[quote user="djmeydey"]
Hi
This could be the problem. But what drivers can I take, but those from HP themself?
I have these printers: HP deskjet 1280 and HP PSC 1210
I really don't know if there are other drivers available.
You can get drivers for these printers directly from HP. To test is you are really having a printer problem though create a new printer set to print to a file and then use that as the default printer driver. If things speed up then this is a printer driver problem.
[quote user="djmeydey"]<p>Hi
[/quote]</p><p>&nbsp;You can get drivers for these printers directly from HP.&nbsp; To test is you are really having a printer problem though create a new printer set to print to a file and then use that as the default printer driver.&nbsp; If things speed up then this is a printer driver problem.</p><p>
&nbsp;</p>
