Why not use Mercury help (or check the PDF manual) instead of searching the Internet, it's more efficient! ;)
First make sure the local domains part of Core configuration is correct. If users should be allowed to send messages to non-local recipients you should add the IP range of the LAN in MercuryS configuration, Connection control and allow relaying for that range. Verify that the ports for the email protocols you use (SMTP, POP3, IMAP...) are not blocked by firewall software on the server.
If you still can't get it to work please post your mercury.ini file here so we can check it!
<p>Why not use Mercury help (or check the PDF manual) instead of searching the Internet, it's more efficient! ;)</p><p>First make sure the local domains part of Core configuration is correct. If users should be allowed to send messages to non-local recipients you should add the IP range of the LAN in MercuryS configuration, Connection control and allow relaying for that range. Verify that the ports for the email protocols you use (SMTP, POP3, IMAP...) are not blocked by firewall software on the server.</p><p>If you still can't get it to work please post your mercury.ini file here so we can check it!</p><p>/Rolf
