Problem with Reply
[quote user="dbowser"]How can I assure that the entire original message is included? [/quote]
Update to Pegasus Mail 4.62, maybe? Otherwise try to do a select all before starting a reply and choose Selected portion from the upcoming dialog. BTW: What kind of messages are affected? Formatted (HTML) ones or plain text (you only need to tell us if updating Pegasus Mail isn't an option: then we would like to get a sample message for duplication as well)?
<p>[quote user="dbowser"]How can I assure that the entire original message is included? [/quote]</p><p>Update to <a href="http://pmail.com/v46x.htm" mce_href="http://pmail.com/v46x.htm" target="_blank">Pegasus Mail 4.62</a>, maybe? Otherwise try to do a <em>select all</em> before starting a reply and choose <em>Selected portion</em> from the upcoming dialog. BTW: What kind of messages are affected? Formatted (HTML) ones or plain text (you only need to tell us if updating Pegasus Mail isn't an option: then we would like to get a sample message for duplication as well)?</p>
When I use Reply and include the original message, the message is cut off. Only a few paragraphs of the original message are included. The balance of the original message is not included.
Thanks for your help.
Dan
<p>When I use Reply and include the original message, the message is cut off. Only a few paragraphs of the original message are included. The balance of the original message is not included.</p><p>How can I assure that the entire original message is included? </p><p>Thanks for your help.</p><p>Dan </p>
