This might help find out more. I used a text editor to search for all lines that begin with ": >> " to pick out commands sent from TB to Mercury and out of the nearly 500000 lines I got the following 117 lines. It appears to me that the deleted message when it reappears in the inbox is coming back with a different UID. I realize that this is just one direction, but was easy to filter out of the whole mess. The number in the first column is the line number that this response was found at, inserted by the editor. If we need to see the response to any of these let me know and I will find it in the log file and post here. The authenticate line is deliberately altered.
4 13:09:03.156: >> 1 capability<cr><lf>
7 13:09:03.218: >> 2 authenticate plain<cr><lf>
9 13:09:03.234: >> ******************************<cr><lf>
11 13:09:03.359: >> 3 lsub "" "*"<cr><lf>
15 13:09:03.390: >> 4 list "" "INBOX"<cr><lf>
18 13:09:03.406: >> 5 list "" "Trash"<cr><lf>
21 13:09:03.421: >> 6 create "Trash"<cr><lf>
23 13:09:03.437: >> 7 select "Trash"<cr><lf>
31 13:09:03.468: >> 8 UID fetch 1:* (FLAGS)<cr><lf>
233 13:09:03.640: >> 9 select "INBOX"<cr><lf>
241 13:09:03.671: >> 10 UID fetch 1:* (FLAGS)<cr><lf>
337 13:09:03.703: >> 11 UID fetch 353:361,363:771 (UID RFC822.SIZE FLAGS BODY.PEEK[HEADER.FIELDS (From To Cc Bcc Subject Date Message-ID Priority X-Priority References Newsgroups In-Reply-To Content-Type)])<cr><lf>
884 13:09:04.031: >> 12 UID fetch 652,691,695,703,710,734,771 (UID RFC822.SIZE BODY.PEEK[])<cr><lf>
1959 13:09:04.250: >> 13 UID fetch 617,624,628,635,638,644,653,661,665,668,671,674,771 (UID BODY.PEEK[HEADER.FIELDS (Content-Type Content-Transfer-Encoding)] BODY.PEEK[TEXT]<0.2048>)<cr><lf>
2768 13:09:04.640: >> 14 UID fetch 617 (UID BODY.PEEK[HEADER.FIELDS (Content-Type Content-Transfer-Encoding)] BODY.PEEK[TEXT]<0.2048>)<cr><lf>
2848 13:09:10.218: >> 15 noop<cr><lf>
2850 13:09:10.234: >> 16 UID fetch 772:* (FLAGS)<cr><lf>
2852 13:09:22.750: >> 17 UID fetch 353 (BODYSTRUCTURE)<cr><lf>
2856 13:09:22.781: >> 18 UID fetch 353 (BODY.PEEK[HEADER] BODY.PEEK[1.MIME] BODY.PEEK[1.1.MIME] BODY.PEEK[1.2.MIME] BODY.PEEK[2.MIME])<cr><lf>
2907 13:09:23.875: >> 19 UID fetch 353 (BODY.PEEK[1.1])<cr><lf>
2917 13:09:23.906: >> 20 UID fetch 353 (BODY.PEEK[1.2])<cr><lf>
2981 13:09:26.015: >> 21 UID fetch 363 (BODYSTRUCTURE)<cr><lf>
2985 13:09:26.031: >> 22 UID fetch 363 (BODY.PEEK[HEADER] BODY.PEEK[1.MIME] BODY.PEEK[2.MIME] BODY.PEEK[3.MIME])<cr><lf>
3020 13:09:26.078: >> 23 UID fetch 363 (BODY.PEEK[1])<cr><lf>
3038 13:09:26.109: >> 24 UID fetch 363 (BODY.PEEK[2])<cr><lf>
3054 13:09:34.328: >> 25 UID fetch 353 (BODY.PEEK[1.1])<cr><lf>
3064 13:09:34.359: >> 26 UID fetch 353 (BODY.PEEK[1.2])<cr><lf>
3128 13:09:41.062: >> 27 uid store 353:361,363:621,625,635,642,650,660:661,665:666,668:671 +Flags (\Seen)<cr><lf>
3154 13:09:43.328: >> 28 UID fetch 674 (BODYSTRUCTURE)<cr><lf>
3158 13:09:43.359: >> 29 UID fetch 674 (BODY.PEEK[HEADER] BODY.PEEK[1.MIME] BODY.PEEK[1.1.MIME] BODY.PEEK[1.2.MIME] BODY.PEEK[2.MIME])<cr><lf>
3212 13:09:43.453: >> 30 UID fetch 674 (BODY.PEEK[1.1])<cr><lf>
3291 13:09:43.500: >> 31 UID fetch 674 (BODY.PEEK[1.2])<cr><lf>
3391 13:09:43.625: >> 33 uid copy 353:361,363:621,625,635,642,650,660:661,665:666,668:671 "Trash"<cr><lf>
3393 13:09:44.703: >> 34 uid store 353:361,363:621,625,635,642,650,660:661,665:666,668:671 +FLAGS (\Deleted \Seen)<cr><lf>
3419 13:09:47.000: >> 35 uid store 674 +Flags (\Seen)<cr><lf>
3422 13:09:47.093: >> 36 noop<cr><lf>
3424 13:09:47.109: >> 37 UID fetch 772:* (FLAGS)<cr><lf>
3426 13:09:50.890: >> 38 select "Trash"<cr><lf>
3434 13:09:50.953: >> 39 UID fetch 1:* (FLAGS)<cr><lf>
3684 13:09:50.046: >> 40 UID fetch 762:785 (UID RFC822.SIZE FLAGS BODY.PEEK[HEADER.FIELDS (From To Cc Bcc Subject Date Message-ID Priority X-Priority References Newsgroups In-Reply-To Content-Type)])<cr><lf>
3962 13:09:50.250: >> 41 UID fetch 776,781 (UID RFC822.SIZE BODY.PEEK[])<cr><lf>
4321 13:09:53.062: >> 42 select "INBOX"<cr><lf>
4329 13:09:53.187: >> 43 UID fetch 1:* (FLAGS)<cr><lf>
4425 13:09:53.218: >> 44 UID fetch 772:781 (UID RFC822.SIZE FLAGS BODY.PEEK[HEADER.FIELDS (From To Cc Bcc Subject Date Message-ID Priority X-Priority References Newsgroups In-Reply-To Content-Type)])<cr><lf>
4530 13:09:53.328: >> 45 UID fetch 631 (UID RFC822.SIZE BODY.PEEK[])<cr><lf>
4813 13:09:53.390: >> 46 UID fetch 674 (BODY.PEEK[1.1])<cr><lf>
4892 13:09:53.437: >> 47 UID fetch 674 (BODY.PEEK[1.2])<cr><lf>
4992 13:10:23.781: >> 48 select "Trash"<cr><lf>
5000 13:10:24.828: >> 49 UID fetch 1:* (FLAGS)<cr><lf>
5250 13:10:24.906: >> 50 UID fetch 772,774:775 (UID RFC822.SIZE BODY.PEEK[])<cr><lf>
6329 13:10:24.109: >> 51 UID fetch 773,779 (UID RFC822.SIZE BODY.PEEK[])<cr><lf>
7301 13:10:24.296: >> 52 STATUS "Drafts" (UIDNEXT MESSAGES UNSEEN RECENT)<cr><lf>
7304 13:10:24.312: >> 53 UID fetch 782,784:785 (UID RFC822.SIZE BODY.PEEK[])<cr><lf>
8003 13:10:24.437: >> 54 UID fetch 771 (UID RFC822.SIZE BODY.PEEK[])<cr><lf>
8743 13:10:24.671: >> 55 STATUS "Sent" (UIDNEXT MESSAGES UNSEEN RECENT)<cr><lf>
8746 13:10:24.687: >> 56 UID fetch 763,767,769:770 (UID RFC822.SIZE BODY.PEEK[])<cr><lf>
9128 13:10:24.781: >> 57 select "Sent"<cr><lf>
9136 13:10:25.843: >> 58 UID fetch 1:* (FLAGS)<cr><lf>
9502 13:10:25.937: >> 59 UID fetch 2:4,68:72,134:135,140,149,176 (UID RFC822.SIZE FLAGS BODY.PEEK[HEADER.FIELDS (From To Cc Bcc Subject Date Message-ID Priority X-Priority References Newsgroups In-Reply-To Content-Type)])<cr><lf>
9629 13:10:25.031: >> 60 select "Trash"<cr><lf>
9637 13:10:25.093: >> 61 UID fetch 1:* (FLAGS)<cr><lf>
9887 13:10:25.187: >> 62 UID fetch 765 (UID RFC822.SIZE BODY.PEEK[])<cr><lf>
11960 13:10:25.531: >> 63 UID fetch 764 (UID RFC822.SIZE BODY.PEEK[])<cr><lf>
14182 13:10:26.921: >> 64 UID fetch 762 (UID RFC822.SIZE BODY.PEEK[])<cr><lf>
16325 13:10:26.484: >> 65 UID fetch 778 (UID RFC822.SIZE BODY.PEEK[])<cr><lf>
18730 13:10:27.890: >> 66 UID fetch 777 (UID RFC822.SIZE BODY.PEEK[])<cr><lf>
21255 13:10:27.343: >> 67 UID fetch 783 (UID RFC822.SIZE BODY.PEEK[])<cr><lf>
31253 13:10:29.421: >> 68 UID fetch 780 (UID RFC822.SIZE BODY.PEEK[])<cr><lf>
42902 13:10:31.718: >> 69 UID fetch 766 (UID RFC822.SIZE BODY.PEEK[])<cr><lf>
55718 13:10:34.421: >> 70 UID fetch 768 (UID RFC822.SIZE BODY.PEEK[])<cr><lf>
76677 13:10:58.984: >> 71 select "INBOX"<cr><lf>
76685 13:10:58.078: >> 72 UID fetch 1:* (FLAGS)<cr><lf>
76781 13:10:58.156: >> 73 UID fetch 663,675 (UID RFC822.SIZE BODY.PEEK[])<cr><lf>
77698 13:10:58.359: >> 74 UID fetch 628,630,637,673 (UID RFC822.SIZE BODY.PEEK[])<cr><lf>
79023 13:10:58.609: >> 75 STATUS "Trash" (UIDNEXT MESSAGES UNSEEN RECENT)<cr><lf>
79026 13:10:58.625: >> 76 UID fetch 638,644,653 (UID RFC822.SIZE BODY.PEEK[])<cr><lf>
79457 13:10:58.734: >> 77 UID fetch 781 (UID RFC822.SIZE BODY.PEEK[])<cr><lf>
80197 13:10:59.921: >> 78 UID fetch 772,775:776,778 (UID RFC822.SIZE BODY.PEEK[])<cr><lf>
80579 13:10:59.031: >> 79 UID fetch 715 (UID RFC822.SIZE BODY.PEEK[])<cr><lf>
83083 13:10:59.562: >> 80 UID fetch 761 (UID RFC822.SIZE BODY.PEEK[])<cr><lf>
84841 13:11:00.921: >> 81 UID fetch 773 (UID RFC822.SIZE BODY.PEEK[])<cr><lf>
86914 13:11:00.421: >> 82 UID fetch 780 (UID RFC822.SIZE BODY.PEEK[])<cr><lf>
89136 13:11:01.937: >> 83 UID fetch 777 (UID RFC822.SIZE BODY.PEEK[])<cr><lf>
91279 13:11:01.531: >> 84 UID fetch 674 (UID RFC822.SIZE BODY.PEEK[])<cr><lf>
93787 13:11:02.093: >> 85 UID fetch 624 (UID RFC822.SIZE BODY.PEEK[])<cr><lf>
96888 13:11:03.046: >> 86 UID fetch 662 (UID RFC822.SIZE BODY.PEEK[])<cr><lf>
107987 13:11:05.796: >> 87 UID fetch 779 (UID RFC822.SIZE BODY.PEEK[])<cr><lf>
120803 13:11:08.796: >> 88 UID fetch 626 (UID RFC822.SIZE BODY.PEEK[])<cr><lf>
135110 13:11:11.671: >> 89 UID fetch 774 (UID RFC822.SIZE BODY.PEEK[])<cr><lf>
156069 13:11:16.203: >> 90 select "Sent"<cr><lf>
156077 13:11:16.265: >> 91 UID fetch 1:* (FLAGS)<cr><lf>
156443 13:11:16.375: >> 92 UID fetch 140 (UID RFC822.SIZE BODY.PEEK[])<cr><lf>
167103 13:11:18.656: >> 93 UID fetch 2 (UID RFC822.SIZE BODY.PEEK[])<cr><lf>
179747 13:11:21.250: >> 94 UID fetch 149 (UID RFC822.SIZE BODY.PEEK[])<cr><lf>
199677 13:11:26.937: >> 95 UID fetch 71 (UID RFC822.SIZE BODY.PEEK[])<cr><lf>
221209 13:11:31.000: >> 96 UID fetch 134 (UID RFC822.SIZE BODY.PEEK[])<cr><lf>
243362 13:11:36.421: >> 97 UID fetch 72 (UID RFC822.SIZE BODY.PEEK[])<cr><lf>
266859 13:11:42.984: >> 98 UID fetch 68 (UID RFC822.SIZE BODY.PEEK[])<cr><lf>
292151 13:11:48.828: >> 99 UID fetch 69 (UID RFC822.SIZE BODY.PEEK[])<cr><lf>
317443 13:11:53.765: >> 100 UID fetch 70 (UID RFC822.SIZE BODY.PEEK[])<cr><lf>
344362 13:12:00.062: >> 101 UID fetch 135 (UID RFC822.SIZE BODY.PEEK[])<cr><lf>
382777 13:12:09.203: >> 102 UID fetch 176 (UID RFC822.SIZE BODY.PEEK[])<cr><lf>
425221 13:12:19.421: >> 103 UID fetch 4 (UID RFC822.SIZE BODY.PEEK[])<cr><lf>
491346 13:13:25.000: >> 104 STATUS "INBOX" (UIDNEXT MESSAGES UNSEEN RECENT)<cr><lf>
491349 13:13:25.046: >> 105 select "INBOX"<cr><lf>
491357 13:13:25.125: >> 106 UID fetch 1:* (FLAGS)<cr><lf>
491453 13:13:42.515: >> 107 expunge<cr><lf>
491469 13:13:42.546: >> 108 UID fetch 782:* (FLAGS)<cr><lf>
491471 13:13:42.640: >> 109 close<cr><lf>
491473 13:13:42.656: >> 110 logout<cr><lf>
<p>This might help find out more.&nbsp; I used a text editor to search for all lines that begin with ": &gt;&gt; " to pick out commands sent from TB to Mercury and out of the nearly 500000 lines I got the following 117 lines.&nbsp; It appears to me that the deleted message when&nbsp; it reappears in the inbox is coming back with a different UID.&nbsp; I realize that this is just one direction, but was easy to filter out of the whole mess.&nbsp; The number in the first column is the line number that this response was found at, inserted by the editor.&nbsp; If we need to see the response to any of these let me know and I will find it in the log file and post here.&nbsp; The authenticate line is deliberately altered.
</p><p>4&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:09:03.156: &gt;&gt; 1 capability&lt;cr&gt;&lt;lf&gt;
7&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:09:03.218: &gt;&gt; 2 authenticate plain&lt;cr&gt;&lt;lf&gt;
9&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:09:03.234: &gt;&gt; ******************************&lt;cr&gt;&lt;lf&gt;
11&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:09:03.359: &gt;&gt; 3 lsub "" "*"&lt;cr&gt;&lt;lf&gt;
15&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:09:03.390: &gt;&gt; 4 list "" "INBOX"&lt;cr&gt;&lt;lf&gt;
18&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:09:03.406: &gt;&gt; 5 list "" "Trash"&lt;cr&gt;&lt;lf&gt;
21&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:09:03.421: &gt;&gt; 6 create "Trash"&lt;cr&gt;&lt;lf&gt;
23&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:09:03.437: &gt;&gt; 7 select "Trash"&lt;cr&gt;&lt;lf&gt;
31&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:09:03.468: &gt;&gt; 8 UID fetch 1:* (FLAGS)&lt;cr&gt;&lt;lf&gt;
233&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:09:03.640: &gt;&gt; 9 select "INBOX"&lt;cr&gt;&lt;lf&gt;
241&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:09:03.671: &gt;&gt; 10 UID fetch 1:* (FLAGS)&lt;cr&gt;&lt;lf&gt;
337&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:09:03.703: &gt;&gt; 11 UID fetch 353:361,363:771 (UID RFC822.SIZE FLAGS BODY.PEEK[HEADER.FIELDS (From To Cc Bcc Subject Date Message-ID Priority X-Priority References Newsgroups In-Reply-To Content-Type)])&lt;cr&gt;&lt;lf&gt;
884&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:09:04.031: &gt;&gt; 12 UID fetch 652,691,695,703,710,734,771 (UID RFC822.SIZE BODY.PEEK[])&lt;cr&gt;&lt;lf&gt;
1959&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:09:04.250: &gt;&gt; 13 UID fetch 617,624,628,635,638,644,653,661,665,668,671,674,771 (UID BODY.PEEK[HEADER.FIELDS (Content-Type Content-Transfer-Encoding)] BODY.PEEK[TEXT]&lt;0.2048&gt;)&lt;cr&gt;&lt;lf&gt;
2768&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:09:04.640: &gt;&gt; 14 UID fetch 617 (UID BODY.PEEK[HEADER.FIELDS (Content-Type Content-Transfer-Encoding)] BODY.PEEK[TEXT]&lt;0.2048&gt;)&lt;cr&gt;&lt;lf&gt;
2848&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:09:10.218: &gt;&gt; 15 noop&lt;cr&gt;&lt;lf&gt;
2850&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:09:10.234: &gt;&gt; 16 UID fetch 772:* (FLAGS)&lt;cr&gt;&lt;lf&gt;
2852&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:09:22.750: &gt;&gt; 17 UID fetch 353 (BODYSTRUCTURE)&lt;cr&gt;&lt;lf&gt;
2856&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:09:22.781: &gt;&gt; 18 UID fetch 353 (BODY.PEEK[HEADER] BODY.PEEK[1.MIME] BODY.PEEK[1.1.MIME] BODY.PEEK[1.2.MIME] BODY.PEEK[2.MIME])&lt;cr&gt;&lt;lf&gt;
2907&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:09:23.875: &gt;&gt; 19 UID fetch 353 (BODY.PEEK[1.1])&lt;cr&gt;&lt;lf&gt;
2917&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:09:23.906: &gt;&gt; 20 UID fetch 353 (BODY.PEEK[1.2])&lt;cr&gt;&lt;lf&gt;
2981&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:09:26.015: &gt;&gt; 21 UID fetch 363 (BODYSTRUCTURE)&lt;cr&gt;&lt;lf&gt;
2985&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:09:26.031: &gt;&gt; 22 UID fetch 363 (BODY.PEEK[HEADER] BODY.PEEK[1.MIME] BODY.PEEK[2.MIME] BODY.PEEK[3.MIME])&lt;cr&gt;&lt;lf&gt;
3020&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:09:26.078: &gt;&gt; 23 UID fetch 363 (BODY.PEEK[1])&lt;cr&gt;&lt;lf&gt;
3038&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:09:26.109: &gt;&gt; 24 UID fetch 363 (BODY.PEEK[2])&lt;cr&gt;&lt;lf&gt;
3054&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:09:34.328: &gt;&gt; 25 UID fetch 353 (BODY.PEEK[1.1])&lt;cr&gt;&lt;lf&gt;
3064&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:09:34.359: &gt;&gt; 26 UID fetch 353 (BODY.PEEK[1.2])&lt;cr&gt;&lt;lf&gt;
3128&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:09:41.062: &gt;&gt; 27 uid store 353:361,363:621,625,635,642,650,660:661,665:666,668:671 +Flags (\Seen)&lt;cr&gt;&lt;lf&gt;
3154&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:09:43.328: &gt;&gt; 28 UID fetch 674 (BODYSTRUCTURE)&lt;cr&gt;&lt;lf&gt;
3158&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:09:43.359: &gt;&gt; 29 UID fetch 674 (BODY.PEEK[HEADER] BODY.PEEK[1.MIME] BODY.PEEK[1.1.MIME] BODY.PEEK[1.2.MIME] BODY.PEEK[2.MIME])&lt;cr&gt;&lt;lf&gt;
3212&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:09:43.453: &gt;&gt; 30 UID fetch 674 (BODY.PEEK[1.1])&lt;cr&gt;&lt;lf&gt;
3291&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:09:43.500: &gt;&gt; 31 UID fetch 674 (BODY.PEEK[1.2])&lt;cr&gt;&lt;lf&gt;
3391&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:09:43.625: &gt;&gt; 33 uid copy 353:361,363:621,625,635,642,650,660:661,665:666,668:671 "Trash"&lt;cr&gt;&lt;lf&gt;
3393&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:09:44.703: &gt;&gt; 34 uid store 353:361,363:621,625,635,642,650,660:661,665:666,668:671 +FLAGS (\Deleted \Seen)&lt;cr&gt;&lt;lf&gt;
3419&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:09:47.000: &gt;&gt; 35 uid store 674 +Flags (\Seen)&lt;cr&gt;&lt;lf&gt;
3422&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:09:47.093: &gt;&gt; 36 noop&lt;cr&gt;&lt;lf&gt;
3424&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:09:47.109: &gt;&gt; 37 UID fetch 772:* (FLAGS)&lt;cr&gt;&lt;lf&gt;
3426&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:09:50.890: &gt;&gt; 38 select "Trash"&lt;cr&gt;&lt;lf&gt;
3434&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:09:50.953: &gt;&gt; 39 UID fetch 1:* (FLAGS)&lt;cr&gt;&lt;lf&gt;
3684&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:09:50.046: &gt;&gt; 40 UID fetch 762:785 (UID RFC822.SIZE FLAGS BODY.PEEK[HEADER.FIELDS (From To Cc Bcc Subject Date Message-ID Priority X-Priority References Newsgroups In-Reply-To Content-Type)])&lt;cr&gt;&lt;lf&gt;
3962&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:09:50.250: &gt;&gt; 41 UID fetch 776,781 (UID RFC822.SIZE BODY.PEEK[])&lt;cr&gt;&lt;lf&gt;
4321&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:09:53.062: &gt;&gt; 42 select "INBOX"&lt;cr&gt;&lt;lf&gt;
4329&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:09:53.187: &gt;&gt; 43 UID fetch 1:* (FLAGS)&lt;cr&gt;&lt;lf&gt;
4425&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:09:53.218: &gt;&gt; 44 UID fetch 772:781 (UID RFC822.SIZE FLAGS BODY.PEEK[HEADER.FIELDS (From To Cc Bcc Subject Date Message-ID Priority X-Priority References Newsgroups In-Reply-To Content-Type)])&lt;cr&gt;&lt;lf&gt;
4530&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:09:53.328: &gt;&gt; 45 UID fetch 631 (UID RFC822.SIZE BODY.PEEK[])&lt;cr&gt;&lt;lf&gt;
4813&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:09:53.390: &gt;&gt; 46 UID fetch 674 (BODY.PEEK[1.1])&lt;cr&gt;&lt;lf&gt;
4892&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:09:53.437: &gt;&gt; 47 UID fetch 674 (BODY.PEEK[1.2])&lt;cr&gt;&lt;lf&gt;
4992&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:10:23.781: &gt;&gt; 48 select "Trash"&lt;cr&gt;&lt;lf&gt;
5000&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:10:24.828: &gt;&gt; 49 UID fetch 1:* (FLAGS)&lt;cr&gt;&lt;lf&gt;
5250&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:10:24.906: &gt;&gt; 50 UID fetch 772,774:775 (UID RFC822.SIZE BODY.PEEK[])&lt;cr&gt;&lt;lf&gt;
6329&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:10:24.109: &gt;&gt; 51 UID fetch 773,779 (UID RFC822.SIZE BODY.PEEK[])&lt;cr&gt;&lt;lf&gt;
7301&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:10:24.296: &gt;&gt; 52 STATUS "Drafts" (UIDNEXT MESSAGES UNSEEN RECENT)&lt;cr&gt;&lt;lf&gt;
7304&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:10:24.312: &gt;&gt; 53 UID fetch 782,784:785 (UID RFC822.SIZE BODY.PEEK[])&lt;cr&gt;&lt;lf&gt;
8003&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:10:24.437: &gt;&gt; 54 UID fetch 771 (UID RFC822.SIZE BODY.PEEK[])&lt;cr&gt;&lt;lf&gt;
8743&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:10:24.671: &gt;&gt; 55 STATUS "Sent" (UIDNEXT MESSAGES UNSEEN RECENT)&lt;cr&gt;&lt;lf&gt;
8746&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:10:24.687: &gt;&gt; 56 UID fetch 763,767,769:770 (UID RFC822.SIZE BODY.PEEK[])&lt;cr&gt;&lt;lf&gt;
9128&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:10:24.781: &gt;&gt; 57 select "Sent"&lt;cr&gt;&lt;lf&gt;
9136&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:10:25.843: &gt;&gt; 58 UID fetch 1:* (FLAGS)&lt;cr&gt;&lt;lf&gt;
9502&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:10:25.937: &gt;&gt; 59 UID fetch 2:4,68:72,134:135,140,149,176 (UID RFC822.SIZE FLAGS BODY.PEEK[HEADER.FIELDS (From To Cc Bcc Subject Date Message-ID Priority X-Priority References Newsgroups In-Reply-To Content-Type)])&lt;cr&gt;&lt;lf&gt;
9629&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:10:25.031: &gt;&gt; 60 select "Trash"&lt;cr&gt;&lt;lf&gt;
9637&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:10:25.093: &gt;&gt; 61 UID fetch 1:* (FLAGS)&lt;cr&gt;&lt;lf&gt;
9887&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:10:25.187: &gt;&gt; 62 UID fetch 765 (UID RFC822.SIZE BODY.PEEK[])&lt;cr&gt;&lt;lf&gt;
11960&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:10:25.531: &gt;&gt; 63 UID fetch 764 (UID RFC822.SIZE BODY.PEEK[])&lt;cr&gt;&lt;lf&gt;
14182&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:10:26.921: &gt;&gt; 64 UID fetch 762 (UID RFC822.SIZE BODY.PEEK[])&lt;cr&gt;&lt;lf&gt;
16325&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:10:26.484: &gt;&gt; 65 UID fetch 778 (UID RFC822.SIZE BODY.PEEK[])&lt;cr&gt;&lt;lf&gt;
18730&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:10:27.890: &gt;&gt; 66 UID fetch 777 (UID RFC822.SIZE BODY.PEEK[])&lt;cr&gt;&lt;lf&gt;
21255&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:10:27.343: &gt;&gt; 67 UID fetch 783 (UID RFC822.SIZE BODY.PEEK[])&lt;cr&gt;&lt;lf&gt;
31253&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:10:29.421: &gt;&gt; 68 UID fetch 780 (UID RFC822.SIZE BODY.PEEK[])&lt;cr&gt;&lt;lf&gt;
42902&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:10:31.718: &gt;&gt; 69 UID fetch 766 (UID RFC822.SIZE BODY.PEEK[])&lt;cr&gt;&lt;lf&gt;
55718&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:10:34.421: &gt;&gt; 70 UID fetch 768 (UID RFC822.SIZE BODY.PEEK[])&lt;cr&gt;&lt;lf&gt;
76677&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:10:58.984: &gt;&gt; 71 select "INBOX"&lt;cr&gt;&lt;lf&gt;
76685&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:10:58.078: &gt;&gt; 72 UID fetch 1:* (FLAGS)&lt;cr&gt;&lt;lf&gt;
76781&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:10:58.156: &gt;&gt; 73 UID fetch 663,675 (UID RFC822.SIZE BODY.PEEK[])&lt;cr&gt;&lt;lf&gt;
77698&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:10:58.359: &gt;&gt; 74 UID fetch 628,630,637,673 (UID RFC822.SIZE BODY.PEEK[])&lt;cr&gt;&lt;lf&gt;
79023&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:10:58.609: &gt;&gt; 75 STATUS "Trash" (UIDNEXT MESSAGES UNSEEN RECENT)&lt;cr&gt;&lt;lf&gt;
79026&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:10:58.625: &gt;&gt; 76 UID fetch 638,644,653 (UID RFC822.SIZE BODY.PEEK[])&lt;cr&gt;&lt;lf&gt;
79457&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:10:58.734: &gt;&gt; 77 UID fetch 781 (UID RFC822.SIZE BODY.PEEK[])&lt;cr&gt;&lt;lf&gt;
80197&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:10:59.921: &gt;&gt; 78 UID fetch 772,775:776,778 (UID RFC822.SIZE BODY.PEEK[])&lt;cr&gt;&lt;lf&gt;
80579&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:10:59.031: &gt;&gt; 79 UID fetch 715 (UID RFC822.SIZE BODY.PEEK[])&lt;cr&gt;&lt;lf&gt;
83083&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:10:59.562: &gt;&gt; 80 UID fetch 761 (UID RFC822.SIZE BODY.PEEK[])&lt;cr&gt;&lt;lf&gt;
84841&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:11:00.921: &gt;&gt; 81 UID fetch 773 (UID RFC822.SIZE BODY.PEEK[])&lt;cr&gt;&lt;lf&gt;
86914&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:11:00.421: &gt;&gt; 82 UID fetch 780 (UID RFC822.SIZE BODY.PEEK[])&lt;cr&gt;&lt;lf&gt;
89136&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:11:01.937: &gt;&gt; 83 UID fetch 777 (UID RFC822.SIZE BODY.PEEK[])&lt;cr&gt;&lt;lf&gt;
91279&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:11:01.531: &gt;&gt; 84 UID fetch 674 (UID RFC822.SIZE BODY.PEEK[])&lt;cr&gt;&lt;lf&gt;
93787&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:11:02.093: &gt;&gt; 85 UID fetch 624 (UID RFC822.SIZE BODY.PEEK[])&lt;cr&gt;&lt;lf&gt;
96888&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; 13:11:03.046: &gt;&gt; 86 UID fetch 662 (UID RFC822.SIZE BODY.PEEK[])&lt;cr&gt;&lt;lf&gt;
107987&nbsp;&nbsp;&nbsp;&nbsp; 13:11:05.796: &gt;&gt; 87 UID fetch 779 (UID RFC822.SIZE BODY.PEEK[])&lt;cr&gt;&lt;lf&gt;
120803&nbsp;&nbsp;&nbsp;&nbsp; 13:11:08.796: &gt;&gt; 88 UID fetch 626 (UID RFC822.SIZE BODY.PEEK[])&lt;cr&gt;&lt;lf&gt;
135110&nbsp;&nbsp;&nbsp;&nbsp; 13:11:11.671: &gt;&gt; 89 UID fetch 774 (UID RFC822.SIZE BODY.PEEK[])&lt;cr&gt;&lt;lf&gt;
156069&nbsp;&nbsp;&nbsp;&nbsp; 13:11:16.203: &gt;&gt; 90 select "Sent"&lt;cr&gt;&lt;lf&gt;
156077&nbsp;&nbsp;&nbsp;&nbsp; 13:11:16.265: &gt;&gt; 91 UID fetch 1:* (FLAGS)&lt;cr&gt;&lt;lf&gt;
156443&nbsp;&nbsp;&nbsp;&nbsp; 13:11:16.375: &gt;&gt; 92 UID fetch 140 (UID RFC822.SIZE BODY.PEEK[])&lt;cr&gt;&lt;lf&gt;
167103&nbsp;&nbsp;&nbsp;&nbsp; 13:11:18.656: &gt;&gt; 93 UID fetch 2 (UID RFC822.SIZE BODY.PEEK[])&lt;cr&gt;&lt;lf&gt;
179747&nbsp;&nbsp;&nbsp;&nbsp; 13:11:21.250: &gt;&gt; 94 UID fetch 149 (UID RFC822.SIZE BODY.PEEK[])&lt;cr&gt;&lt;lf&gt;
199677&nbsp;&nbsp;&nbsp;&nbsp; 13:11:26.937: &gt;&gt; 95 UID fetch 71 (UID RFC822.SIZE BODY.PEEK[])&lt;cr&gt;&lt;lf&gt;
221209&nbsp;&nbsp;&nbsp;&nbsp; 13:11:31.000: &gt;&gt; 96 UID fetch 134 (UID RFC822.SIZE BODY.PEEK[])&lt;cr&gt;&lt;lf&gt;
243362&nbsp;&nbsp;&nbsp;&nbsp; 13:11:36.421: &gt;&gt; 97 UID fetch 72 (UID RFC822.SIZE BODY.PEEK[])&lt;cr&gt;&lt;lf&gt;
266859&nbsp;&nbsp;&nbsp;&nbsp; 13:11:42.984: &gt;&gt; 98 UID fetch 68 (UID RFC822.SIZE BODY.PEEK[])&lt;cr&gt;&lt;lf&gt;
292151&nbsp;&nbsp;&nbsp;&nbsp; 13:11:48.828: &gt;&gt; 99 UID fetch 69 (UID RFC822.SIZE BODY.PEEK[])&lt;cr&gt;&lt;lf&gt;
317443&nbsp;&nbsp;&nbsp;&nbsp; 13:11:53.765: &gt;&gt; 100 UID fetch 70 (UID RFC822.SIZE BODY.PEEK[])&lt;cr&gt;&lt;lf&gt;
344362&nbsp;&nbsp;&nbsp;&nbsp; 13:12:00.062: &gt;&gt; 101 UID fetch 135 (UID RFC822.SIZE BODY.PEEK[])&lt;cr&gt;&lt;lf&gt;
382777&nbsp;&nbsp;&nbsp;&nbsp; 13:12:09.203: &gt;&gt; 102 UID fetch 176 (UID RFC822.SIZE BODY.PEEK[])&lt;cr&gt;&lt;lf&gt;
425221&nbsp;&nbsp;&nbsp;&nbsp; 13:12:19.421: &gt;&gt; 103 UID fetch 4 (UID RFC822.SIZE BODY.PEEK[])&lt;cr&gt;&lt;lf&gt;
491346&nbsp;&nbsp;&nbsp;&nbsp; 13:13:25.000: &gt;&gt; 104 STATUS "INBOX" (UIDNEXT MESSAGES UNSEEN RECENT)&lt;cr&gt;&lt;lf&gt;
491349&nbsp;&nbsp;&nbsp;&nbsp; 13:13:25.046: &gt;&gt; 105 select "INBOX"&lt;cr&gt;&lt;lf&gt;
491357&nbsp;&nbsp;&nbsp;&nbsp; 13:13:25.125: &gt;&gt; 106 UID fetch 1:* (FLAGS)&lt;cr&gt;&lt;lf&gt;
491453&nbsp;&nbsp;&nbsp;&nbsp; 13:13:42.515: &gt;&gt; 107 expunge&lt;cr&gt;&lt;lf&gt;
491469&nbsp;&nbsp;&nbsp;&nbsp; 13:13:42.546: &gt;&gt; 108 UID fetch 782:* (FLAGS)&lt;cr&gt;&lt;lf&gt;
491471&nbsp;&nbsp;&nbsp;&nbsp; 13:13:42.640: &gt;&gt; 109 close&lt;cr&gt;&lt;lf&gt;
491473&nbsp;&nbsp;&nbsp;&nbsp; 13:13:42.656: &gt;&gt; 110 logout&lt;cr&gt;&lt;lf&gt;
&nbsp;</p>
