The background to this is partially explained in an earlier thread I started concerned with SSL. I have started a new thread because this all refers to Thunderbird as the mail client. In summary, I want to to be able to use a Motorola Xoom tablet to access accounts on Mercury and also access these same accounts from several computer on my home LAN. To do this, I switched from using no authentication to SSL. As it is a one or the other situation for IMAP4 (no authentication or SSL, but not both), the computers on my home LAN also need to use SSL. I am using IMAP4.
What I don't know is whether the following issues are problems with Thunderbird (3.1.10) or with Mercury (still 4.72) or some combination.
I am currently having four issues showing up when I start Thunderbird:
1. A temporary pop-up message appears saying "The current operation on "Inbox" did not succeed. The mail server account [username] responded: Folder in use by other connections". This happens when one of the other computers on the LAN is also running Thunderbird and includes the same account [username]. I can see that there are sometimes issues when two computers are accessing the same mailbox, but I have never had a failure situation arise (e.g. when using Windows Live Mail or Outlook Express, with no authentication set up for clients or server). Despite this, I seem to be receiving mail in all of the user accounts. If no other computers on the LAN are running Thunderbird I don't see this pop-up message. The e-mail application (K9) on my Xoom can still be running and it doesn't cause the pop-up to appear.
2. A temporary pop-up message appears saying "The IMAP server [account name] does not support the selected authentication method. Please change the authenitcation method in the Account/Server settings".
3. On one of the LAN computers (my wife's, so I need to get this fixed!), some attached received pictures are not completely shown by Thunderbird. The top half of the picture is shown correctly, but the bottom half is just grey. This has only happened when pictures have been attached wich are large, e.g. ~1MB or more. Small pictures (<100KB) have never caused this problem so far. Also, when there are several attached pictures, I have only seen one of them with this problem. If I terminate Thunderbird and restart it, the pictures all show correctly. I have tried synchonization to only download headers or the whole message and this makes no difference.
4. In the Thunderbird error log, I am seeing:
mydomain.com : server does not support RFC 5746, see CVE-2009-3555 .
I have looked at the Mercury IMAP4 error logs (general and session) and I see the following:
General Logging (just a sample)
[Not-logged-in] at 192.168.1.1: 0 sec. elapsed, connection closed Thu Jun 16 06:03:19 2011
Connection from 192.168.1.1, Thu Jun 16 06:03:19 2011
Connection from 192.168.1.1, Thu Jun 16 06:04:12 2011
[Not-logged-in] at 192.168.1.1: 2 sec. elapsed, connection closed Thu Jun 16 06:04:14 2011
Connection from 192.168.1.1, Thu Jun 16 06:04:15 2011
Connection from 192.168.1.1, Thu Jun 16 06:10:12 2011
Connection from 192.168.1.1, Thu Jun 16 06:15:32 2011
Connection from 192.168.1.1, Thu Jun 16 06:35:48 2011
User2 at 192.168.1.1: 2120 sec. elapsed, connection closed Thu Jun 16 06:45:32 2011
User2 at 192.168.1.1: 1803 sec. elapsed, connection closed Thu Jun 16 06:45:35 2011
Connection from 192.168.1.1, Thu Jun 16 07:05:09 2011
User2 at 192.168.1.1: 1850 sec. elapsed, connection closed Thu Jun 16 07:06:38 2011
User2 at 192.168.1.1: 257 sec. elapsed, connection closed Thu Jun 16 07:09:26 2011
User2 at 192.168.1.1: 3911 sec. elapsed, connection closed Thu Jun 16 07:09:26 2011
Connection from 192.168.1.1, Thu Jun 16 07:10:48 2011
[Not-logged-in] at 192.168.1.1: 0 sec. elapsed, connection closed Thu Jun 16 07:10:48 2011
Session Logging (in file TCP0000)
05:07:53.187: Connection from 192.168.1.104, Wed Jun 08 05:07:53 2011<lf>
05:07:53.187: << * OK mydomain.com IMAP4rev1 Mercury/32 v4.62 server ready.<cr><lf>
05:07:53.187: >> xag1 CAPABILITY<cr><lf>
05:07:53.187: << * CAPABILITY IMAP4rev1 STARTTLS LOGINDISABLED X-MERCURY-1<cr><lf>
05:07:53.187: << xag1 OK CAPABILITY complete.<cr><lf>
05:07:53.187: >> 4ne8 LOGIN "account-name" "password"<cr><lf>
05:07:53.187: << 4ne8 NO LOGIN is not allowed unless STARTTLS has been issued.<cr><lf>
05:07:53.187: --- Connection closed normally at Wed Jun 08 05:07:53 2011. ---
05:07:53.187:
05:03:59.812: Connection from 192.168.1.1, Thu Jun 16 05:03:59 2011<lf>
05:03:59.812: << * OK mydomain.com IMAP4rev1 Mercury/32 v4.62 server ready.<cr><lf>
05:03:59.937: >> 1 CAPABILITY<cr><lf>
05:03:59.937: << * CAPABILITY IMAP4rev1 STARTTLS LOGINDISABLED X-MERCURY-1<cr><lf>
05:03:59.937: << 1 OK CAPABILITY complete.<cr><lf>
05:03:59.140: >> 2 STARTTLS<cr><lf>
05:03:59.140: << 2 OK Begin SSL/TLS negotiation now.<cr><lf>
05:04:00.906: 22: Error -41 activating SSL session (locus 0, type 0, code 0, 'No data was read because the remote syst')
05:04:00.906: --- Connection closed normally at Thu Jun 16 05:04:00 2011. ---
05:04:00.906:
I don't understand why there are two dates in this file, unless the file is re-used in some way. I think that the connection detail for Wed June 08 can be ignored, because I definitely had SSL incorrectly set-up at that time.
I have set up MercuryI to listen on Port 993; "Refuse access when no password is defined: is checked; Under the SSL tab, I have checked "Enable support for SSL/TLS secure connections" and "Disable plaintext logins for non-SSL connections". I generated a self-signed certificate and allowed this to be accepted by the clients on first connection.
In Thunderbird, for the server settings, I have defined Port 993, Connection Security as STARTTLS and Authentication method as "Normal password". (I wasn't sure about this, but using "Encrypted password" wouldn't work at all.
Any help on these issues would be much appreciated.
Thank you
Gordon
<p>The background to this is&nbsp;partially explained&nbsp;in an earlier thread I started concerned with SSL.&nbsp; I have started a new thread because this all refers to Thunderbird as the mail client.&nbsp; In summary, I want to to be able to use a Motorola Xoom tablet to access accounts on Mercury and also access these same accounts from several computer on my home LAN.&nbsp; To do this, I switched from using no authentication to SSL.&nbsp; As it is a one or the other situation for IMAP4&nbsp;(no authentication&nbsp;or SSL, but not both), the computers on my home LAN also need to use SSL.&nbsp; I am using IMAP4.</p><p>What I don't know is whether the following issues are problems with Thunderbird (3.1.10) or with Mercury (still 4.72) or some combination.</p><p>I am currently having four issues showing up when I start Thunderbird:</p><p>1. A temporary pop-up message appears saying "The current operation on "Inbox" did not succeed.&nbsp; The mail server account [username] responded: Folder in use by other connections".&nbsp; This happens when one of the other computers on the LAN is also running Thunderbird and includes the same account [username].&nbsp; I can see that there are sometimes issues when two computers are accessing the same mailbox, but I have never had a failure situation arise (e.g. when using Windows Live Mail or Outlook Express, with no authentication set up for clients or server).&nbsp; Despite this, I seem to be receiving mail in all of the user accounts.&nbsp; If no other computers on the LAN are running Thunderbird I don't see this pop-up message.&nbsp; The e-mail application (K9) on my Xoom can still be running and it doesn't cause the pop-up to appear.</p><p>2. A temporary pop-up message appears saying "The IMAP server [account name] does not support the selected authentication method.&nbsp; Please change the authenitcation method in the Account/Server settings".</p><p>3. On one of the LAN computers (my wife's, so I need to get this fixed!), some attached received pictures are not completely shown by Thunderbird.&nbsp; The top half of the picture is shown correctly, but the bottom half is just grey.&nbsp; This has only happened when pictures have been attached wich are large, e.g. ~1MB or more.&nbsp; Small pictures (&lt;100KB) have never caused this problem so far.&nbsp; Also, when there are several attached pictures, I have only seen one of them with this problem.&nbsp; If I terminate Thunderbird and restart it, the pictures all show correctly.&nbsp; I have tried&nbsp;synchonization to only download headers or the whole message and this makes no difference.</p><p>&nbsp;4.&nbsp; In&nbsp;the Thunderbird error log, I am seeing: </p><p>mydomain.com : server does not support RFC 5746, see CVE-2009-3555&nbsp;.</p><p mce_keep="true">&nbsp;</p><p>I have looked at the Mercury IMAP4 error logs (general and session) and I see the following:</p><p><b>General Logging (just a sample)</b></p><p>[Not-logged-in] at 192.168.1.1: 0 sec. elapsed, connection closed Thu Jun 16 06:03:19 2011
User2&nbsp;at 192.168.1.1: 1803 sec. elapsed, connection closed Thu Jun 16 06:45:35 2011
User2&nbsp;at 192.168.1.1: 1850 sec. elapsed, connection closed Thu Jun 16 07:06:38 2011
User2&nbsp;at 192.168.1.1: 257 sec. elapsed, connection closed Thu Jun 16 07:09:26 2011
User2&nbsp;at 192.168.1.1: 3911 sec. elapsed, connection closed Thu Jun 16 07:09:26 2011
Connection from 192.168.1.1, Thu Jun 16 07:10:48 2011</p><p><b>Session Logging (in file TCP0000)</b></p><p>05:07:53.187: Connection from 192.168.1.104, Wed Jun 08 05:07:53 2011&lt;lf&gt;
05:07:53.187: &lt;&lt; * OK mydomain.com IMAP4rev1 Mercury/32 v4.62 server ready.&lt;cr&gt;&lt;lf&gt;
05:07:53.187: &gt;&gt; xag1 CAPABILITY&lt;cr&gt;&lt;lf&gt;
05:07:53.187: &lt;&lt; * CAPABILITY IMAP4rev1 STARTTLS LOGINDISABLED X-MERCURY-1&lt;cr&gt;&lt;lf&gt;
05:07:53.187: &lt;&lt; xag1 OK CAPABILITY complete.&lt;cr&gt;&lt;lf&gt;
05:07:53.187: &gt;&gt; 4ne8 LOGIN "account-name" "password"&lt;cr&gt;&lt;lf&gt;
05:07:53.187: &lt;&lt; 4ne8 NO LOGIN is not allowed unless STARTTLS has been issued.&lt;cr&gt;&lt;lf&gt;
05:07:53.187:
05:03:59.812: Connection from 192.168.1.1, Thu Jun 16 05:03:59 2011&lt;lf&gt;
05:03:59.812: &lt;&lt; * OK mydomain.com IMAP4rev1 Mercury/32 v4.62 server ready.&lt;cr&gt;&lt;lf&gt;
05:03:59.937: &gt;&gt; 1 CAPABILITY&lt;cr&gt;&lt;lf&gt;
05:03:59.937: &lt;&lt; * CAPABILITY IMAP4rev1 STARTTLS LOGINDISABLED X-MERCURY-1&lt;cr&gt;&lt;lf&gt;
05:03:59.937: &lt;&lt; 1 OK CAPABILITY complete.&lt;cr&gt;&lt;lf&gt;
05:03:59.140: &gt;&gt; 2 STARTTLS&lt;cr&gt;&lt;lf&gt;
05:03:59.140: &lt;&lt; 2 OK Begin SSL/TLS negotiation now.&lt;cr&gt;&lt;lf&gt;
05:04:00.906: </p><p>I don't understand why there are two dates in this file, unless the file is re-used in some way.&nbsp; I think that the connection detail for Wed June 08 can be ignored, because I definitely had SSL incorrectly set-up at that time.</p><p>I have set up MercuryI&nbsp;to listen on&nbsp;Port 993; "Refuse access when no password is defined: is checked; Under the SSL tab, I have checked "Enable support for SSL/TLS secure connections" and&nbsp;"Disable plaintext logins for non-SSL connections".&nbsp; I generated a self-signed certificate and allowed this to be accepted by the clients on first connection.</p><p>In Thunderbird,&nbsp;for the server settings, I have defined Port 993, Connection Security as STARTTLS and Authentication method as "Normal password".&nbsp; (I wasn't sure about this, but using "Encrypted password" wouldn't work at all.</p><p>Any help on these issues would be much appreciated.</p><p>Thank you</p><p>Gordon</p><p mce_keep="true">&nbsp;</p><p mce_keep="true">&nbsp;</p>
