Hello
One of our staff has a long-standing issue with the Window menu in Pegasus Mail. He said (and showed me), that if he has several messages/folders open and wants to switch from one message/folder to another using the Window menu, the chosen message/folder is not brought to the front. He said Pegasus Mail has exhibited this behaviour for several years.
I tried this on my machine and found that Pegasus Mail behaves exactly the same way. I am unable to switch between windows. It is a feature I have never used before (weird, huh!)
We are able to use the WindowBar to switch between windows, so that works fine.
I have checked this on several machines and it is the same. However, bear in mind that we use a central installation of Pegasus Mail that all the desktops link to.
[Edit]
The top menu options work fine - cascade etc.
<P>Hello</P>
<P>One of our staff has a long-standing issue with the Window menu in Pegasus Mail. He said (and showed me),&nbsp;that if he has several messages/folders open and wants to switch from one message/folder to another using the Window menu, the chosen message/folder is not brought to the front. He said Pegasus Mail has exhibited this behaviour for several years.</P>
<P>I tried this on my machine and found that Pegasus Mail behaves exactly the same way. I am unable to switch between windows. It is a&nbsp;feature I have never used before (weird, huh!)</P>
<P>We are able to use the WindowBar to switch between windows, so that works fine.</P>
<P>I have checked this on several machines and it is the same. However, bear in mind that we use a central installation of Pegasus Mail that all the desktops link to.</P>
<P mce_keep="true">&nbsp;</P>
<P>[Edit]</P>
<P>The top menu options work fine - cascade etc.</P>
