Weird problem in pegasus
Hi Thomas Thanks for the suggestion
But  the system font is already on normal, no large or extra large is selected.
thanks
kalu
<p>Hi Thomas Thanks for the suggestion </p><p>But  the system font is already on normal, no large or extra large is selected.</p><p>thanks</p><p>kalu </p>
Hello guys.
I have strange issue with my pegasus mail.
please don't ask me which version i'm using. please do not suggest me to upgrade it.
I just want to know if anybody has faced this problem before and would like to know how did you get rid of this.
picture speak more than thousand word. please see the attachment and pay particular attention to the buttons
thanks
kalu%20%20Uploaded%20with%20ImageShack.us" mce_src=" Uploaded with ImageShack.us">
<p>Hello guys.</p><p>I have strange issue with my pegasus mail.</p><p>please don't ask me which version i'm using. please do not suggest me to upgrade it.</p><p>I just want to know if anybody has faced this problem before and would like to know how did you get rid of this.</p><p>picture speak more than thousand word. please see the attachment and pay particular attention to the buttons</p><p> </p><p>thanks</p><p>kalu<img src="[URL=http://imageshack.us/photo/my-images/843/pmailscreen.jpg/][IMG]http://img843.imageshack.us/img843/8933/pmailscreen.jpg[/IMG][/URL]%20%20Uploaded%20with%20[URL=http://imageshack.us]ImageShack.us[/URL]" mce_src="[URL=http://imageshack.us/photo/my-images/843/pmailscreen.jpg/][IMG]http://img843.imageshack.us/img843/8933/pmailscreen.jpg[/IMG][/URL] Uploaded with [URL=http://imageshack.us]ImageShack.us[/URL]"> </p>
Funny - perhaps changed lettersize or dpi in windows? Aynway ...
  • stop Pegasus
  • Edit STATE.PMJ
  • Remove in Section [General] all lines with V4*=... and save them into another textfile
  • problem should be solved, but now all windowsizes and openingplaces are deleted
  • if so, you may overwrite all V4*-entries from saved textfile one by one (interim starting and stopping Pegasus) until the error occurs again. Then you know, which line is relevant for the error (/me don't know)
Happy testing [:)]
   Olaf
<p>Funny - perhaps changed lettersize or dpi in windows? Aynway ...</p><ul><li>stop Pegasus </li><li>Edit STATE.PMJ </li><li>Remove in Section [General] all lines with V4*=... and save them into another textfile</li><li>problem should be solved, but now all windowsizes and openingplaces are deleted</li><li>if so, you may overwrite all V4*-entries from saved textfile one by one (interim starting and stopping Pegasus) until the error occurs again. Then you know, which line is relevant for the error (/me don't know) </li></ul><p>Happy testing [:)]    Olaf</p><p>  </p>
[quote user="FJR"]Funny - perhaps changed lettersize or dpi in windows? Aynway ...
  • stop Pegasus
  • Edit STATE.PMJ
  • if so, you may overwrite all V4*-entries from saved textfile one by one (interim starting and stopping Pegasus) until the error occurs again. Then you know, which line is relevant for the error (/me don't know)[/quote]
I don't think this will help, it looks pretty much like a system font size setting issue of some kind - but then it should affect other applications as well.
[quote user="FJR"]Funny - perhaps changed lettersize or dpi in windows? Aynway ...<ul><li>stop Pegasus </li><li>Edit STATE.PMJ </li><li>Remove in Section [General] all lines with V4*=... and save them into another textfile</li><li>problem should be solved, but now all windowsizes and openingplaces are deleted</li><li>if so, you may overwrite all V4*-entries from saved textfile one by one (interim starting and stopping Pegasus) until the error occurs again. Then you know, which line is relevant for the error (/me don't know)[/quote]</li></ul><p>I don't think this will help, it looks pretty much like a system font size setting issue of some kind - but then it should affect other applications as well.</p>
Hi FJR
No, i have not changed lettersize or dpi in windows.
No Editing State.pmj didn't solved the problem.
i also tried with Pmail.ini (deleting it)
Neither one helped
thanks any way for your suggestion
kalu
<p>Hi FJR</p><p>No, i have not changed lettersize or dpi in windows. No Editing State.pmj didn't solved the problem. i also tried with Pmail.ini (deleting it)</p><p>Neither one helped</p><p>thanks any way for your suggestion</p><p>kalu </p>
hi idw
no, other applications are running fine. It's only with pegasusmail.
i tried upgrading it to Version 4.6. That didn't helped either.
thanks
kalu
<p>hi idw</p><p>no, other applications are running fine. It's only with pegasusmail. i tried upgrading it to Version 4.6. That didn't helped either.</p><p>thanks</p><p>kalu </p>
[quote user="kalu"]no, other applications are running fine. It's only with pegasusmail.[/quote]
Hmm ... I'm shure it's something in STATE.PMJ (it has been everytime I had problems with missing parts of subwindows in Pegasus). Is there any entry, where there is a minus in one of the coordinates?
Another idea: Temporrily change  resolution in windows, start Pegasus, stop it, switch resolution back and have a look at Pegasus and the configurationwindow. Sorry ... just try + error.
 bye   Olaf
<p>[quote user="kalu"]no, other applications are running fine. It's only with pegasusmail.[/quote] </p><p>Hmm ... I'm shure it's something in STATE.PMJ (it has been everytime I had problems with missing parts of subwindows in Pegasus). Is there any entry, where there is a minus in one of the coordinates? </p><p>Another idea: Temporrily change  resolution in windows, start Pegasus, stop it, switch resolution back and have a look at Pegasus and the configurationwindow. Sorry ... just try + error. </p><p> bye   Olaf</p><p> </p>
[quote user="FJR"]Hmm ... I'm shure it's something in STATE.PMJ (it has been everytime I had problems with missing parts of subwindows in Pegasus).[/quote]
Olaf, this applies only to Pegasus Mail's MDI windows (reader, editor, folder etc.), not to a standard Windows dialog as used by the window affected here (without very few exceptions, I believe the folder selection dialog for moving messages is one of these).
<p>[quote user="FJR"]Hmm ... I'm shure it's something in STATE.PMJ (it has been everytime I had problems with missing parts of subwindows in Pegasus).[/quote]</p><p>Olaf, this applies only to Pegasus Mail's MDI windows (reader, editor, folder etc.), not to a standard Windows dialog as used by the window affected here (without very few exceptions, I believe the folder selection dialog for moving messages is one of these).</p><p> </p>
> no, other applications are running fine. It's only with Pegasus Mail.
Try changing the system font back to normal instead of large fonts.
> no, other applications are running fine. It's only with Pegasus Mail. > i tried upgrading it to Version 4.6. That didn't helped either. Try changing the system font back to normal instead of large fonts.
