If you keep your messages reverse-sorted by date, the new messages will come in at the top and everything will be in correct sort order.
Messages marked "urgent" floating to the top, or using the setting "sort unread before read" will slightly skew the list, but it's a lot better than having half your new mail at the top and half at the bottom.
Try it, you might be surprised how quickly you get used to it... it's not as cool and sophisticated as fancy grouping & threading, but it works!
<p>If you keep your messages reverse-sorted by date, the new messages will come in at the top and everything will be in correct sort order.</p><p>Messages marked "urgent" floating to the top, or using the setting "sort unread before read" will slightly skew the list, but it's a lot better than having half your new mail at the top and half at the bottom.</p><p>Try it, you might be surprised how quickly you get used to it... it's not as cool and sophisticated as fancy grouping &amp; threading, but it works!
