<!--[if gte mso 9]><xml>
</p><p> <w:WordDocument>
</p><p> <w:View>Normal</w:View>
</p><p> <w:Zoom>0</w:Zoom>
</p><p> <w:PunctuationKerning/>
</p><p> <w:ValidateAgainstSchemas/>
</p><p> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid>
</p><p> <w:IgnoreMixedContent>false</w:IgnoreMixedContent>
</p><p> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText>
</p><p> <w:Compatibility>
</p><p> <w:BreakWrappedTables/>
</p><p> <w:SnapToGridInCell/>
</p><p> <w:WrapTextWithPunct/>
</p><p> <w:UseAsianBreakRules/>
</p><p> <w:DontGrowAutofit/>
</p><p> </w:Compatibility>
</p><p> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
</p><p> </w:WordDocument>
</p><p></xml><![endif]--><!--[if gte mso 9]><xml>
</p><p> <w:LatentStyles DefLockedState="false" LatentStyleCount="156">
</p><p> </w:LatentStyles>
</p><p></xml><![endif]--><!--[if gte mso 10]>
</p><p><style>
</p><p> /* Style Definitions */
</p><p> table.MsoNormalTable
</p><p> {mso-style-name:"Table Normal";
</p><p> mso-tstyle-rowband-size:0;
</p><p> mso-tstyle-colband-size:0;
</p><p> mso-style-noshow:yes;
</p><p> mso-style-parent:"";
</p><p> mso-padding-alt:0in 5.4pt 0in 5.4pt;
</p><p> mso-para-margin:0in;
</p><p> mso-para-margin-bottom:.0001pt;
</p><p> mso-pagination:widow-orphan;
</p><p> font-size:10.0pt;
</p><p> font-family:"Times New Roman";
</p><p> mso-ansi-language:#0400;
</p><p> mso-fareast-language:#0400;
</p><p> mso-bidi-language:#0400;}
</p><p></style>
</p><p><![endif]-->
Recently been having problems with my isp Verizon & Pegasus. Been having to go to its webmail page to read the mailas selective download(s) not working or the check host option. Sometimes I will have say 10 messages and 8 will show breing downloaded but the completion process never takes place and I will received following messages (which I apologize for length) Seems like some type of timing problem
</p><p><style>
</p><p></style>
</p><p><![endif]-->
>> 0155 +OK Messaging
Multiplexor (Sun Java(tm) System Messaging Server 6.3-11.01 (built Feb 12
2010)) <398dd86b159feb72bd2d2de62c5e1d03@vms171051.mailsrvcs.net>
<< 0015 USER (I have
deleted for this forum it is OK)
>> 0041 +OK password
required for user (I have deleted for forum it is OK)
<< 0021 PASS
XXXXXXXXXXXXXX
>> 0020 +OK Maildrop
ready
<< 0006 STAT
>> 0015 +OK 8 1067047
<< 0006 LIST
>> 0026 +OK scan listing
follows
<< 0008 RETR 1
>> 0019 +OK 163814
octets
<< 0008 DELE 1
>> 0021 +OK message
deleted
<< 0008 RETR 2
>> 0018 +OK 15599 octets
<< 0008 DELE 2
>> 0021 +OK message
deleted
<< 0008 RETR 3
>> 0019 +OK 771328
octets
<< 0021 PASS
XXXXXXXXXXXXXX
>> 0020 +OK Maildrop
ready
<< 0006 STAT
>> 0015 +OK 4 5239877
<< 0006 LIST
follows
<< 0008 UIDL 1
>> 0024 +OK 1
30569-1251803036
<< 0009 TOP 1 1
8: Socket read timeout.
15: Peer connect failure (the
host has refused the connection).
<w:WordDocument>
<w:Zoom>0</w:Zoom>
<w:Compatibility>
</w:Compatibility>
</w:WordDocument>
</w:LatentStyles>
<style>
font-size:10.0pt;
</style>
<![endif]-->
<p class="MsoNormal">&nbsp;Recently been having problems with my isp Verizon &amp; Pegasus. Been having to go to its webmail page to read the mailas selective download(s) not working or the check host option. Sometimes I will have say 10 messages and 8 will show breing downloaded but the completion process never takes place and I will received following messages (which I apologize for length) Seems like some type of timing problem
</p><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:Zoom>0</w:Zoom>
<w:Compatibility>
</w:Compatibility>
</w:WordDocument>
</w:LatentStyles>
<style>
font-size:10.0pt;
</style>
<![endif]-->
<p class="MsoNormal"><span style="font-size: 9pt;">&gt;&gt; 0155 +OK Messaging
2010)) &lt;398dd86b159feb72bd2d2de62c5e1d03@vms171051.mailsrvcs.net&gt;</span></p>
<p class="MsoNormal"><span style="font-size: 9pt;">&lt;&lt; 0015 USER (I have
deleted for this forum it is OK)</span></p>
<p class="MsoNormal"><span style="font-size: 9pt;">&gt;&gt; 0041 +OK password
required for user (I have deleted for forum it is OK)</span></p>
<p class="MsoNormal"><span style="font-size: 9pt;">&lt;&lt; 0021 PASS
XXXXXXXXXXXXXX</span></p>
<p class="MsoNormal"><span style="font-size: 9pt;">&gt;&gt; 0020 +OK Maildrop
ready</span></p>
<p class="MsoNormal"><span style="font-size: 9pt;">&lt;&lt; 0006 STAT</span></p>
<p class="MsoNormal"><span style="font-size: 9pt;">&gt;&gt; 0015 +OK 8 1067047</span></p>
<p class="MsoNormal"><span style="font-size: 9pt;">&lt;&lt; 0006 LIST</span></p>
<p class="MsoNormal"><span style="font-size: 9pt;">&gt;&gt; 0026 +OK scan listing
follows</span></p>
<p class="MsoNormal"><span style="font-size: 9pt;">&lt;&lt; 0008 RETR 1</span></p>
<p class="MsoNormal"><span style="font-size: 9pt;">&gt;&gt; 0019 +OK 163814
octets</span></p>
<p class="MsoNormal"><span style="font-size: 9pt;">&lt;&lt; 0008 DELE 1</span></p>
<p class="MsoNormal"><span style="font-size: 9pt;">&gt;&gt; 0021 +OK message
deleted</span></p>
<p class="MsoNormal"><span style="font-size: 9pt;">&lt;&lt; 0008 RETR 2</span></p>
<p class="MsoNormal"><span style="font-size: 9pt;">&gt;&gt; 0018 +OK 15599 octets</span></p>
<p class="MsoNormal"><span style="font-size: 9pt;">&lt;&lt; 0008 DELE 2</span></p>
deleted</span></p>
<p class="MsoNormal"><span style="font-size: 9pt;">&lt;&lt; 0008 RETR 3</span></p>
<p class="MsoNormal"><span style="font-size: 9pt;">&gt;&gt; 0019 +OK 771328
octets</span></p>
<p class="MsoNormal"><span style="font-size: 9pt;">&nbsp;</span></p>
ready</span></p>
<p class="MsoNormal"><span style="font-size: 9pt;">&gt;&gt; 0015 +OK 4 5239877</span></p>
follows</span></p>
<p class="MsoNormal"><span style="font-size: 9pt;">&lt;&lt; 0008 UIDL 1</span></p>
<p class="MsoNormal"><span style="font-size: 9pt;">&gt;&gt; 0024 +OK 1
30569-1251803036</span></p>
<p class="MsoNormal"><span style="font-size: 9pt;">&lt;&lt; 0009 TOP 1 1</span></p>
<p class="MsoNormal"><span style="font-size: 9pt;">8: Socket read timeout.</span></p>
<p class="MsoNormal"><span style="font-size: 9pt;">&nbsp;15: Peer connect failure (the
host has refused the connection).</span></p>
<span style="font-size: 9pt;"></span>
