[quote user="Thomas R. Stephenson"]> RFCs aside, it is just common sense: If the client sent a command (Delete Mail X) and the server confirmed the execution of the command
> ("OK"), then the server is responsible to retain this information.
> There must be a very specific reason for "forgetting" such a command long after the fact, and in this case, I cannot see such a reason.
The most common reason is that it is better to not delete mail from the server until you know that this was what was desired by the user properly closing the session. The same reasoning is used for POP3 as well, all delete flags are removed if the session is not properly closed.
I heartily disagree: While this behavior made sense with POP3, where a session has a very specific, predetermined purpose (get list of mails, download certain mails, delete other mails, close session). If during all those steps an error happens, the client can start from the beginning.
The usage of IMAP4 is completely different: The session is left open for hours, or even days. The user does many different "transactions" during this session (reading a mail, moving another, going back to the first to delete it etc.). All this is interactive. Every single step must be considered as final, since after hours (or days!) in this open connection, you do not want your actions from way back to suddenly be reversed. Also, it's not like Mercury magically reverts your mailbox to the state before the connection was opened: Only the deleted flag vanishes. Copied mails stay copied, Replied to mails retain that tag etc.
IMAP4 is used hugely differently from POP3. The mailserver has to treat it that way.
Also, one of the new features of 4.73 was, that the index files are now written immediately. I think everyone took this to mean, that all relevant information is saved immediately. Change of a flag, especially "Deleted" is relevant information.
Greetings
Markus Borst
Also, and this is not small problem: Mercury crashes from time to time, mostly on corrupt mailboxes. In this case, the server has no chance to retroactively save the Deleted flag, it is simply lost without any user error at all.
<p>[/quote]</p><p>I heartily disagree: While this behavior made sense with POP3, where a session has a very specific, predetermined purpose (get list of mails, download certain mails, delete other mails, close session). If during all those steps an error happens, the client can start from the beginning.</p><p>The usage of IMAP4 is completely different: The session is left open for hours, or even days. The user does many different "transactions" during this session (reading a mail, moving another, going back to the first to delete it etc.). All this is interactive. Every single step must be considered as final, since after hours (or days!) in this open connection, you do not want your actions from way back to suddenly be reversed. Also, it's not like Mercury magically reverts your mailbox to the state before the connection was opened: Only the deleted flag vanishes. Copied mails stay copied, Replied to mails retain that tag etc.</p><p>IMAP4 is used hugely differently from POP3. The mailserver has to treat it that way.</p><p>Also, one of the new features of 4.73 was, that the index files are now written immediately. I think everyone took this to mean, that all relevant information is saved immediately. Change of a flag, especially "Deleted" is relevant information.</p><p>Greetings</p><p>Markus Borst</p><p>
</p><p>Also, and this is not small problem: Mercury crashes from time to time, mostly on corrupt mailboxes. In this case, the server has no chance to retroactively save the Deleted flag, it is simply lost without any user error at all.&nbsp;</p><p>
