode: 0 # If NZ, use progressive backoff for queue retries
Local_DSNs: 1 # If NZ generate Delivery Status for local users only
DSN_time1: 10800 # Seconds deferred before first DSN is sent
DSN_time2: 86400 # Seconds deferred before second DSN is sent
DSN_time3: 259200 # Seconds deferred before third DSN is sent
Host_in_title: 0 # If NZ, show hostname in system tray and taskbar
Lingering: 0 # Enable or disable 'lingering mailboxes'
Linger_Timeout: 60 # Seconds before a lingering mailbox is shut down
Alert_Host: notify.pmail.com # Host to check for licensee advisories
Alert_Interval: 720 # Frequency in minutes (min 240) for checks
Alert_Flags: 3 # Flags controlling advisory checks
[MercuryC]
Host : smtp1.alleghenytechnologies.com
Failfile : C:\MERCURY\Mercury\FAILURE.MER
Poll : 30
Scratch : C:\MERCURY\scratch
ReturnLines : 15
Timeout : 30
ESMTP : 1
POP3_Auth : 0
Logfile : C:\MERCURY\Logs\MercuryC\~y-~m-~d.log
Log_Verbose : 0
Session_logging : C:\MERCURY\Sessions\MercuryC
Session_logmode : 0
[MercuryE]
Poll : 15
Timeout : 60
logfile : C:\MERCURY\Logs\MercuryE\~y-~m-~d.log # Traffic logging file
Session_logging : C:\MERCURY\Sessions\MercuryE\ # Directory for session log files
Session_logmode : 0
# Nameservers : 139.80.64.1
[MercuryD]
Session_logging : C:\MERCURY\Sessions\MercuryD\ # Directory for session log files
Session_logmode : 0
# Timeout : 30
# Poll : 120 # How often to check hosts for new mail (seconds)
[MercuryS]
Debug : 1
Logfile : C:\MERCURY\Logs\MercuryS\~y-~m-~d.log
Timeout : 30
Relay : 1
Strict_Relay : 0
Allow_Illegals : 1
SMTP_Authentication : 0
Session_logging : C:\MERCURY\Sessions\MercuryS
Session_logmode : 0
Compliance_Settings : 0
Maximum_Failed_Rcpts : 4
Max_Relay_Attempts : 4
SSL_Mode : 0
ST_Blacklisting : 288
No_VRFY : 0
SMTP_ConnFlags : 0
[MercuryP]
Logfile : C:\MERCURY\Logs\MercuryP\~y-~m-~d.log
Stack : 32768
Mark_Read : 1
SSL_Mode : 0
Login_Disabled : 0
UIDL_nul_list : 1
New_UIDs : 1
No_NUL_passwords : 1
Session_logging : C:\MERCURY\Sessions\MercuryP
Session_logmode : 0
Timeout : 60
[MercuryX]
Drain_queues: 1
# Cmd_Delay: 10
# Cmd_Wait: 1
# IE4_Dialling: 0
# Use_ETRN: 1
# Clients_only: 1
# [Groups]
# testgroup : TESTGRP
[Domains]
10: 10
10: 10.2.13.96
[Maiser]
Helpfile: C:\MERCURY\Mercury\MAISER.HLP # Help sent on failed maiser requests
Lookupfile: C:\MERCURY\Mercury\MAISER.LKP # Format file for the 'lookup' command
Send_dir: C:\MERCURY\Mercury\SENDABLE # Directory for the 'send' command
Logfile: C:\MERCURY\Logs\Maiser\~y-~m-~d.LOG # Mail server log file
Notify: C:\MERCURY\Mercury\TMP # Dir. for pending 'notify' commands
[MercuryH]
logfile : C:\MERCURY\Logs\MercuryH\~y-~m-~d.log # Traffic logging file
Timeout : 30
[MercuryI]
logfile : C:\MERCURY\Logs\MercuryI\~y-~m-~d.log # Traffic logging file
Session_logging : C:\MERCURY\Sessions\MercuryI\ # Directory for session log files
Session_logmode : 0
Timeout : 120
Server_Port : 143
Idle_Timeout : 1800
[MercuryB]
logfile : C:\MERCURY\Logs\MercuryB\~y-~m-~d.log # Traffic logging file
Session_logging : C:\MERCURY\Sessions\MercuryB\ # Directory for session log files
Session_logmode : 0
Timeout : 120
Server_Port : 80
Idle_Timeout : 1800
[Groups]
[Rewrite]
[Statistics]
StatFlags: 0 # Statistical reporting settings
STM_Hours: 24 # How often to e-mail stat log files
<P>Local computer engmonitor-01a @ 10.2.13.96&nbsp;</P>
<P mce_keep="true">&nbsp;</P>
<P>#&nbsp; MERCURY.INI generated by Mercury Setup
#&nbsp; Sample Bindery Mode / Standalone Mode MERCURY.INI file.
#&nbsp; This sample file implements most of the possible switches for each
#&nbsp; module, but you can edit it to do less if you wish.
#&nbsp; Anything after a '#' to the end of the line is a comment and
#&nbsp; is stripped out before parsing. Trailing and leading whitespace
#&nbsp; is also stripped before parsing. Many sample commands have been
#&nbsp; left in this file commented out for reference purposes.
#&nbsp; Note that in general, manual modification of this file is NOT
#&nbsp; RECOMMENDED - use the Mercury "Configuration" menu to change the
#&nbsp; program's settings wherever possible.
#</P>
<P>[General]
myname:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 10.2.13.96&nbsp;&nbsp;&nbsp; # Canonical name for this server
timezone:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; +0000&nbsp;&nbsp;&nbsp; # Time Zone to add to date fields
file_api:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 1&nbsp;&nbsp;&nbsp; # Use the file api instead of queues
mailqueue:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; C:\MERCURY\QUEUE&nbsp;&nbsp;&nbsp; # Where mail should be put for delivery
smtpqueue:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; C:\MERCURY\QUEUE&nbsp;&nbsp;&nbsp; # Where the SMTP client should look for mail
newmail_path:&nbsp;&nbsp;&nbsp; C:\MERCURY\MAIL\~N&nbsp;&nbsp;&nbsp; # Where to find the users' WinPMail mailboxes.</P>
<P>[Protocols]
MERCURYS.DLL
# MERCURYP.DLL
# MERCURYE.DLL
MERCURYC.DLL
# MERCURYD.DLL
# MERCURYH.DLL
# MERCURYF.DLL
# MERCURYW.DLL
# MERCURYX.DLL
# MERCURYI.DLL
# MERCURYB.DLL</P>
<P>[Mercury]
failfile:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; C:\MERCURY\Mercury\FAILURE.MER&nbsp;&nbsp;&nbsp; # Delivery failure notification template
confirmfile:&nbsp;&nbsp; C:\MERCURY\Mercury\CONFIRM.MER&nbsp;&nbsp;&nbsp; # Delivery confirmation template
aliasfile:&nbsp;&nbsp;&nbsp;&nbsp; C:\MERCURY\Mercury\ALIAS.MER&nbsp;&nbsp;&nbsp; # System-wide alias file
synfile:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; C:\MERCURY\Mercury\SYNONYM.MER&nbsp;&nbsp;&nbsp; # User synonym database
listfile:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; C:\MERCURY\Mercury\LISTS.MER&nbsp;&nbsp;&nbsp; # List of lists
logfile:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; C:\MERCURY\Logs\Core\~y-~m-~d.log&nbsp;&nbsp;&nbsp; # Traffic logging file
logwidth:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 30&nbsp;&nbsp;&nbsp; # Width of address fields in logfile
retpath:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 1&nbsp;&nbsp;&nbsp; # Do/Don't use 'return-path' for errors
maxhops:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 30&nbsp;&nbsp;&nbsp; # Used to detect mailing loops
gullible:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp; # If NZ, don't validate 'From' fields
poll:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 10&nbsp;&nbsp; # Seconds between queue polling cycles
scratch:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; C:\MERCURY\Scratch&nbsp;&nbsp;&nbsp; # Where we can write temp files
returnlines:&nbsp;&nbsp; 15&nbsp;&nbsp;&nbsp; # How many lines of failed messages to return
postmaster:&nbsp;&nbsp;&nbsp; PA User&nbsp;&nbsp;&nbsp; # NetWare UIC of postmaster
broadcast:&nbsp;&nbsp;&nbsp;&nbsp; 1&nbsp;&nbsp;&nbsp; # Yes, we want broadcast notifications, but
receipts:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp; # ... no broadcasts for receipt confirmations
PM_notify:&nbsp;&nbsp;&nbsp;&nbsp; 1&nbsp;&nbsp;&nbsp; # Do/Don't send errors to the postmaster
change_owner:&nbsp; 1&nbsp;&nbsp;&nbsp; # Change message ownership to recipient
auto_tzone:&nbsp;&nbsp;&nbsp; 1&nbsp;&nbsp;&nbsp; # If NZ, obtain timezone information from OS
LogLevel:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 15&nbsp;&nbsp;&nbsp; # System message reporting level
LogMax:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 100&nbsp;&nbsp;&nbsp; # Maximum number of system messages to store
RetryPeriod:&nbsp;&nbsp; 30&nbsp;&nbsp;&nbsp; # Period between job retries (minutes)
MaxRetries:&nbsp;&nbsp;&nbsp; 16&nbsp;&nbsp;&nbsp; # Maximum number of times a job can fail
TwoPasses:&nbsp;&nbsp;&nbsp;&nbsp; 1&nbsp;&nbsp;&nbsp; # If NZ, process submission queue in 2 passes
Autoaddress:&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp; # If NZ, auto-generate user addresses based on name
Daily_exit:&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp; # If NZ, auto-restart each day after maintenance
No_Areply:&nbsp;&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp; # If NZ, disable automatic replies system-wide
Alt_Forward:&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp; # If NZ, allow alternate forwarding specification
Maint_hour:&nbsp;&nbsp;&nbsp; 2&nbsp;&nbsp;&nbsp; # Hour for daily maintenance (24-hour clock)
Maint_min:&nbsp;&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp; # Minute for daily maintenance
Retry_Mode:&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp; # If NZ, use progressive backoff for queue retries
Local_DSNs:&nbsp;&nbsp;&nbsp; 1&nbsp;&nbsp;&nbsp; # If NZ generate Delivery Status for local users only
DSN_time1:&nbsp;&nbsp;&nbsp;&nbsp; 10800&nbsp;&nbsp;&nbsp; # Seconds deferred before first DSN is sent
DSN_time2:&nbsp;&nbsp;&nbsp;&nbsp; 86400&nbsp;&nbsp;&nbsp; # Seconds deferred before second DSN is sent
DSN_time3:&nbsp;&nbsp;&nbsp;&nbsp; 259200&nbsp;&nbsp;&nbsp; # Seconds deferred before third DSN is sent
Host_in_title: 0&nbsp;&nbsp;&nbsp; # If NZ, show hostname in system tray and taskbar
Lingering:&nbsp;&nbsp;&nbsp;&nbsp; 0&nbsp;&nbsp;&nbsp; # Enable or disable 'lingering mailboxes'
Linger_Timeout: 60&nbsp;&nbsp; # Seconds before a lingering mailbox is shut down
Alert_Host:&nbsp;&nbsp;&nbsp; notify.pmail.com&nbsp;&nbsp;&nbsp; # Host to check for licensee advisories
Alert_Interval: 720&nbsp;&nbsp; # Frequency in minutes (min 240) for checks
Alert_Flags:&nbsp;&nbsp; 3&nbsp;&nbsp;&nbsp; # Flags controlling advisory checks</P>
<P>[MercuryC]
Poll : 30
ReturnLines : 15
Timeout : 30
ESMTP : 1
POP3_Auth : 0
Log_Verbose : 0
Session_logmode : 0</P>
<P>[MercuryE]
Poll : 15
Timeout : 60
logfile : C:\MERCURY\Logs\MercuryE\~y-~m-~d.log&nbsp;&nbsp; # Traffic logging file
Session_logging : C:\MERCURY\Sessions\MercuryE\&nbsp;&nbsp; # Directory for session log files
Session_logmode : 0
# Nameservers : 139.80.64.1</P>
<P>[MercuryD]
Session_logging : C:\MERCURY\Sessions\MercuryD\&nbsp;&nbsp;&nbsp; # Directory for session log files
Session_logmode : 0
# Timeout : 30
# Poll : 120&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; # How often to check hosts for new mail (seconds)</P>
<P>[MercuryS]
Debug : 1
Timeout : 30
Relay : 1
Strict_Relay : 0
Allow_Illegals : 1
Session_logmode : 0
SSL_Mode : 0
No_VRFY : 0
SMTP_ConnFlags : 0</P>
<P>[MercuryP]
Stack : 32768
Mark_Read : 1
SSL_Mode : 0
Login_Disabled : 0
UIDL_nul_list : 1
New_UIDs : 1
Session_logmode : 0
Timeout : 60</P>
<P>[MercuryX]
Drain_queues: 1
# Cmd_Delay: 10
# Cmd_Wait: 1
# IE4_Dialling: 0
# Use_ETRN: 1
# Clients_only: 1
# Saturday: 1031,1035,2,45,-1,0</P>
<P># [Groups]
# testgroup&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; :&nbsp;&nbsp;&nbsp;&nbsp; TESTGRP</P>
<P>[Domains]
10: 10
10: 10.2.13.96</P>
<P>[Maiser]
Maiser:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Maiser&nbsp;&nbsp; # 'Username' of mail server account
Helpfile:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; C:\MERCURY\Mercury\MAISER.HLP&nbsp;&nbsp; # Help sent on failed maiser requests
Lookupfile:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; C:\MERCURY\Mercury\MAISER.LKP&nbsp;&nbsp; # Format file for the 'lookup' command
Send_dir:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; C:\MERCURY\Mercury\SENDABLE&nbsp;&nbsp; # Directory for the 'send' command
Logfile:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; C:\MERCURY\Logs\Maiser\~y-~m-~d.LOG&nbsp;&nbsp; # Mail server log file
Notify:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; C:\MERCURY\Mercury\TMP&nbsp;&nbsp; # Dir. for pending 'notify' commands
NoList:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; N&nbsp;&nbsp; # If 'Y', disable the 'list' command
Local_only:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Y&nbsp;&nbsp; # If 'Y', local 'notify' commands only</P>
<P>[MercuryH]
logfile : C:\MERCURY\Logs\MercuryH\~y-~m-~d.log&nbsp;&nbsp; # Traffic logging file
# Addressbook : <A href="file://clio/SYS/SYSTEM/MERCURY/PH.PMR">\\CLIO\SYS\SYSTEM\MERCURY\PH.PMR</A>
# MOTD : <A href="file://clio/SYS/SYSTEM/MERCURY/PH-MOTD.TXT">\\CLIO\SYS\SYSTEM\MERCURY\PH-MOTD.TXT</A>
# Administrator : <A href="mailto:postmaster@clio.pmail.gen.nz">postmaster@clio.pmail.gen.nz</A>
Timeout : 30</P>
<P>[MercuryI]
logfile : C:\MERCURY\Logs\MercuryI\~y-~m-~d.log&nbsp;&nbsp; # Traffic logging file
Session_logging : C:\MERCURY\Sessions\MercuryI\&nbsp;&nbsp; # Directory for session log files
Session_logmode : 0
Timeout : 120
Server_Port : 143
Idle_Timeout : 1800</P>
<P>[MercuryB]
logfile : C:\MERCURY\Logs\MercuryB\~y-~m-~d.log&nbsp;&nbsp; # Traffic logging file
Session_logging : C:\MERCURY\Sessions\MercuryB\&nbsp;&nbsp; # Directory for session log files
Session_logmode : 0
Timeout : 120
Server_Port : 80
Idle_Timeout : 1800
# URL_Base : enter_your_domain_here</P>
<P>[Groups]</P>
<P>[Rewrite]</P>
<P>[Statistics]
StatFlags:&nbsp;&nbsp;&nbsp; 0&nbsp; # Statistical reporting settings
STF_Hours:&nbsp;&nbsp;&nbsp; 24&nbsp; # How often to write stat log files
STM_Hours:&nbsp;&nbsp;&nbsp; 24&nbsp; # How often to e-mail stat log files</P>
