4.61 (minor) problems
A few problems with Pegasus 4.61 (because they are minor problems I put them in one posting):
  • the menu entry "Window" and the WindowBar present different lists. As of this version the menu entry apparently does not list open individual mails only folders
  • there is no "x"-button to close the queued mail folder (nor a "Window"->"Close" menu entry), but Ctrl-F4 works (same as in previous versions)
  • as far as I remember the previous version were satisfied to show new mail in "Folder - New mail" (when it was open?). This version insists to focus on "New mail folder"
  • in Folder-Preview mode one (at least I) cannot see which window is active: the selected folder and the selected mail are marked the same way. I would consider it helpful if the selection in the active window differed (same as in previous versions)
I don't know if the following is a good idea:
  • Allow in "Message properties" to change the date
Recently I had a mail with a date setting of 2005. I took a while to discover it in the New mail folder. To be able to find it in the Main folder I had to edit the new mail file manually.
Oskar
<p>A few problems with Pegasus 4.61 (because they are minor problems I put them in one posting): </p><ul><li>the menu entry "Window" and the WindowBar present different lists. As of this version the menu entry apparently does not list open individual mails only folders</li><li>there is no "x"-button to close the queued mail folder (nor a "Window"->"Close" menu entry), but Ctrl-F4 works (same as in previous versions)</li><li>as far as I remember the previous version were satisfied to show new mail in "Folder - New mail" (when it was open?). This version insists to focus on "New mail folder"</li><li>in Folder-Preview mode one (at least I) cannot see which window is active: the selected folder and the selected mail are marked the same way. I would consider it helpful if the selection in the active window differed (same as in previous versions)</li></ul><p> I don't know if the following is a good idea: </p><ul><li>Allow in "Message properties" to change the date</li></ul><p>Recently I had a mail with a date setting of 2005. I took a while to discover it in the New mail folder. To be able to find it in the Main folder I had to edit the new mail file manually.</p><p>Oskar </p><p> </p>
[quote user="vdhagen"]the menu entry "Window" and the WindowBar present different lists. As of this version the menu entry apparently does not list open individual mails only folders[/quote] It's actually a bit more complex (and David Harris cannot provide a solution), there will be a (fixed) work-around with an upcoming IERenderer update.
[quote user="vdhagen"]there is no "x"-button to close the queued mail folder (nor a "Window"->"Close" menu entry), but Ctrl-F4 works (same as in previous versions)[/quote] Don't use maximized (inner) windows and you'll not encounter this (IIRC David Harris doesn't know how to fix this): I'm using "pseudo-maximized windows", i.e. open each window as the only one in Pegasus Mail and click Window => Tile, then close it (provided you have Tools => Options => Basi settings => Save ... desktop state ... enabled).
[quote user="vdhagen"]as far as I remember the previous version were satisfied to show new mail in "Folder - New mail" (when it was open?). This version insists to focus on "New mail folder"[/quote] I don't think so ...
[quote user="vdhagen"]in Folder-Preview mode one (at least I) cannot see which window is active: the selected folder and the selected mail are marked the same way. I would consider it helpful if the selection in the active window differed (same as in previous versions)[/quote] I cannot duplicate this ...
<p>[quote user="vdhagen"]the menu entry "Window" and the WindowBar present different lists. As of this version the menu entry apparently does not list open individual mails only folders[/quote] It's actually a bit more complex (and David Harris cannot provide a solution), there will be a (fixed) work-around with an upcoming IERenderer update.</p><p>[quote user="vdhagen"]there is no "x"-button to close the queued mail folder (nor a "Window"->"Close" menu entry), but Ctrl-F4 works (same as in previous versions)[/quote] Don't use maximized (inner) windows and you'll not encounter this (IIRC David Harris doesn't know how to fix this): I'm using "pseudo-maximized windows", i.e. open each window as the only one in Pegasus Mail and click <em>Window => Tile</em>, then close it (provided you have <em>Tools => Options => Basi settings => Save ... desktop state ...</em> enabled).</p><p>[quote user="vdhagen"]as far as I remember the previous version were satisfied to show new mail in "Folder - New mail" (when it was open?). This version insists to focus on "New mail folder"[/quote] I don't think so ...</p><p>[quote user="vdhagen"]in Folder-Preview mode one (at least I) cannot see which window is active: the selected folder and the selected mail are marked the same way. I would consider it helpful if the selection in the active window differed (same as in previous versions)[/quote] I cannot duplicate this ...</p>
[quote user="idw"]
Thanks for the response. On the last point I was probably not precise enough. In "Folder preview" there are three subwindows. In each subwindow a selection is displayed white on black and I can't see which selection is "active"
Oskar
[quote user="idw"]<p>[quote user="vdhagen"]in Folder-Preview mode one (at least I) cannot see which window is active: the selected folder and the selected mail are marked the same way. I would consider it helpful if the selection in the active window differed (same as in previous versions)[/quote] I cannot duplicate this ...</p><p>[/quote]</p><p>Thanks for the response. On the last point I was probably not precise enough. In "Folder preview" there are three subwindows. In each subwindow a selection is displayed white on black and I can't see which selection is "active"</p><p>Oskar</p>
[quote user="vdhagen"]Thanks for the response. On the last point I was probably not precise enough. In "Folder preview" there are three subwindows. In each subwindow a selection is displayed white on black and I can't see which selection is "active"[/quote]
Enable Tools => Options => Basic settings => Use system-defined colours ... and you're done with it.
<p>[quote user="vdhagen"]Thanks for the response. On the last point I was probably not precise enough. In "Folder preview" there are three subwindows. In each subwindow a selection is displayed white on black and I can't see which selection is "active"[/quote]</p><p>Enable <em>Tools => Options => Basic settings => Use system-defined colours ...</em> and you're done with it.</p>
