Problem with Trend Micro Titanium
[quote user="sirob"]
I have been using Trend Micro Internet Security on 2 Win XP systems for many years with no problem.
I recently updated to Trend Micro Titanium and experienced severe problems with Pegasus. Trend Micro had no solution for me, so I was forced to uninstall and re-install Titanium, and re-install the previous version.
I am also running Titanium on a third system under Win 7. The only problem here is that when I delete a Pegasus message it takes about 4 seconds for the action to complete - is this normal?
AV programs have been know to cause problems with Pegasus Mail, some more than others.  Trend Micro Titanium may fall into the "more" category.  The rule of thumb is to exclude mailbox folders from active scanning because of conflicts that can occur when Pegasus Mail tries to access/process a file at the same time the AV scanner has a hold of it.  Deletes can cause a good bit of file activity in the mailbox folder so Trend Micro scanning could certainly be having an impact.
[quote user="sirob"]<p>I have been using Trend Micro Internet Security on 2 Win XP systems for many years with no problem.</p><p> I recently updated to Trend Micro Titanium and experienced severe problems with Pegasus. Trend Micro had no solution for me, so I was forced to uninstall and re-install Titanium, and re-install the previous version.</p><p> I am also running Titanium on a third system under Win 7. The only problem here is that when I delete a Pegasus message it takes about 4 seconds for the action to complete - is this normal? </p><p>[/quote]</p><p>AV programs have been know to cause problems with Pegasus Mail, some more than others.  Trend Micro Titanium may fall into the "more" category.  The rule of thumb is to exclude mailbox folders from active scanning because of conflicts that can occur when Pegasus Mail tries to access/process a file at the same time the AV scanner has a hold of it.  Deletes can cause a good bit of file activity in the mailbox folder so Trend Micro scanning could certainly be having an impact.      </p><p> </p>
