Issue with Earthlink Web hosting & Pegasus as of 9/29/2011
Email from PMAIL support after review of log files I provided. Appears that Eaarthlink has made a change:
 Ok here is the problem. It appears this is one of the servers that advertise the
AUTH type CRAM-MD5 but have not really implemented it. This is why David added the option
in v4.6x to "Do not use CRAM-MD5 authentication even if it is advertised " If you select this
option when editing the SMTP setup under "Security" then it will fall back to using the AUTH
PLAIN or LOGIN.
Selecting this option does fix the issue. I have provided this feedback to Earthlink as well.
<FONT size=2> <P align=left mce_keep="true"> </P> <P align=left>Email from PMAIL support after review of log files I provided. Appears that Eaarthlink has made a change:</P> <P align=left><EM> Ok here is the problem. It appears this is one of the servers that advertise the</EM></P> <P align=left><EM>AUTH type CRAM-MD5 but have not really implemented it. This is why David added the option</EM></P> <P align=left><EM>in v4.6x to "Do not use CRAM-MD5 authentication even if it is advertised " If you select this</EM></P> <P align=left><EM>option when editing the SMTP setup under "Security" then it will fall back to using the AUTH</EM></P> <P align=left><EM>PLAIN or LOGIN.</EM></P> <P align=left mce_keep="true"> </P> <P align=left>Selecting this option does fix the issue. I have provided this feedback to Earthlink as well.</P></FONT>
Sometime overnight all 3 of the computers at our house stopped sending email. After lots problem solving and talking to Earthlink Tech Support, (who told me to use Outlook) I believe I have found a work around.
This morning if I wrote a single email and then sent it, it would fail with an authentication error. I then noticed that if I had BCC'd somebody, the BCC email went. If I wrote 5 emails and then tried to send, the first one would fail, but the next 4 would work.
 I ended up changing the smtp definition to do a login prior to sending mail (previously I simply gave it the credentials to use - has worked that way for 5 years)
 It now works but thought others may run into this and wanted to share.
<P>Sometime overnight all 3 of the computers at our house stopped sending email. After lots problem solving and talking to Earthlink Tech Support, (who told me to use Outlook) I believe I have found a work around.</P> <P>This morning if I wrote a single email and then sent it, it would fail with an authentication error. I then noticed that if I had BCC'd somebody, the BCC email went. If I wrote 5 emails and then tried to send, the first one would fail, but the next 4 would work. </P> <P> I ended up changing the smtp definition to do a login prior to sending mail (previously I simply gave it the credentials to use - has worked that way for 5 years)</P> <P> It now works but thought others may run into this and wanted to share.</P>
