Hello I am a new user and I have two problems.
First:
When I download new mails I want them to be downloaded directly in to a folder that represent the e-mail address.
Example:
I have two e-mails, a@blabla.com and b@blabla.com.
Now, when I download mail from both they will be put in the main "New Mail" folder.
What I want, is to create two folders called "a@blabla.com" and "b@blabla.com". Then the if I download the mail, it will automatically be put in those folders.
a@blabla.com's mails will be put in the a@blabla.com's folder etc...
Second:
When I send an e-mail it will be treated as junk for the receiver. Any way to fix this?
<p><strong>Hello I am a new user and I have two problems.</strong></p><p>
</p><p><strong>First:</strong></p><p>When I download new mails I want them to be downloaded directly in to a folder that represent the e-mail address.</p><p>
</p><p>Example:&nbsp;</p><p>I have two e-mails, a@blabla.com and b@blabla.com.</p><p>Now, when I download mail from both they will be put in the main "New Mail" folder.</p><p>What I want, is to create two folders called "a@blabla.com" and "b@blabla.com". Then the if I download the mail, it will automatically be put in those folders.</p><p>a@blabla.com's mails will be put in the a@blabla.com's folder etc...</p><p>
</p><p><strong>Second:</strong></p><p>When I send an e-mail it will be treated as junk for the receiver. Any way to fix this?<strong>
</strong></p>
