I had a note hang up on me, then when I restarted Pegasus, I got the following: Mailbox is locked. This happens, so I press Continue and the Mailbox is locked panel becomes greyed out and behind it appears a standard Windows screen which says Pegasus for Windows has stopped working, that I can search for a solution online (yeah, right) or close the program. That, oddly enough, closes the program. So, I have a Mailbox is locked which persistently creates a Program has stopped working. There are no other options. The details are:
Problem signature:
Problem Event Name: BEX
Application Name: winpm-32.exe
Application Version: 4.5.2.0
Application Timestamp: 4b543cb5
Fault Module Name: winpm-32.exe
Fault Module Version: 4.5.2.0
Fault Module Timestamp: 4b543cb5
Exception Offset: 0018b976
Exception Code: c0000417
Exception Data: 00000000
OS Version: 6.1.7601.2.1.0.768.3
Locale ID: 3084
Additional Information 1: 4fff
Additional Information 2: 4ffff463368b3dfd72df454880e2db7b
Additional Information 3: 7d13
Additional Information 4: 7d13ba4dd69a42bd3d05e3c880d74b32
<p>I had a note hang up on me, then when I restarted Pegasus, I got the following: Mailbox is locked. &nbsp;This happens, so I press Continue and the Mailbox is locked panel becomes greyed out and behind it appears a standard Windows screen which says Pegasus for Windows has stopped working, that I can search for a solution online (yeah, right) or close the program. &nbsp;That, oddly enough, closes the program. &nbsp;So, I have a Mailbox is locked which persistently creates a Program has stopped working. &nbsp;There are no other options. &nbsp;The details are:</p><p>Problem signature:</p><p>Problem Event Name:<span class="Apple-tab-span" style="white-space:pre"> </span>BEX</p><p>Application Name:&nbsp;winpm-32.exe</p><p>Application Version:&nbsp;4.5.2.0</p><p>Application Timestamp:&nbsp;4b543cb5</p><p>Fault Module Name:&nbsp;winpm-32.exe</p><p>Fault Module Version:<span class="Apple-tab-span" style="white-space:pre"> </span>4.5.2.0</p><p>Fault Module Timestamp:&nbsp;4b543cb5</p><p>Exception Offset:&nbsp;0018b976</p><p>Exception Code:&nbsp;c0000417</p><p>Exception Data:<span class="Apple-tab-span" style="white-space:pre"> </span>00000000</p><p>OS Version:&nbsp;6.1.7601.2.1.0.768.3</p><p>Locale ID:&nbsp;3084</p><p>Additional Information 1:&nbsp;4fff</p><p>Additional Information 2:&nbsp;4ffff463368b3dfd72df454880e2db7b</p><p>Additional Information 3:&nbsp;7d13</p><p>Additional Information 4:&nbsp;7d13ba4dd69a42bd3d05e3c880d74b32</p><p>&nbsp;</p><p>&nbsp;&nbsp;</p>
