Delivery notifications problem
Worked. Thank you very much.
Filippo
<p>Worked. Thank you very much.</p><p> </p><p>Filippo </p>
I would appreciate a bit of help with delivery notifications.
In my system all the mails are gathered by mercuryD from a unique pop3 account(me@notariato.it), then delivered to a dummy account, that forward them to the local users.
Now, every time the (external) user aaaa@youraccount.com send me an email, every lcoal user get the following message:
With reference to your message with the subject:
   "delibera di fusione"
Your message was successfully delivered to the following addresses:
   ediana
   fpaolini
   imussato
   lpaolini
   mreferre
   ofollini
   rventurini
   svegetti
------------------ Beginning of message follows --------------------
Received: from spooler by paolini09.local (Mercury/32 v4.72)
  for <dummy@paolini09.local>;  25 Jul 2011 14:43:52 +0200
Resent-from: dummy@paolini09.local
Resent-Date: Mon, 25 Jul 2011 14:43:52 +0200
X-Autoforward: 1
Received: from POP3D by paolini09.local with MercuryD (v4.72); 25 Jul 2011 14:43:51 +0200
Return-Path: <aaaa@youraccount.com>
Delivered-To: me@notariato.it
Received: by store-it.notartel.it (Postfix, from userid 8)
    id 8128E70004; Mon, 25 Jul 2011 14:42:45 +0200 (CEST)
Received: from mta1.notariato.it (unknown [192.168.20.1])
    by store-it.notartel.it (Postfix) with ESMTP id 03ECF70001
    for <me@notariato.it>; Mon, 25 Jul 2011 14:42:45 +0200 (CEST)
Received: from localhost.localdomain (localhost.localdomain [127.0.0.1])
    by mta1.notariato.it (Postfix) with SMTP id 7AFBE10351
And this is the header of the above notification message
Received: from spooler by paolini09.local (Mercury/32 v4.72); 25 Jul 2011 14:45:25 +0200
X-Envelope-To: fpaolini
  for <dummy@paolini09.local>;  25 Jul 2011 14:44:54 +0200
Resent-Date: Mon, 25 Jul 2011 14:44:54 +0200
X-Autoforward: 1
From:    Mail Delivery System <postmaster@paolini09.local>
To:      dummy@paolini09.local
Date:    Mon, 25 Jul 2011 14:44:23 +0200
Subject: Delivery Confirmation
X-EsetId: 95FC9A276CCF3C36C1B1
I really cannot under stand: what should I turn off in Mercury?
Best regards
Filippo
<!--[if gte mso 9]><xml> </p><p> <w:WordDocument> </p><p> <w:View>Normal</w:View> </p><p> <w:Zoom>0</w:Zoom> </p><p> <w:TrackMoves/> </p><p> <w:TrackFormatting/> </p><p> <w:HyphenationZone>14</w:HyphenationZone> </p><p> <w:PunctuationKerning/> </p><p> <w:ValidateAgainstSchemas/> </p><p> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> </p><p> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> </p><p> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> </p><p> <w:DoNotPromoteQF/> </p><p> <w:LidThemeOther>IT</w:LidThemeOther> </p><p> <w:LidThemeAsian>X-NONE</w:LidThemeAsian> </p><p> <w:LidThemeComplexScript>X-NONE</w:LidThemeComplexScript> </p><p> <w:Compatibility> </p><p> <w:BreakWrappedTables/> </p><p> <w:SnapToGridInCell/> </p><p> <w:WrapTextWithPunct/> </p><p> <w:UseAsianBreakRules/> </p><p> <w:DontGrowAutofit/> </p><p> <w:SplitPgBreakAndParaMark/> </p><p> <w:DontVertAlignCellWithSp/> </p><p> <w:DontBreakConstrainedForcedTables/> </p><p> <w:DontVertAlignInTxbx/> </p><p> <w:Word11KerningPairs/> </p><p> <w:CachedColBalance/> </p><p> </w:Compatibility> </p><p> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </p><p> <m:mathPr> </p><p> <m:mathFont m:val="Cambria Math"/> </p><p> <m:brkBin m:val="before"/> </p><p> <m:brkBinSub m:val="&#45;-"/> </p><p> <m:smallFrac m:val="off"/> </p><p> <m:dispDef/> </p><p> <m:lMargin m:val="0"/> </p><p> <m:rMargin m:val="0"/> </p><p> <m:defJc m:val="centerGroup"/> </p><p> <m:wrapIndent m:val="1440"/> </p><p> <m:intLim m:val="subSup"/> </p><p> <m:naryLim m:val="undOvr"/> </p><p> </m:mathPr></w:WordDocument> </p><p></xml><![endif]--><!--[if gte mso 9]><xml> </p><p> <w:LatentStyles DefLockedState="false" DefUnhideWhenUsed="true" </p><p> DefSemiHidden="true" DefQFormat="false" DefPriority="99" </p><p> LatentStyleCount="267"> </p><p> <w:LsdException Locked="false" Priority="0" SemiHidden="false" </p><p> UnhideWhenUsed="false" QFormat="true" Name="Normal"/> </p><p> <w:LsdException Locked="false" Priority="9" SemiHidden="false" </p><p> UnhideWhenUsed="false" QFormat="true" Name="heading 1"/> </p><p> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 2"/> </p><p> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 3"/> </p><p> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 4"/> </p><p> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 5"/> </p><p> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 6"/> </p><p> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 7"/> </p><p> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 8"/> </p><p> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 9"/> </p><p> <w:LsdException Locked="false" Priority="39" Name="toc 1"/> </p><p> <w:LsdException Locked="false" Priority="39" Name="toc 2"/> </p><p> <w:LsdException Locked="false" Priority="39" Name="toc 3"/> </p><p> <w:LsdException Locked="false" Priority="39" Name="toc 4"/> </p><p> <w:LsdException Locked="false" Priority="39" Name="toc 5"/> </p><p> <w:LsdException Locked="false" Priority="39" Name="toc 6"/> </p><p> <w:LsdException Locked="false" Priority="39" Name="toc 7"/> </p><p> <w:LsdException Locked="false" Priority="39" Name="toc 8"/> </p><p> <w:LsdException Locked="false" Priority="39" Name="toc 9"/> </p><p> <w:LsdException Locked="false" Priority="35" QFormat="true" Name="caption"/> </p><p> <w:LsdException Locked="false" Priority="10" SemiHidden="false" </p><p> UnhideWhenUsed="false" QFormat="true" Name="Title"/> </p><p> <w:LsdException Locked="false" Priority="1" Name="Default Paragraph Font"/> </p><p> <w:LsdException Locked="false" Priority="11" SemiHidden="false" </p><p> UnhideWhenUsed="false" QFormat="true" Name="Subtitle"/> </p><p> <w:LsdException Locked="false" Priority="22" SemiHidden="false" </p><p> UnhideWhenUsed="false" QFormat="true" Name="Strong"/> </p><p> <w:LsdException Locked="false" Priority="20" SemiHidden="false" </p><p> UnhideWhenUsed="false" QFormat="true" Name="Emphasis"/> </p><p> <w:LsdException Locked="false" Priority="59" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Table Grid"/> </p><p> <w:LsdException Locked="false" UnhideWhenUsed="false" Name="Placeholder Text"/> </p><p> <w:LsdException Locked="false" Priority="1" SemiHidden="false" </p><p> UnhideWhenUsed="false" QFormat="true" Name="No Spacing"/> </p><p> <w:LsdException Locked="false" Priority="60" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Light Shading"/> </p><p> <w:LsdException Locked="false" Priority="61" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Light List"/> </p><p> <w:LsdException Locked="false" Priority="62" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Light Grid"/> </p><p> <w:LsdException Locked="false" Priority="63" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Shading 1"/> </p><p> <w:LsdException Locked="false" Priority="64" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Shading 2"/> </p><p> <w:LsdException Locked="false" Priority="65" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium List 1"/> </p><p> <w:LsdException Locked="false" Priority="66" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium List 2"/> </p><p> <w:LsdException Locked="false" Priority="67" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Grid 1"/> </p><p> <w:LsdException Locked="false" Priority="68" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Grid 2"/> </p><p> <w:LsdException Locked="false" Priority="69" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Grid 3"/> </p><p> <w:LsdException Locked="false" Priority="70" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Dark List"/> </p><p> <w:LsdException Locked="false" Priority="71" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Colorful Shading"/> </p><p> <w:LsdException Locked="false" Priority="72" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Colorful List"/> </p><p> <w:LsdException Locked="false" Priority="73" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Colorful Grid"/> </p><p> <w:LsdException Locked="false" Priority="60" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Light Shading Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="61" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Light List Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="62" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Light Grid Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="63" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Shading 1 Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="64" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Shading 2 Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="65" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium List 1 Accent 1"/> </p><p> <w:LsdException Locked="false" UnhideWhenUsed="false" Name="Revision"/> </p><p> <w:LsdException Locked="false" Priority="34" SemiHidden="false" </p><p> UnhideWhenUsed="false" QFormat="true" Name="List Paragraph"/> </p><p> <w:LsdException Locked="false" Priority="29" SemiHidden="false" </p><p> UnhideWhenUsed="false" QFormat="true" Name="Quote"/> </p><p> <w:LsdException Locked="false" Priority="30" SemiHidden="false" </p><p> UnhideWhenUsed="false" QFormat="true" Name="Intense Quote"/> </p><p> <w:LsdException Locked="false" Priority="66" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium List 2 Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="67" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Grid 1 Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="68" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Grid 2 Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="69" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Grid 3 Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="70" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Dark List Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="71" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Colorful Shading Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="72" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Colorful List Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="73" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Colorful Grid Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="60" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Light Shading Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="61" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Light List Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="62" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Light Grid Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="63" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Shading 1 Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="64" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Shading 2 Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="65" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium List 1 Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="66" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium List 2 Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="67" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Grid 1 Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="68" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Grid 2 Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="69" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Grid 3 Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="70" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Dark List Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="71" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Colorful Shading Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="72" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Colorful List Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="73" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Colorful Grid Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="60" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Light Shading Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="61" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Light List Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="62" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Light Grid Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="63" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Shading 1 Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="64" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Shading 2 Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="65" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium List 1 Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="66" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium List 2 Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="67" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Grid 1 Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="68" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Grid 2 Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="69" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Grid 3 Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="70" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Dark List Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="71" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Colorful Shading Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="72" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Colorful List Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="73" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Colorful Grid Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="60" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Light Shading Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="61" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Light List Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="62" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Light Grid Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="63" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Shading 1 Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="64" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Shading 2 Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="65" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium List 1 Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="66" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium List 2 Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="67" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Grid 1 Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="68" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Grid 2 Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="69" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Grid 3 Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="70" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Dark List Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="71" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Colorful Shading Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="72" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Colorful List Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="73" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Colorful Grid Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="60" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Light Shading Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="61" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Light List Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="62" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Light Grid Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="63" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Shading 1 Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="64" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Shading 2 Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="65" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium List 1 Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="66" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium List 2 Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="67" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Grid 1 Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="68" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Grid 2 Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="69" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Grid 3 Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="70" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Dark List Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="71" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Colorful Shading Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="72" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Colorful List Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="73" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Colorful Grid Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="60" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Light Shading Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="61" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Light List Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="62" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Light Grid Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="63" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Shading 1 Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="64" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Shading 2 Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="65" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium List 1 Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="66" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium List 2 Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="67" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Grid 1 Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="68" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Grid 2 Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="69" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Medium Grid 3 Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="70" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Dark List Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="71" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Colorful Shading Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="72" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Colorful List Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="73" SemiHidden="false" </p><p> UnhideWhenUsed="false" Name="Colorful Grid Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="19" SemiHidden="false" </p><p> UnhideWhenUsed="false" QFormat="true" Name="Subtle Emphasis"/> </p><p> <w:LsdException Locked="false" Priority="21" SemiHidden="false" </p><p> UnhideWhenUsed="false" QFormat="true" Name="Intense Emphasis"/> </p><p> <w:LsdException Locked="false" Priority="31" SemiHidden="false" </p><p> UnhideWhenUsed="false" QFormat="true" Name="Subtle Reference"/> </p><p> <w:LsdException Locked="false" Priority="32" SemiHidden="false" </p><p> UnhideWhenUsed="false" QFormat="true" Name="Intense Reference"/> </p><p> <w:LsdException Locked="false" Priority="33" SemiHidden="false" </p><p> UnhideWhenUsed="false" QFormat="true" Name="Book Title"/> </p><p> <w:LsdException Locked="false" Priority="37" Name="Bibliography"/> </p><p> <w:LsdException Locked="false" Priority="39" QFormat="true" Name="TOC Heading"/> </p><p> </w:LatentStyles> </p><p></xml><![endif]--><!--[if gte mso 10]> </p><p><style> </p><p> /* Style Definitions */ </p><p> table.MsoNormalTable </p><p> {mso-style-name:"Tabella normale"; </p><p> mso-tstyle-rowband-size:0; </p><p> mso-tstyle-colband-size:0; </p><p> mso-style-noshow:yes; </p><p> mso-style-priority:99; </p><p> mso-style-qformat:yes; </p><p> mso-style-parent:""; </p><p> mso-padding-alt:0cm 5.4pt 0cm 5.4pt; </p><p> mso-para-margin-top:0cm; </p><p> mso-para-margin-right:0cm; </p><p> mso-para-margin-bottom:10.0pt; </p><p> mso-para-margin-left:0cm; </p><p> line-height:115%; </p><p> mso-pagination:widow-orphan; </p><p> font-size:11.0pt; </p><p> font-family:"Calibri","sans-serif"; </p><p> mso-ascii-font-family:Calibri; </p><p> mso-ascii-theme-font:minor-latin; </p><p> mso-fareast-font-family:"Times New Roman"; </p><p> mso-fareast-theme-font:minor-fareast; </p><p> mso-hansi-font-family:Calibri; </p><p> mso-hansi-theme-font:minor-latin;} </p><p></style> </p><p><![endif]-->
&lt;p&gt;Hello, I would appreciate a bit of help with delivery notifications. In my system all the mails are gathered by mercuryD from a unique pop3 account(me@notariato.it), then delivered to a dummy account, that forward them to the local users. Now, every time the (external) user aaaa@youraccount.com send me an email, every lcoal user get the following message: &lt;i&gt;With reference to your message with the subject: &amp;nbsp;&amp;nbsp; &quot;delibera di fusione&quot; Your message was successfully delivered to the following addresses: &amp;nbsp;&amp;nbsp; ediana &amp;nbsp;&amp;nbsp; fpaolini &amp;nbsp;&amp;nbsp; imussato &amp;nbsp;&amp;nbsp; lpaolini &amp;nbsp;&amp;nbsp; mreferre &amp;nbsp;&amp;nbsp; ofollini &amp;nbsp;&amp;nbsp; rventurini &amp;nbsp;&amp;nbsp; svegetti ------------------ Beginning of message follows -------------------- Received: from spooler by paolini09.local (Mercury/32 v4.72) &amp;nbsp; for &amp;lt;dummy@paolini09.local&amp;gt;;&amp;nbsp; 25 Jul 2011 14:43:52 +0200 Resent-from: dummy@paolini09.local Resent-Date: Mon, 25 Jul 2011 14:43:52 +0200 X-Autoforward: 1 Received: from POP3D by paolini09.local with MercuryD (v4.72); 25 Jul 2011 14:43:51 +0200 Return-Path: &amp;lt;aaaa@youraccount.com&amp;gt; Delivered-To: me@notariato.it Received: by store-it.notartel.it (Postfix, from userid 8) &amp;nbsp;&amp;nbsp;&amp;nbsp; id 8128E70004; Mon, 25 Jul 2011 14:42:45 +0200 (CEST) Received: from mta1.notariato.it (unknown [192.168.20.1]) &amp;nbsp;&amp;nbsp;&amp;nbsp; by store-it.notartel.it (Postfix) with ESMTP id 03ECF70001 &amp;nbsp;&amp;nbsp;&amp;nbsp; for &amp;lt;me@notariato.it&amp;gt;; Mon, 25 Jul 2011 14:42:45 +0200 (CEST) Received: from localhost.localdomain (localhost.localdomain [127.0.0.1]) &amp;nbsp;&amp;nbsp;&amp;nbsp; by mta1.notariato.it (Postfix) with SMTP id 7AFBE10351 &amp;nbsp;&amp;nbsp;&amp;nbsp; by mta1.notariato.it (Postfix) with SMTP id 7AFBE10351&lt;/i&gt; And this is the header of the above notification message &lt;/p&gt;&lt;p&gt;&lt;i&gt;Received: from spooler by paolini09.local (Mercury/32 v4.72); 25 Jul 2011 14:45:25 +0200 X-Envelope-To: fpaolini Received: from spooler by paolini09.local (Mercury/32 v4.72) &amp;nbsp; for &amp;lt;dummy@paolini09.local&amp;gt;;&amp;nbsp; 25 Jul 2011 14:44:54 +0200 Resent-from: dummy@paolini09.local Resent-Date: Mon, 25 Jul 2011 14:44:54 +0200 X-Autoforward: 1 From:&amp;nbsp;&amp;nbsp;&amp;nbsp; Mail Delivery System &amp;lt;postmaster@paolini09.local&amp;gt; To:&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp; dummy@paolini09.local Date:&amp;nbsp;&amp;nbsp;&amp;nbsp; Mon, 25 Jul 2011 14:44:23 +0200 Subject: Delivery Confirmation X-EsetId: 95FC9A276CCF3C36C1B1 &lt;/i&gt; I really cannot under stand: what should I turn off in Mercury? Best regards Filippo &lt;!--[if gte mso 9]&gt;&lt;xml&gt; &lt;w:WordDocument&gt; &lt;w:View&gt;Normal&lt;/w:View&gt; &lt;w:Zoom&gt;0&lt;/w:Zoom&gt; &lt;w:TrackMoves/&gt; &lt;w:TrackFormatting/&gt; &lt;w:HyphenationZone&gt;14&lt;/w:HyphenationZone&gt; &lt;w:PunctuationKerning/&gt; &lt;w:ValidateAgainstSchemas/&gt; &lt;w:SaveIfXMLInvalid&gt;false&lt;/w:SaveIfXMLInvalid&gt; &lt;w:IgnoreMixedContent&gt;false&lt;/w:IgnoreMixedContent&gt; &lt;w:AlwaysShowPlaceholderText&gt;false&lt;/w:AlwaysShowPlaceholderText&gt; &lt;w:DoNotPromoteQF/&gt; &lt;w:LidThemeOther&gt;IT&lt;/w:LidThemeOther&gt; &lt;w:LidThemeAsian&gt;X-NONE&lt;/w:LidThemeAsian&gt; &lt;w:LidThemeComplexScript&gt;X-NONE&lt;/w:LidThemeComplexScript&gt; &lt;w:Compatibility&gt; &lt;w:BreakWrappedTables/&gt; &lt;w:SnapToGridInCell/&gt; &lt;w:WrapTextWithPunct/&gt; &lt;w:UseAsianBreakRules/&gt; &lt;w:DontGrowAutofit/&gt; &lt;w:SplitPgBreakAndParaMark/&gt; &lt;w:DontVertAlignCellWithSp/&gt; &lt;w:DontBreakConstrainedForcedTables/&gt; &lt;w:DontVertAlignInTxbx/&gt; &lt;w:Word11KerningPairs/&gt; &lt;w:CachedColBalance/&gt; &lt;/w:Compatibility&gt; &lt;w:BrowserLevel&gt;MicrosoftInternetExplorer4&lt;/w:BrowserLevel&gt; &lt;m:mathPr&gt; &lt;m:mathFont m:val=&quot;Cambria Math&quot;/&gt; &lt;m:brkBin m:val=&quot;before&quot;/&gt; &lt;m:brkBinSub m:val=&quot;&amp;#45;-&quot;/&gt; &lt;m:smallFrac m:val=&quot;off&quot;/&gt; &lt;m:dispDef/&gt; &lt;m:lMargin m:val=&quot;0&quot;/&gt; &lt;m:rMargin m:val=&quot;0&quot;/&gt; &lt;m:defJc m:val=&quot;centerGroup&quot;/&gt; &lt;m:wrapIndent m:val=&quot;1440&quot;/&gt; &lt;m:intLim m:val=&quot;subSup&quot;/&gt; &lt;m:naryLim m:val=&quot;undOvr&quot;/&gt; &lt;/m:mathPr&gt;&lt;/w:WordDocument&gt; &lt;/xml&gt;&lt;![endif]--&gt;&lt;!--[if gte mso 9]&gt;&lt;xml&gt; &lt;w:LatentStyles DefLockedState=&quot;false&quot; DefUnhideWhenUsed=&quot;true&quot; DefSemiHidden=&quot;true&quot; DefQFormat=&quot;false&quot; DefPriority=&quot;99&quot; LatentStyleCount=&quot;267&quot;&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;0&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; QFormat=&quot;true&quot; Name=&quot;Normal&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;9&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; QFormat=&quot;true&quot; Name=&quot;heading 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;9&quot; QFormat=&quot;true&quot; Name=&quot;heading 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;9&quot; QFormat=&quot;true&quot; Name=&quot;heading 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;9&quot; QFormat=&quot;true&quot; Name=&quot;heading 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;9&quot; QFormat=&quot;true&quot; Name=&quot;heading 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;9&quot; QFormat=&quot;true&quot; Name=&quot;heading 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;9&quot; QFormat=&quot;true&quot; Name=&quot;heading 7&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;9&quot; QFormat=&quot;true&quot; Name=&quot;heading 8&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;9&quot; QFormat=&quot;true&quot; Name=&quot;heading 9&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;39&quot; Name=&quot;toc 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;39&quot; Name=&quot;toc 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;39&quot; Name=&quot;toc 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;39&quot; Name=&quot;toc 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;39&quot; Name=&quot;toc 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;39&quot; Name=&quot;toc 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;39&quot; Name=&quot;toc 7&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;39&quot; Name=&quot;toc 8&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;39&quot; Name=&quot;toc 9&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;35&quot; QFormat=&quot;true&quot; Name=&quot;caption&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;10&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; QFormat=&quot;true&quot; Name=&quot;Title&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;1&quot; Name=&quot;Default Paragraph Font&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;11&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; QFormat=&quot;true&quot; Name=&quot;Subtitle&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;22&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; QFormat=&quot;true&quot; Name=&quot;Strong&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;20&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; QFormat=&quot;true&quot; Name=&quot;Emphasis&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;59&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Table Grid&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Placeholder Text&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;1&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; QFormat=&quot;true&quot; Name=&quot;No Spacing&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;60&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Light Shading&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;61&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Light List&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;62&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Light Grid&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;63&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Shading 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;64&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Shading 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;65&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium List 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;66&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium List 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;67&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Grid 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;68&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Grid 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;69&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Grid 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;70&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Dark List&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;71&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Colorful Shading&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;72&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Colorful List&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;73&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Colorful Grid&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;60&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Light Shading Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;61&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Light List Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;62&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Light Grid Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;63&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Shading 1 Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;64&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Shading 2 Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;65&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium List 1 Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Revision&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;34&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; QFormat=&quot;true&quot; Name=&quot;List Paragraph&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;29&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; QFormat=&quot;true&quot; Name=&quot;Quote&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;30&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; QFormat=&quot;true&quot; Name=&quot;Intense Quote&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;66&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium List 2 Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;67&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Grid 1 Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;68&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Grid 2 Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;69&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Grid 3 Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;70&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Dark List Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;71&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Colorful Shading Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;72&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Colorful List Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;73&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Colorful Grid Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;60&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Light Shading Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;61&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Light List Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;62&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Light Grid Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;63&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Shading 1 Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;64&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Shading 2 Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;65&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium List 1 Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;66&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium List 2 Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;67&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Grid 1 Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;68&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Grid 2 Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;69&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Grid 3 Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;70&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Dark List Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;71&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Colorful Shading Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;72&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Colorful List Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;73&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Colorful Grid Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;60&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Light Shading Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;61&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Light List Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;62&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Light Grid Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;63&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Shading 1 Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;64&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Shading 2 Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;65&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium List 1 Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;66&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium List 2 Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;67&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Grid 1 Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;68&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Grid 2 Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;69&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Grid 3 Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;70&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Dark List Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;71&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Colorful Shading Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;72&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Colorful List Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;73&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Colorful Grid Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;60&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Light Shading Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;61&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Light List Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;62&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Light Grid Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;63&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Shading 1 Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;64&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Shading 2 Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;65&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium List 1 Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;66&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium List 2 Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;67&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Grid 1 Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;68&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Grid 2 Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;69&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Grid 3 Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;70&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Dark List Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;71&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Colorful Shading Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;72&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Colorful List Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;73&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Colorful Grid Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;60&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Light Shading Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;61&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Light List Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;62&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Light Grid Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;63&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Shading 1 Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;64&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Shading 2 Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;65&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium List 1 Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;66&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium List 2 Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;67&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Grid 1 Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;68&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Grid 2 Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;69&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Grid 3 Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;70&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Dark List Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;71&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Colorful Shading Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;72&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Colorful List Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;73&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Colorful Grid Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;60&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Light Shading Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;61&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Light List Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;62&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Light Grid Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;63&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Shading 1 Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;64&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Shading 2 Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;65&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium List 1 Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;66&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium List 2 Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;67&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Grid 1 Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;68&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Grid 2 Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;69&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Medium Grid 3 Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;70&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Dark List Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;71&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Colorful Shading Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;72&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Colorful List Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;73&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; Name=&quot;Colorful Grid Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;19&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; QFormat=&quot;true&quot; Name=&quot;Subtle Emphasis&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;21&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; QFormat=&quot;true&quot; Name=&quot;Intense Emphasis&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;31&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; QFormat=&quot;true&quot; Name=&quot;Subtle Reference&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;32&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; QFormat=&quot;true&quot; Name=&quot;Intense Reference&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;33&quot; SemiHidden=&quot;false&quot; UnhideWhenUsed=&quot;false&quot; QFormat=&quot;true&quot; Name=&quot;Book Title&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;37&quot; Name=&quot;Bibliography&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;39&quot; QFormat=&quot;true&quot; Name=&quot;TOC Heading&quot;/&gt; &lt;/w:LatentStyles&gt; &lt;/xml&gt;&lt;![endif]--&gt;&lt;!--[if gte mso 10]&gt; &lt;style&gt; /* Style Definitions */ table.MsoNormalTable {mso-style-name:&quot;Tabella normale&quot;; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:&quot;&quot;; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:&quot;Calibri&quot;,&quot;sans-serif&quot;; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:&quot;Times New Roman&quot;; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;} &lt;/style&gt; &lt;![endif]--&gt;&lt;/p&gt;
It looks like the sending client has requested delivery confirmation from the server. To disable sending of delivery confirmations you can clear the field "Delivery confirmation template" in Core configuration / Files.
&lt;p&gt;It looks like the sending client has requested delivery confirmation from the server. To disable sending of delivery confirmations you can clear the field &quot;Delivery confirmation template&quot; in Core configuration / Files.&lt;/p&gt;&lt;p&gt;/Rolf&amp;nbsp;&lt;/p&gt;
