Pegasus Mail Suggestions
Right and left click when icon in start bar
Same here!  I thought I was the only one experiencing this weirdness! (running Win2k, SP4).
I suppose we should move this discussion to Support....but I could not resist responding, as I previously thought I was the only one with this problem!
Same here!  I thought I was the only one experiencing this weirdness! (running Win2k, SP4). I suppose we should move this discussion to Support....but I could not resist responding, as I previously thought I was the only one with this problem!
When Pegasus is reduced to an icon in the right hand corner of my start bar, if I double-click on it, it shows extended in my start bar. BUT... if I click on that again, it doesn't appear, it is only with a right-click that it appears.
Shouldn't it appear with a left click? How can the new user guess he must right-click?
<p>When Pegasus is reduced to an icon in the right hand corner of my start bar, if I double-click on it, it shows extended in my start bar. BUT... if I click on that again, it doesn't appear, it is only with a right-click that it appears.</p><p> </p><p>Shouldn't it appear with a left click? How can the new user guess he must right-click? </p>
Not for me. If I minimize Pegasus to the Systray, then a double click on its icon restores it but does not bring it to the foreground. Left-clicking on its name in the taskbar, as with any other program, brings it to the foreground.
Up! Sorry but I found the message above irrelevant to the problem I noticed.
When I double-click on the icon on the bottom right side, it only appears in the task bar, and then a left-click makes it disappear back to the bottom right icon.
When I double-click on the icon on the bottom right side, only a righ-click makes the window appear in the foreground.
<p>Up! Sorry but I found the message above irrelevant to the problem I noticed. </p><p>  When I double-click on the icon on the bottom right side, it only appears in the task bar, and then a left-click makes it disappear back to the bottom right icon. </p><p>When I double-click on the icon on the bottom right side, only a righ-click makes the window appear in the foreground.  </p>
