Window Menu Does Not Work
Yes - and, OT, it can be frustrating watching people click a menu, then click an option when they can do it with one click or a keyboard command... bleugh!
Hello
One of our staff has a long-standing issue with the Window menu in Pegasus Mail. He said (and showed me), that if he has several messages/folders open and wants to switch from one message/folder to another using the Window menu, the chosen message/folder is not brought to the front. He said Pegasus Mail has exhibited this behaviour for several years.
I tried this on my machine and found that Pegasus Mail behaves exactly the same way. I am unable to switch between windows. It is a feature I have never used before (weird, huh!)
We are able to use the WindowBar to switch between windows, so that works fine.
I have checked this on several machines and it is the same. However, bear in mind that we use a central installation of Pegasus Mail that all the desktops link to.
[Edit]
The top menu options work fine - cascade etc.
<P>Hello</P> <P>One of our staff has a long-standing issue with the Window menu in Pegasus Mail. He said (and showed me), that if he has several messages/folders open and wants to switch from one message/folder to another using the Window menu, the chosen message/folder is not brought to the front. He said Pegasus Mail has exhibited this behaviour for several years.</P> <P>I tried this on my machine and found that Pegasus Mail behaves exactly the same way. I am unable to switch between windows. It is a feature I have never used before (weird, huh!)</P> <P>We are able to use the WindowBar to switch between windows, so that works fine.</P> <P>I have checked this on several machines and it is the same. However, bear in mind that we use a central installation of Pegasus Mail that all the desktops link to.</P> <P mce_keep="true"> </P> <P>[Edit]</P> <P>The top menu options work fine - cascade etc.</P> <P mce_keep="true"> </P>
[quote user="Greenman"]One of our staff has a long-standing issue with the Window menu in Pegasus Mail. He said (and showed me), that if he has several messages/folders open and wants to switch from one message/folder to another using the Window menu, the chosen message/folder is not brought to the front. He said Pegasus Mail has exhibited this behaviour for several years. [/quote]
This is a known issue if using an "invisible" extension such as any of my encryption extensions, MiniDump or IERenderer. The reason behind this is - according to David Harris - a bug in Windows' MDI window handling (MDI windows are the windows within Pegasus Mail which cannot be moved outside of it; "invisible" means the extension doesn't use an MDI window). I've developed a workaround for this issue which was broken for a couple of versions in MiniDump and IERenderer (due to code migration to a more recent - Unicode based - Delphi version) but will be back working with my next public IERenderer update.
<p>[quote user="Greenman"]One of our staff has a long-standing issue with the Window menu in Pegasus Mail. He said (and showed me), that if he has several messages/folders open and wants to switch from one message/folder to another using the Window menu, the chosen message/folder is not brought to the front. He said Pegasus Mail has exhibited this behaviour for several years. [/quote]</p><p>This is a known issue if using an "invisible" extension such as any of my encryption extensions, MiniDump or IERenderer. The reason behind this is - according to David Harris - a bug in Windows' MDI window handling (MDI windows are the windows within Pegasus Mail which cannot be moved outside of it; "invisible" means the extension doesn't use an MDI window). I've developed a workaround for this issue which was broken for a couple of versions in MiniDump and IERenderer (due to code migration to a more recent - Unicode based - Delphi version) but will be back working with my next public IERenderer update.</p>
Thanks, Michael.
Seriously, it's not a problem and using the WindowBar is a far better way of navigating the windows IMO. But, I guess some folks prefer the extra click will use the menu instead.
<p>Thanks, Michael.</p><p>Seriously, it's not a problem and using the WindowBar is a far better way of navigating the windows IMO. But, I guess some folks prefer the extra click will use the menu instead.</p>
[quote user="Greenman"]Seriously, it's not a problem and using the WindowBar is a far better way of navigating the windows IMO. But, I guess some folks prefer the extra click will use the menu instead.[/quote]
I use the button bar as well, but it's a matter of long-standing habits, I guess ...
<p>[quote user="Greenman"]Seriously, it's not a problem and using the WindowBar is a far better way of navigating the windows IMO. But, I guess some folks prefer the extra click will use the menu instead.[/quote]</p><p>I use the button bar as well, but it's a matter of long-standing habits, I guess ...</p>
