I haven't tried Profimail yet but I did look at the Android Market reviews. They were a bit mixed, though mainly on the positive side. The main complaints seemed to be about the UI and the cost (though that's not a big issue for me, if it works well). I haven't been able to find out whether it's possible to set Profimail to logout IMAP4 connections after checking mail.
I have also been doing a bit of research about K-9 and Thunderbird (I am now using 6.0), which both give me persistent connections. It seems that some (maybe not all) IMAP4 servers check for unused/hung connections and remove any connections that are in this situation. Mercury seems to be one of those that does check. I have Mercury's IMAP4 idle time-out set to 30 minutes (the default and minimum allowed by the RFC). In the case of Thunderbird, I have set the IMAP4 client to check for new mail every 40 minutes. This is far too long than I would like, but is a useful test. Indeed, after 30 minutes the connections disappear from Mercury's IMAP4 server window, which then shows no connections for 10 minutes. I have also set the Thunderbird accounts so that they do not use the IDLE command. Also, I have the TB accounts set so that there is only one cached connection. I tried to use zero cached connections (I am not sure that this makes sense), but "0" wouldn't stick, and went back to "1", which I had been using. The only other odd thing about the TB connections is that I have all of the accounts set so they don't check mail immediately when TB starts. Of the seven accounts that are connecting to Mercury, six of them follow the desired behaviour. One, however, makes a connection as soon as TB starts. I don't know why.
Given that, under the above setup, there is a period when there are no connections from my machine running TB, I think that it should be possible to purge e-mails from another client (running OE6) during this window. How practical this is really going to be, given the long mail checking cycle, I haven't decided yet.
So far as K-9 is concerned, I am still awaiting results. There is less flexibility in setting refresh times than for TB. I have set the IDLE refresh time to 60 minutes (there is no "never refresh" and the next smallest available is 30 minutes, which is the same as Mercury's idle time-out). I have also set the mail polling time to 60 minutes.
Whether this is going to get me anywhere with regard to being able to delete mail in a multi-client environment, I don't know.
What I don't understand (unless Push mail is being used, which requires a persistent connection) is why IMAP4 clients don't just logon, check mail and then logout immediately. Maybe I am missing something here.
Gordon
<P>I haven't tried Profimail yet but I did look at the Android Market reviews.&nbsp; They were a bit mixed, though mainly on the positive side.&nbsp; The main complaints seemed to be about the UI and the cost (though that's not a big issue for me, if it works well).&nbsp; I haven't been able to find out whether it's possible to set Profimail to logout IMAP4 connections after checking mail.</P>
<P>I have also been doing a bit of research about K-9 and Thunderbird (I am now using 6.0), which both give me persistent connections.&nbsp; It seems that some (maybe not all) IMAP4 servers check for unused/hung connections and remove any connections that are in this situation.&nbsp; Mercury seems to be one of those that does check.&nbsp; I have Mercury's IMAP4 idle time-out set to 30 minutes (the default and minimum allowed by the RFC).&nbsp; In the case of Thunderbird, I have set the IMAP4 client to check for new mail every 40 minutes.&nbsp; This is far too long than I would like, but is a useful test.&nbsp; Indeed, after 30 minutes the connections disappear from Mercury's IMAP4 server window, which then shows no connections for 10 minutes.&nbsp; I have also set the Thunderbird accounts so that they do not use the IDLE command.&nbsp; Also, I have the TB accounts set so that there is only one cached connection.&nbsp; I tried to use zero cached connections (I am not sure that this makes sense), but "0" wouldn't stick, and went back to "1", which I had been using.&nbsp; The only other odd thing about the TB connections is that I have all of the accounts set so they don't check mail immediately when TB starts.&nbsp; Of the&nbsp;seven accounts that are connecting to Mercury, six of them follow the desired behaviour.&nbsp; One, however, makes a connection as soon as TB starts.&nbsp; I don't know why.</P>
<P>Given that, under the above setup, there is a period when there are no connections from my machine running TB, I think that it should be possible to purge e-mails from another client (running OE6) during this window.&nbsp; How practical this is really going to be, given the long mail checking cycle, I haven't decided yet.</P>
<P>So far as K-9 is concerned, I am still awaiting results.&nbsp; There is less flexibility in setting refresh times than for TB.&nbsp; I have set the IDLE refresh time to 60 minutes (there is no "never refresh" and the next smallest available is 30 minutes, which is the same as Mercury's idle time-out).&nbsp; I have also set the mail polling time to 60 minutes.</P>
<P>Whether this is going to get me anywhere with regard to being able to delete mail in a multi-client environment, I don't know.</P>
<P>What I don't understand (unless Push mail is being used, which requires a persistent connection) is why IMAP4 clients don't just logon, check mail and then logout immediately.&nbsp; Maybe I am missing something here.</P>
<P>Gordon</P>
<P mce_keep="true">&nbsp;</P>
