Mercury will not send mail in a virtual pc
Thanks for the help with login details. I forgot!
I am sure You have right about the bracket and that sort of things, But I can tell You, that without having changing anything, I can now send email to what ever address I will.
I dont understand what have happend, but now everything is working. also from magento!?
<p>Thanks for the help with login details. I forgot!</p><p> </p><p>I am sure You have right about the bracket and that sort of things, But I can tell You, that without having changing anything, I can now send email to what ever address I will.</p><p>I dont understand what have happend, but now everything is working. also from magento!?</p>
Hi!
 I am trying to setup mercury in a vmware workstation.
So far I have managed to receive mail from an outside ( realworld) mail.
But I can not send any mail.
My setup is :
Windows 7/64 client
Mercury/32 v4.73
no firewall.
I use MercuryC
Core config is: internet name ["192.168.177.176"],
local domain:localhost - localhost
localhost - [192.168.177.176]  (vmware ipadress)
localhost - local.com ( just a testsite for magento)
MercuryC config is:
smarthost name: my realworld ISP's SMTPserver
conn.port: 587 ( my realworld ISP's SMTPport)
I login via POP3 host
I get this error code: 550.5.1.8 sending non-local domain not allowed, see http://postmast
and this error code: Error FF servicing queue job
Habe anyone any idea, what is wrong?
in advance thanks
<p>Hi!</p><p> I am trying to setup mercury in a vmware workstation.</p><p>So far I have managed to receive mail from an outside ( realworld) mail.</p><p>But I can not send any mail.</p><p>My setup is :</p><p>Windows 7/64 client</p><p>Mercury/32 v4.73 </p><p>no firewall.</p><p>I use MercuryC</p><p>Core config is: internet name ["192.168.177.176"], </p><p>local domain:localhost - localhost</p><p>localhost - [192.168.177.176]  (vmware ipadress)</p><p>localhost - local.com ( just a testsite for magento)</p><p>MercuryC config is:</p><p>smarthost name: my realworld ISP's SMTPserver</p><p>conn.port: 587 ( my realworld ISP's SMTPport)</p><p>I login via POP3 host </p><p>I get this error code: 550.5.1.8 sending non-local domain not allowed, see <a href="http://postmast">http://postmast</a></p><p>and this error code: Error FF servicing queue job</p><p>Habe anyone any idea, what is wrong?</p><p>in advance thanks</p>
> I use MercuryC
> MercuryC config is:
Set MercuryC to do session logging and then post the session log showing the failure.  Munge any passwords in the file.
> I use MercuryC > > Core config is: internet name ["192.168.177.176"], > > local domain:localhost - localhost > > localhost - [192.168.177.176]  (vmware ipadress) > > localhost - local.com ( just a testsite for magento) > > MercuryC config is: > > smarthost name: my realworld ISP's SMTPserver > > conn.port: 587 ( my realworld ISP's SMTPport) > > I login via POP3 host > > I get this error code: 550.5.1.8 sending non-local domain not allowed, see http://postmast > > and this error code: Error FF servicing queue job > > Habe anyone any idea, what is wrong? Set MercuryC to do session logging and then post the session log showing the failure.  Munge any passwords in the file.
[quote user="Fixfinn"]
in advance thanks
It seems your ISP mail server is telling you that you are not allowed to relay mail through it with another MAIL FROM: domain name.
You should talk to them about their policies & your requirements.
[quote user="Fixfinn"]<p>I get this error code: 550.5.1.8 sending non-local domain not allowed, see http://postmast</p><p>and this error code: Error FF servicing queue job</p><p>Habe anyone any idea, what is wrong?</p><p>in advance thanks</p><p>[/quote]</p><p>It seems your ISP mail server is telling you that you are not allowed to relay mail through it with another MAIL FROM: domain name.</p><p>You should talk to them about their policies & your requirements. </p>
Hi!
The logfile looks like this:
E 20111129 221536 1a98 Connection error during handshake with mamutmail.com.
E 20111129 221536 1a98 Error connecting to mamutmail.com.
E 20111129 221622 1a98 Connection error during handshake with mamutmail.com.
E 20111129 221622 1a98 Error connecting to mamutmail.com.
****THIS ONE WITH ANOTHER ISP*******
T 20111129 222031 1a98 Begin processing job MO000001 from postmaster@[]
W 20111129 222032 1a98 451 4.1.8 [] not found in dns, se venligst http://postmaster.tdc.dk/publish.php?
T 20111129 222032 1a98 Begin processing job MO000004 from postmaster@[]
T 20111129 222032 1a98 Begin processing job MO000023 from postmaster@[]
T 20111129 222032 1a98 Job MO000023 from postmaster@[] processed OK.
T 20111129 222032 1a98 Begin processing job MO000024 from postmaster@[]
T 20111129 222032 1a98 Job MO000024 from postmaster@[] processed OK.
T 20111129 222032 1a98 Begin processing job MO000025 from postmaster@[]
T 20111129 222032 1a98 Job MO000025 from postmaster@[] processed OK.
T 20111129 222032 1a98 Begin processing job MO000026 from postmaster@[]
W 20111129 222032 1a98 421 4.5.1 No more messages on this connection, se venligst http://postmaster.tdc
T 20111129 222032 1a98 Begin processing job MO000027 from postmaster@[]
E 20111129 222032 1a98 TCP/IP error.
I tried to configure MercC again with a different result. I also tried with another ISP.
I have no problems receivinbg mails, just sending it
Thanks for the reply
<p>Hi!</p><p> </p><p>The logfile looks like this:</p><p>E 20111129 221536 1a98 Connection error during handshake with mamutmail.com. E 20111129 221536 1a98 Error connecting to mamutmail.com. E 20111129 221622 1a98 Connection error during handshake with mamutmail.com. E 20111129 221622 1a98 Error connecting to mamutmail.com. ****THIS ONE WITH ANOTHER ISP******* T 20111129 222031 1a98 Begin processing job MO000001 from postmaster@[] W 20111129 222032 1a98 451 4.1.8 [] not found in dns, se venligst http://postmaster.tdc.dk/publish.php? T 20111129 222032 1a98 Begin processing job MO000004 from postmaster@[] W 20111129 222032 1a98 451 4.1.8 [] not found in dns, se venligst http://postmaster.tdc.dk/publish.php? T 20111129 222032 1a98 Begin processing job MO000023 from postmaster@[] T 20111129 222032 1a98 Job MO000023 from postmaster@[] processed OK. T 20111129 222032 1a98 Begin processing job MO000024 from postmaster@[] T 20111129 222032 1a98 Job MO000024 from postmaster@[] processed OK. T 20111129 222032 1a98 Begin processing job MO000025 from postmaster@[] T 20111129 222032 1a98 Job MO000025 from postmaster@[] processed OK. T 20111129 222032 1a98 Begin processing job MO000026 from postmaster@[] W 20111129 222032 1a98 421 4.5.1 No more messages on this connection, se venligst http://postmaster.tdc T 20111129 222032 1a98 Begin processing job MO000027 from postmaster@[] E 20111129 222032 1a98 TCP/IP error. </p><p>I tried to configure MercC again with a different result. I also tried with another ISP.</p><p>I have no problems receivinbg mails, just sending it</p><p> </p><p>Thanks for the reply</p><p> </p><p> </p>
Please temporarily switch on session logging, which is not the same as normal MercuryC logging. This will give a much more detailed log showing every single line that is sent to and from the external server. As Thomas already said you need to censor the lines with login name and password before posting!
I would definitely use some better values for hostname and local domains as well. If there actually are quotation marks in the Core hostname they will have to be removed. Furthermore, using a private LAN IP address as hostname when communicating externally is probably not a good idea.
<p>Please temporarily switch on session logging, which is not the same as normal MercuryC logging. This will give a much more detailed log showing every single line that is sent to and from the external server. As Thomas already said you need to censor the lines with login name and password before posting!</p><p>I would definitely use some better values for hostname and local domains as well. If there actually are quotation marks in the Core hostname they will have to be removed. Furthermore, using a private LAN IP address as hostname when communicating externally is probably not a good idea.</p><p>/Rolf </p>
W 20111129 222032 1a98 451 4.1.8 [] not found in dns, se venligst http://postmaster.tdc.dk/publish.php?[/quote]
That's not the session log. Anyway ...
It seems your ISPs (like most good ISPs today) do a (reverse) lookup on hostname used in HELO/EHLO as one check ensuring it's a "good" host. You have set hostname to a private IP which for shure can't be found in DNS. Due to that they cancel the connection (first) or send an error message and because Mercury tries sending the other messages on and on closes the connection (second).
cheers    Olaf
<p>[quote user="Fixfinn"] E 20111129 221536 1a98 Connection error during handshake with mamutmail.com. E 20111129 221536 1a98 Error connecting to mamutmail.com. ****THIS ONE WITH ANOTHER ISP******* T 20111129 222031 1a98 Begin processing job MO000001 from postmaster@[] W 20111129 222032 1a98 451 4.1.8 [] not found in dns, se venligst http://postmaster.tdc.dk/publish.php?[/quote]</p><p>That's not the session log. Anyway ...</p><p>It seems your ISPs (like most good ISPs today) do a (reverse) lookup on hostname used in HELO/EHLO as one check ensuring it's a "good" host. You have set hostname to a private IP which for shure can't be found in DNS. Due to that they cancel the connection (first) or send an error message and because Mercury tries sending the other messages on and on closes the connection (second).</p><p>cheers    Olaf</p><p> </p>
Hi, Thanks for the answer
I try again.
Core config is: internet name 87.57.133.33,
localhost - [87.57.133.33] (dynamic ipadress from ISP)
MercuryC config is:
Actually, with this I can send testmessage from mercury, but I still get errors!?
I am using this for a testsite in magento and need to test mail sending from the system before I go live!
Here is the sessions log from mercuryC:
20:34:21.796: --- Wed Nov 30 20:34:21 2011 ---
20:34:22.796: Connect to 'asmtp.mail.dk', timeout 30.
20:34:23.921: >> 220 Welcome to asmtp.mail.dk!<cr><lf>
20:34:23.921: << EHLO 87.57.133.33<cr><lf>
20:34:23.953: >> 250-fep41.mail.dk says EHLO to 87.57.135.17:23780<cr><lf>
20:34:23.968: >> 250-PIPELINING<cr><lf>
20:34:23.968: >> 250-ENHANCEDSTATUSCODES<cr><lf>
20:34:23.968: >> 250-AUTH=PLAIN LOGIN<cr><lf>
20:34:23.968: >> 250-AUTH PLAIN LOGIN<cr><lf>
20:34:23.968: >> 250 8BITMIME<cr><lf>
20:34:23.968: << AUTH LOGIN<cr><lf>
// removed !!!!
20:34:23.125: >> 235 Authed. Go on.<cr><lf>
20:34:23.125: << MAIL FROM:<yyy@yy.yy><cr><lf>
20:34:23.296: >> 250 MAIL FROM accepted<cr><lf>
20:34:23.296: << RCPT TO:<Admin@87.57.133.33><cr><lf>
20:34:23.359: >> 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421<cr><lf>
20:34:23.375: << RSET<cr><lf>
20:34:23.390: >> 250 RSET OK<cr><lf>
20:34:23.390: << MAIL FROM:<yyy@yy.yy><cr><lf>
20:34:23.421: >> 250 MAIL FROM accepted<cr><lf>
20:34:23.421: << RCPT TO:<Admin@87.57.133.33><cr><lf>
20:34:23.453: >> 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421<cr><lf>
20:34:23.468: << RSET<cr><lf>
20:34:23.500: >> 250 RSET OK<cr><lf>
20:34:23.500: << MAIL FROM:<yyy@yy.yy><cr><lf>
20:34:23.531: >> 250 MAIL FROM accepted<cr><lf>
20:34:23.531: << RCPT TO:<Admin@87.57.133.33><cr><lf>
20:34:23.562: >> 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421<cr><lf>
20:34:23.578: << RSET<cr><lf>
20:34:23.593: >> 250 RSET OK<cr><lf>
20:34:23.609: << MAIL FROM:<yyy@yy.yy><cr><lf>
20:34:23.640: >> 250 MAIL FROM accepted<cr><lf>
20:34:23.640: << RCPT TO:<Admin@87.57.133.33><cr><lf>
20:34:23.671: >> 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421<cr><lf>
20:34:23.687: << RSET<cr><lf>
20:34:23.703: >> 250 RSET OK<cr><lf>
20:34:23.703: << MAIL FROM:<yyy@yy.yy><cr><lf>
20:34:23.734: >> 250 MAIL FROM accepted<cr><lf>
20:34:23.750: << RCPT TO:<Admin@87.57.133.33><cr><lf>
20:34:23.765: >> 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421<cr><lf>
20:34:23.796: << RSET<cr><lf>
20:34:24.812: >> 250 RSET OK<cr><lf>
20:34:24.812: << MAIL FROM:<yyy@yy.yy><cr><lf>
20:34:24.843: >> 250 MAIL FROM accepted<cr><lf>
20:34:24.859: << RCPT TO:<Admin@87.57.133.33><cr><lf>
20:34:24.875: >> 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421<cr><lf>
20:34:24.890: << RSET<cr><lf>
20:34:24.921: >> 250 RSET OK<cr><lf>
20:34:24.921: << MAIL FROM:<yyy@yy.yy><cr><lf>
20:34:24.953: >> 250 MAIL FROM accepted<cr><lf>
20:34:24.953: << RCPT TO:<Admin@87.57.133.33><cr><lf>
20:34:24.984: >> 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421<cr><lf>
20:34:24.015: << RSET<cr><lf>
20:34:24.046: >> 250 RSET OK<cr><lf>
20:34:24.046: << MAIL FROM:<yyy@yy.yy><cr><lf>
20:34:24.078: >> 250 MAIL FROM accepted<cr><lf>
20:34:24.078: << RCPT TO:<Admin@87.57.133.33><cr><lf>
20:34:24.109: >> 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421<cr><lf>
20:34:24.125: << RSET<cr><lf>
20:34:24.156: >> 250 RSET OK<cr><lf>
20:34:24.156: << MAIL FROM:<yyy@yy.yy><cr><lf>
20:34:24.187: >> 250 MAIL FROM accepted<cr><lf>
20:34:24.187: << RCPT TO:<Admin@87.57.133.33><cr><lf>
20:34:24.218: >> 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421<cr><lf>
20:34:24.234: << RSET<cr><lf>
20:34:24.265: >> 250 RSET OK<cr><lf>
20:34:24.265: << MAIL FROM:<yyy@yy.yy><cr><lf>
20:34:24.296: >> 250 MAIL FROM accepted<cr><lf>
20:34:24.296: << RCPT TO:<Admin@87.57.133.33><cr><lf>
20:34:24.328: >> 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421<cr><lf>
20:34:24.343: << RSET<cr><lf>
20:34:24.375: >> 250 RSET OK<cr><lf>
20:34:24.375: << MAIL FROM:<yyy@yy.yy><cr><lf>
20:34:24.406: >> 250 MAIL FROM accepted<cr><lf>
20:34:24.406: << RCPT TO:<Admin@87.57.133.33><cr><lf>
20:34:24.437: >> 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421<cr><lf>
20:34:24.453: << RSET<cr><lf>
20:34:24.484: >> 250 RSET OK<cr><lf>
20:34:24.484: << MAIL FROM:<yyy@yy.yy><cr><lf>
20:34:24.515: >> 250 MAIL FROM accepted<cr><lf>
20:34:24.515: << RCPT TO:<Admin@87.57.133.33><cr><lf>
20:34:24.546: >> 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421<cr><lf>
20:34:24.562: << RSET<cr><lf>
20:34:24.593: >> 250 RSET OK<cr><lf>
20:34:24.593: << MAIL FROM:<yyy@yy.yy><cr><lf>
20:34:24.625: >> 250 MAIL FROM accepted<cr><lf>
20:34:24.625: << RCPT TO:<xxx@xx.xx><cr><lf>
20:34:24.656: >> 250 RCPT TO accepted<cr><lf>
20:34:24.671: << DATA<cr><lf>
20:34:24.687: >> 354 continue. finished with "\r\n.\r\n"<cr><lf>
20:34:24.703: << Received: from Spooler by 87.57.133.33 (Mercury/32 v4.73) ID MO000029;<cr><lf> 30 Nov 2011 20:34:24 +0100<cr><lf>
20:34:24.703: << Received: from spooler by ["192.168.177.176"] (Mercury/32 v4.73); 23 Nov 2011 21:15:40 +0100<cr><lf>
20:34:24.703: << From: "E-Mail Administrator" <postmaster@["192.168.177.176"]><cr><lf>
20:34:24.703: << To: xxx@xx.xx<cr><lf>
20:34:24.703: << Subject: test<cr><lf>
20:34:24.703: << Date: Wed, 23 Nov 2011 21:15:37 +0100<cr><lf>
20:34:24.718: << MIME-Version: 1.0<cr><lf>
20:34:24.718: << Content-type: Text/plain; charset=US-ASCII<cr><lf>
20:34:24.718: << Message-ID: <C0D4FE7.4ECD627C.0009@["192.168.177.176"]><cr><lf>
20:34:24.718: << <cr><lf>
20:34:24.718: << the product currently ran agencies going building sites agencies code legitimate <cr><lf>
20:34:24.718: << The files vulnerable taking that attacks patches and also there need asked <cr><lf>
20:34:24.734: << and hundred attacks ubiquitous north attacks attacks north strings malicious <cr><lf>
20:34:24.734: << that to are The helps welcome and injected hundred are vulnerable as across <cr><lf>
20:34:24.734: << <cr><lf>
20:34:24.734: << in to to longest hundred patches also no institutions vulnerable dedicate <cr><lf>
20:34:24.734: << building quick hundred ran welcome in across to security technique institutions <cr><lf>
20:34:24.734: << organizations bugs files also institutions to there haunted are and reside <cr><lf>
20:34:24.750: << into other the financial that making patches range comprehensive are need <cr><lf>
20:34:24.750: << attacks system for institutions are technique ran agencies making security <cr><lf>
20:34:24.750: << currently comprehensive to attacks patches no injected security vulnerable <cr><lf>
20:34:24.750: << <cr><lf>
20:34:24.750: << by ubiquitous in into which known applets haunted the building ran operated <cr><lf>
20:34:24.750: << patches movies organizations movies other welcome bugs building dedicate <cr><lf>
20:34:24.750: << Internet dedicate for security product reside The ubiquitous institutions <cr><lf>
20:34:24.750: << currently sites sites vulnerable quick going that taking hundred no product <cr><lf>
20:34:24.750: << are and files scripting are helps code helps need ubiquitous through by <cr><lf>
20:34:24.750: << graphics going helps found blocks other asked organizations the are taking <cr><lf>
20:34:24.765: << agencies security graphics and financial are dedicate blocks code range <cr><lf>
20:34:24.765: << <cr><lf>
20:34:24.765: << taking making currently found product need there movies security The sites <cr><lf>
20:34:24.765: << haunted range asked the files injected malicious range bugs into across <cr><lf>
20:34:24.765: << files attacks product the also bugs to The vulnerable security bugs The <cr><lf>
20:34:24.765: << currently which need asked as malicious quick scripting are asked taking <cr><lf>
20:34:24.765: << currently to dedicate are taking in also by strings currently also haunted <cr><lf>
20:34:24.765: << into asked scripting strings patches financial going that bugs free in <cr><lf>
20:34:24.765: << ran agencies injected attacks government code ubiquitous attacks ran bugs <cr><lf>
20:34:24.765: << which north they them making found helps product building operated injected <cr><lf>
20:34:24.765: << in scripting are agencies and making Internet are sites graphics them graphics <cr><lf>
20:34:24.781: << need the helps strings into hundred The to in found applets going institutions <cr><lf>
20:34:24.781: << no in going blocks across which as operated animate security system hundred <cr><lf>
20:34:24.781: << <cr><lf>
20:34:24.781: << them applets Internet also into longest other vulnerable them through Internet <cr><lf>
20:34:24.781: << longest by there operated need the need there <cr><lf>
20:34:24.781: << .<cr><lf>
20:34:25.875: >> 250 OK A0/50-11301-14586DE4<cr><lf>
20:34:25.875: << RSET<cr><lf>
20:34:25.906: >> 250 RSET OK<cr><lf>
20:34:25.906: << MAIL FROM:<yyy@yy.yy><cr><lf>
20:34:25.937: >> 250 MAIL FROM accepted<cr><lf>
20:34:25.937: << RCPT TO:<xxx@xx.xx><cr><lf>
20:34:25.968: >> 250 RCPT TO accepted<cr><lf>
20:34:25.968: << DATA<cr><lf>
20:34:25.000: >> 354 continue. finished with "\r\n.\r\n"<cr><lf>
20:34:25.000: << Received: from Spooler by 87.57.133.33 (Mercury/32 v4.73) ID MO00002A;<cr><lf> 30 Nov 2011 20:34:25 +0100<cr><lf>
20:34:25.015: << Received: from spooler by ["192.168.177.176"] (Mercury/32 v4.73); 23 Nov 2011 21:15:40 +0100<cr><lf>
20:34:25.015: << From: "E-Mail Administrator" <postmaster@["192.168.177.176"]><cr><lf>
20:34:25.015: << To: xxx@xx.xx<cr><lf>
20:34:25.015: << Subject: test<cr><lf>
20:34:25.015: << Date: Wed, 23 Nov 2011 21:15:37 +0100<cr><lf>
20:34:25.031: << MIME-Version: 1.0<cr><lf>
20:34:25.031: << Content-type: Text/plain; charset=US-ASCII<cr><lf>
20:34:25.031: << Message-ID: <C0D5026.4ECD627C.000A@["192.168.177.176"]><cr><lf>
20:34:25.031: << <cr><lf>
20:34:25.031: << found found graphics technique building agencies by vulnerable reside found <cr><lf>
20:34:25.046: << ubiquitous asked scripting technique ubiquitous welcome security welcome <cr><lf>
20:34:25.046: << <cr><lf>
20:34:25.046: << in agencies helps blocks through by which to are system across the are <cr><lf>
20:34:25.046: << and no as ran across in comprehensive ran files quick malicious security <cr><lf>
20:34:25.046: << them reside ubiquitous to vulnerable ubiquitous attacks currently security <cr><lf>
20:34:25.046: << patches operated no to vulnerable legitimate ubiquitous code north range <cr><lf>
20:34:25.062: << comprehensive are other applets The system which technique making asked <cr><lf>
20:34:25.062: << legitimate security making the product across are files other animate Internet <cr><lf>
20:34:25.062: << <cr><lf>
20:34:25.078: << files organizations files ubiquitous are graphics and in hundred institutions <cr><lf>
20:34:25.078: << <cr><lf>
20:34:25.078: << quick into sites patches are reside asked injected agencies hundred need <cr><lf>
20:34:25.093: << north range making found also going building and are ran security graphics <cr><lf>
20:34:25.093: << them strings vulnerable and product scripting malicious and comprehensive <cr><lf>
20:34:25.093: << injected range reside comprehensive code in The and into currently The <cr><lf>
20:34:25.093: << quick as currently taking asked across helps technique across animate agencies <cr><lf>
20:34:25.093: << and government which them The by financial building the to injected dedicate <cr><lf>
20:34:25.093: << helps patches injected product comprehensive the blocks asked attacks there <cr><lf>
20:34:25.093: << <cr><lf>
20:34:25.093: << patches product to are comprehensive dedicate going found sites as into <cr><lf>
20:34:25.093: << building legitimate no range and blocks the other free through patches <cr><lf>
20:34:25.093: << into for graphics The comprehensive scripting haunted other through north <cr><lf>
20:34:25.093: << in north in across that need known hundred as blocks they The free helps <cr><lf>
20:34:25.109: << security taking in ran range building in the graphics which by the asked <cr><lf>
20:34:25.109: << by patches ran building and which going injected animate ubiquitous blocks <cr><lf>
20:34:25.109: << also haunted institutions which which welcome helps ubiquitous organizations <cr><lf>
20:34:25.109: << making through that legitimate injected operated found by that found making <cr><lf>
20:34:25.109: << <cr><lf>
20:34:25.109: << animate quick scripting they are no security to blocks found ran hundred <cr><lf>
20:34:25.109: << they haunted also animate graphics sites them government dedicate for attacks <cr><lf>
20:34:25.109: << asked also and in ran they welcome making animate patches reside attacks <cr><lf>
20:34:25.109: << the bugs code haunted dedicate hundred making as organizations quick which <cr><lf>
20:34:25.109: << found as as attacks technique also are free scripting comprehensive scripting <cr><lf>
20:34:25.109: << .<cr><lf>
20:34:25.203: >> 250 OK B0/50-11301-24586DE4<cr><lf>
20:34:25.218: << RSET<cr><lf>
20:34:25.250: >> 250 RSET OK<cr><lf>
20:34:25.250: << MAIL FROM:<yyy@yy.yy><cr><lf>
20:34:25.281: >> 250 MAIL FROM accepted<cr><lf>
20:34:25.281: << RCPT TO:<xxx@xx.xx><cr><lf>
20:34:25.312: >> 250 RCPT TO accepted<cr><lf>
20:34:25.328: << DATA<cr><lf>
20:34:25.359: >> 354 continue. finished with "\r\n.\r\n"<cr><lf>
20:34:25.359: << Received: from Spooler by 87.57.133.33 (Mercury/32 v4.73) ID MO00002E;<cr><lf> 30 Nov 2011 20:34:25 +0100<cr><lf>
20:34:25.359: << Received: from spooler by ["192.168.177.176"] (Mercury/32 v4.73); 23 Nov 2011 21:15:40 +0100<cr><lf>
20:34:25.359: << From: "E-Mail Administrator" <postmaster@["192.168.177.176"]><cr><lf>
20:34:25.375: << To: xxx@xx.xx<cr><lf>
20:34:25.375: << Subject: test<cr><lf>
20:34:25.375: << Date: Wed, 23 Nov 2011 21:15:37 +0100<cr><lf>
20:34:25.375: << MIME-Version: 1.0<cr><lf>
20:34:25.375: << Content-type: Text/plain; charset=US-ASCII<cr><lf>
20:34:25.375: << Message-ID: <C0D51AC.4ECD627C.000E@["192.168.177.176"]><cr><lf>
20:34:25.375: << <cr><lf>
20:34:25.375: << reside blocks technique there found the asked the range operated known <cr><lf>
20:34:25.375: << currently they them patches the bugs helps institutions the security organizations <cr><lf>
20:34:25.390: << haunted helps animate the ran in and hundred movies that animate ubiquitous <cr><lf>
20:34:25.390: << institutions building as need no other dedicate and animate strings across <cr><lf>
20:34:25.390: << <cr><lf>
20:34:25.390: << malicious welcome by currently ran currently helps for for across and asked <cr><lf>
20:34:25.390: << known to haunted vulnerable technique institutions product product graphics <cr><lf>
20:34:25.390: << technique patches range to sites no into ran graphics movies for dedicate <cr><lf>
20:34:25.390: << in making they injected taking there quick ran institutions them asked <cr><lf>
20:34:25.390: << scripting there organizations legitimate there government which vulnerable <cr><lf>
20:34:25.406: << security the ran no comprehensive across organizations free by bugs reside <cr><lf>
20:34:25.406: << government patches making institutions also graphics animate by comprehensive <cr><lf>
20:34:25.406: << currently government and free taking the injected quick haunted code graphics <cr><lf>
20:34:25.406: << product north haunted product ran currently vulnerable haunted animate <cr><lf>
20:34:25.406: << <cr><lf>
20:34:25.406: << across scripting by scripting comprehensive vulnerable blocks that ran <cr><lf>
20:34:25.406: << haunted asked range animate scripting applets are and security patches <cr><lf>
20:34:25.406: << found free north found quick for legitimate blocks also asked which comprehensive <cr><lf>
20:34:25.421: << the code haunted ran The range the into applets need organizations through <cr><lf>
20:34:25.421: << making legitimate quick The and ran making technique security to making <cr><lf>
20:34:25.421: << <cr><lf>
20:34:25.421: << quick taking blocks currently which need helps across injected them and <cr><lf>
20:34:25.421: << they system Internet product sites in making building malicious legitimate <cr><lf>
20:34:25.421: << are <cr><lf>
20:34:25.421: << .<cr><lf>
20:34:25.500: >> 250 OK D0/50-11301-24586DE4<cr><lf>
20:34:25.515: << RSET<cr><lf>
20:34:25.546: >> 250 RSET OK<cr><lf>
20:34:25.546: << MAIL FROM:<yyy@yy.yy><cr><lf>
20:34:25.578: >> 421 4.5.1 No more messages on this connection, se venligst http://postmaster.tdc.dk/publish.php?id=23413<cr><lf>
20:34:25.593: << RSET<cr><lf>
20:34:25.609: << QUIT<cr><lf>
20:34:25.609: --- Connection closed normally at Wed Nov 30 20:34:25 2011. ---
20:34:25.609:
&lt;p&gt;Hi, Thanks for the answer&lt;/p&gt;&lt;p&gt;I try again.&lt;/p&gt;&lt;p&gt;Core config is: internet name 87.57.133.33,&amp;nbsp; local domain:localhost - localhost localhost - [87.57.133.33] (dynamic ipadress from ISP) localhost - local.com ( just a testsite for magento) MercuryC config is: smarthost name: my realworld ISP&#039;s SMTPserver conn.port: 587 ( my realworld ISP&#039;s SMTPport)&lt;/p&gt;&lt;p&gt; &lt;/p&gt;&lt;p&gt;Actually, with this I can send testmessage from mercury, but I still get errors!?&lt;/p&gt;&lt;p&gt; &lt;/p&gt;&lt;p&gt;I am using this for a testsite in magento and need to test mail sending from the system before I go live! &lt;/p&gt;&lt;p&gt; &lt;/p&gt;&lt;p&gt;Here is the sessions log from mercuryC:&lt;/p&gt;&lt;p&gt;20:34:21.796: --- Wed Nov 30 20:34:21 2011 --- 20:34:22.796: Connect to &#039;asmtp.mail.dk&#039;, timeout 30. 20:34:23.921: &amp;gt;&amp;gt; 220 Welcome to asmtp.mail.dk!&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:23.921: &amp;lt;&amp;lt; EHLO 87.57.133.33&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:23.953: &amp;gt;&amp;gt; 250-fep41.mail.dk says EHLO to 87.57.135.17:23780&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:23.968: &amp;gt;&amp;gt; 250-PIPELINING&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:23.968: &amp;gt;&amp;gt; 250-ENHANCEDSTATUSCODES&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:23.968: &amp;gt;&amp;gt; 250-AUTH=PLAIN LOGIN&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:23.968: &amp;gt;&amp;gt; 250-AUTH PLAIN LOGIN&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:23.968: &amp;gt;&amp;gt; 250 8BITMIME&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:23.968: &amp;lt;&amp;lt; AUTH LOGIN&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; // removed !!!! 20:34:23.125: &amp;gt;&amp;gt; 235 Authed. Go on.&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:23.125: &amp;lt;&amp;lt; MAIL FROM:&amp;lt;yyy@yy.yy&amp;gt;&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:23.296: &amp;gt;&amp;gt; 250 MAIL FROM accepted&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:23.296: &amp;lt;&amp;lt; RCPT TO:&amp;lt;Admin@87.57.133.33&amp;gt;&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:23.359: &amp;gt;&amp;gt; 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:23.375: &amp;lt;&amp;lt; RSET&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:23.390: &amp;gt;&amp;gt; 250 RSET OK&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:23.390: &amp;lt;&amp;lt; MAIL FROM:&amp;lt;yyy@yy.yy&amp;gt;&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:23.421: &amp;gt;&amp;gt; 250 MAIL FROM accepted&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:23.421: &amp;lt;&amp;lt; RCPT TO:&amp;lt;Admin@87.57.133.33&amp;gt;&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:23.453: &amp;gt;&amp;gt; 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:23.468: &amp;lt;&amp;lt; RSET&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:23.500: &amp;gt;&amp;gt; 250 RSET OK&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:23.500: &amp;lt;&amp;lt; MAIL FROM:&amp;lt;yyy@yy.yy&amp;gt;&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:23.531: &amp;gt;&amp;gt; 250 MAIL FROM accepted&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:23.531: &amp;lt;&amp;lt; RCPT TO:&amp;lt;Admin@87.57.133.33&amp;gt;&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:23.562: &amp;gt;&amp;gt; 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:23.578: &amp;lt;&amp;lt; RSET&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:23.593: &amp;gt;&amp;gt; 250 RSET OK&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:23.609: &amp;lt;&amp;lt; MAIL FROM:&amp;lt;yyy@yy.yy&amp;gt;&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:23.640: &amp;gt;&amp;gt; 250 MAIL FROM accepted&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:23.640: &amp;lt;&amp;lt; RCPT TO:&amp;lt;Admin@87.57.133.33&amp;gt;&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:23.671: &amp;gt;&amp;gt; 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:23.687: &amp;lt;&amp;lt; RSET&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:23.703: &amp;gt;&amp;gt; 250 RSET OK&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:23.703: &amp;lt;&amp;lt; MAIL FROM:&amp;lt;yyy@yy.yy&amp;gt;&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:23.734: &amp;gt;&amp;gt; 250 MAIL FROM accepted&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:23.750: &amp;lt;&amp;lt; RCPT TO:&amp;lt;Admin@87.57.133.33&amp;gt;&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:23.765: &amp;gt;&amp;gt; 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:23.796: &amp;lt;&amp;lt; RSET&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.812: &amp;gt;&amp;gt; 250 RSET OK&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.812: &amp;lt;&amp;lt; MAIL FROM:&amp;lt;yyy@yy.yy&amp;gt;&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.843: &amp;gt;&amp;gt; 250 MAIL FROM accepted&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.859: &amp;lt;&amp;lt; RCPT TO:&amp;lt;Admin@87.57.133.33&amp;gt;&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.875: &amp;gt;&amp;gt; 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.890: &amp;lt;&amp;lt; RSET&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.921: &amp;gt;&amp;gt; 250 RSET OK&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.921: &amp;lt;&amp;lt; MAIL FROM:&amp;lt;yyy@yy.yy&amp;gt;&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.953: &amp;gt;&amp;gt; 250 MAIL FROM accepted&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.953: &amp;lt;&amp;lt; RCPT TO:&amp;lt;Admin@87.57.133.33&amp;gt;&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.984: &amp;gt;&amp;gt; 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.015: &amp;lt;&amp;lt; RSET&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.046: &amp;gt;&amp;gt; 250 RSET OK&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.046: &amp;lt;&amp;lt; MAIL FROM:&amp;lt;yyy@yy.yy&amp;gt;&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.078: &amp;gt;&amp;gt; 250 MAIL FROM accepted&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.078: &amp;lt;&amp;lt; RCPT TO:&amp;lt;Admin@87.57.133.33&amp;gt;&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.109: &amp;gt;&amp;gt; 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.125: &amp;lt;&amp;lt; RSET&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.156: &amp;gt;&amp;gt; 250 RSET OK&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.156: &amp;lt;&amp;lt; MAIL FROM:&amp;lt;yyy@yy.yy&amp;gt;&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.187: &amp;gt;&amp;gt; 250 MAIL FROM accepted&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.187: &amp;lt;&amp;lt; RCPT TO:&amp;lt;Admin@87.57.133.33&amp;gt;&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.218: &amp;gt;&amp;gt; 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.234: &amp;lt;&amp;lt; RSET&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.265: &amp;gt;&amp;gt; 250 RSET OK&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.265: &amp;lt;&amp;lt; MAIL FROM:&amp;lt;yyy@yy.yy&amp;gt;&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.296: &amp;gt;&amp;gt; 250 MAIL FROM accepted&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.296: &amp;lt;&amp;lt; RCPT TO:&amp;lt;Admin@87.57.133.33&amp;gt;&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.328: &amp;gt;&amp;gt; 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.343: &amp;lt;&amp;lt; RSET&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.375: &amp;gt;&amp;gt; 250 RSET OK&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.375: &amp;lt;&amp;lt; MAIL FROM:&amp;lt;yyy@yy.yy&amp;gt;&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.406: &amp;gt;&amp;gt; 250 MAIL FROM accepted&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.406: &amp;lt;&amp;lt; RCPT TO:&amp;lt;Admin@87.57.133.33&amp;gt;&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.437: &amp;gt;&amp;gt; 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.453: &amp;lt;&amp;lt; RSET&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.484: &amp;gt;&amp;gt; 250 RSET OK&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.484: &amp;lt;&amp;lt; MAIL FROM:&amp;lt;yyy@yy.yy&amp;gt;&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.515: &amp;gt;&amp;gt; 250 MAIL FROM accepted&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.515: &amp;lt;&amp;lt; RCPT TO:&amp;lt;Admin@87.57.133.33&amp;gt;&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.546: &amp;gt;&amp;gt; 451 4.1.8 87.57.133.33 not found in dns, se venligst http://postmaster.tdc.dk/publish.php?id=23421&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.562: &amp;lt;&amp;lt; RSET&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.593: &amp;gt;&amp;gt; 250 RSET OK&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.593: &amp;lt;&amp;lt; MAIL FROM:&amp;lt;yyy@yy.yy&amp;gt;&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.625: &amp;gt;&amp;gt; 250 MAIL FROM accepted&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.625: &amp;lt;&amp;lt; RCPT TO:&amp;lt;xxx@xx.xx&amp;gt;&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.656: &amp;gt;&amp;gt; 250 RCPT TO accepted&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.671: &amp;lt;&amp;lt; DATA&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.687: &amp;gt;&amp;gt; 354 continue. finished with &quot;\r\n.\r\n&quot;&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.703: &amp;lt;&amp;lt; Received: from Spooler by 87.57.133.33 (Mercury/32 v4.73) ID MO000029;&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 30 Nov 2011 20:34:24 +0100&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.703: &amp;lt;&amp;lt; Received: from spooler by [&quot;192.168.177.176&quot;] (Mercury/32 v4.73); 23 Nov 2011 21:15:40 +0100&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.703: &amp;lt;&amp;lt; From: &quot;E-Mail Administrator&quot; &amp;lt;postmaster@[&quot;192.168.177.176&quot;]&amp;gt;&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.703: &amp;lt;&amp;lt; To: xxx@xx.xx&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.703: &amp;lt;&amp;lt; Subject: test&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.703: &amp;lt;&amp;lt; Date: Wed, 23 Nov 2011 21:15:37 +0100&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.718: &amp;lt;&amp;lt; MIME-Version: 1.0&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.718: &amp;lt;&amp;lt; Content-type: Text/plain; charset=US-ASCII&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.718: &amp;lt;&amp;lt; Message-ID: &amp;lt;C0D4FE7.4ECD627C.0009@[&quot;192.168.177.176&quot;]&amp;gt;&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.718: &amp;lt;&amp;lt; &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.718: &amp;lt;&amp;lt; the product currently ran agencies going building sites agencies code legitimate &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.718: &amp;lt;&amp;lt; The files vulnerable taking that attacks patches and also there need asked &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.734: &amp;lt;&amp;lt; and hundred attacks ubiquitous north attacks attacks north strings malicious &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.734: &amp;lt;&amp;lt; that to are The helps welcome and injected hundred are vulnerable as across &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.734: &amp;lt;&amp;lt; &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.734: &amp;lt;&amp;lt; in to to longest hundred patches also no institutions vulnerable dedicate &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.734: &amp;lt;&amp;lt; building quick hundred ran welcome in across to security technique institutions &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.734: &amp;lt;&amp;lt; &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.734: &amp;lt;&amp;lt; organizations bugs files also institutions to there haunted are and reside &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.750: &amp;lt;&amp;lt; into other the financial that making patches range comprehensive are need &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.750: &amp;lt;&amp;lt; attacks system for institutions are technique ran agencies making security &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.750: &amp;lt;&amp;lt; currently comprehensive to attacks patches no injected security vulnerable &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.750: &amp;lt;&amp;lt; &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.750: &amp;lt;&amp;lt; by ubiquitous in into which known applets haunted the building ran operated &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.750: &amp;lt;&amp;lt; patches movies organizations movies other welcome bugs building dedicate &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.750: &amp;lt;&amp;lt; Internet dedicate for security product reside The ubiquitous institutions &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.750: &amp;lt;&amp;lt; &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.750: &amp;lt;&amp;lt; currently sites sites vulnerable quick going that taking hundred no product &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.750: &amp;lt;&amp;lt; &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.750: &amp;lt;&amp;lt; are and files scripting are helps code helps need ubiquitous through by &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.750: &amp;lt;&amp;lt; graphics going helps found blocks other asked organizations the are taking &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.765: &amp;lt;&amp;lt; agencies security graphics and financial are dedicate blocks code range &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.765: &amp;lt;&amp;lt; &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.765: &amp;lt;&amp;lt; taking making currently found product need there movies security The sites &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.765: &amp;lt;&amp;lt; haunted range asked the files injected malicious range bugs into across &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.765: &amp;lt;&amp;lt; files attacks product the also bugs to The vulnerable security bugs The &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.765: &amp;lt;&amp;lt; currently which need asked as malicious quick scripting are asked taking &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.765: &amp;lt;&amp;lt; currently to dedicate are taking in also by strings currently also haunted &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.765: &amp;lt;&amp;lt; into asked scripting strings patches financial going that bugs free in &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.765: &amp;lt;&amp;lt; ran agencies injected attacks government code ubiquitous attacks ran bugs &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.765: &amp;lt;&amp;lt; which north they them making found helps product building operated injected &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.765: &amp;lt;&amp;lt; in scripting are agencies and making Internet are sites graphics them graphics &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.781: &amp;lt;&amp;lt; need the helps strings into hundred The to in found applets going institutions &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.781: &amp;lt;&amp;lt; no in going blocks across which as operated animate security system hundred &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.781: &amp;lt;&amp;lt; &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.781: &amp;lt;&amp;lt; them applets Internet also into longest other vulnerable them through Internet &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.781: &amp;lt;&amp;lt; longest by there operated need the need there &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:24.781: &amp;lt;&amp;lt; .&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.875: &amp;gt;&amp;gt; 250 OK A0/50-11301-14586DE4&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.875: &amp;lt;&amp;lt; RSET&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.906: &amp;gt;&amp;gt; 250 RSET OK&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.906: &amp;lt;&amp;lt; MAIL FROM:&amp;lt;yyy@yy.yy&amp;gt;&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.937: &amp;gt;&amp;gt; 250 MAIL FROM accepted&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.937: &amp;lt;&amp;lt; RCPT TO:&amp;lt;xxx@xx.xx&amp;gt;&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.968: &amp;gt;&amp;gt; 250 RCPT TO accepted&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.968: &amp;lt;&amp;lt; DATA&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.000: &amp;gt;&amp;gt; 354 continue. finished with &quot;\r\n.\r\n&quot;&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.000: &amp;lt;&amp;lt; Received: from Spooler by 87.57.133.33 (Mercury/32 v4.73) ID MO00002A;&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 30 Nov 2011 20:34:25 +0100&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.015: &amp;lt;&amp;lt; Received: from spooler by [&quot;192.168.177.176&quot;] (Mercury/32 v4.73); 23 Nov 2011 21:15:40 +0100&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.015: &amp;lt;&amp;lt; From: &quot;E-Mail Administrator&quot; &amp;lt;postmaster@[&quot;192.168.177.176&quot;]&amp;gt;&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.015: &amp;lt;&amp;lt; To: xxx@xx.xx&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.015: &amp;lt;&amp;lt; Subject: test&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.015: &amp;lt;&amp;lt; Date: Wed, 23 Nov 2011 21:15:37 +0100&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.031: &amp;lt;&amp;lt; MIME-Version: 1.0&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.031: &amp;lt;&amp;lt; Content-type: Text/plain; charset=US-ASCII&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.031: &amp;lt;&amp;lt; Message-ID: &amp;lt;C0D5026.4ECD627C.000A@[&quot;192.168.177.176&quot;]&amp;gt;&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.031: &amp;lt;&amp;lt; &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.031: &amp;lt;&amp;lt; found found graphics technique building agencies by vulnerable reside found &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.046: &amp;lt;&amp;lt; ubiquitous asked scripting technique ubiquitous welcome security welcome &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.046: &amp;lt;&amp;lt; &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.046: &amp;lt;&amp;lt; in agencies helps blocks through by which to are system across the are &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.046: &amp;lt;&amp;lt; &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.046: &amp;lt;&amp;lt; and no as ran across in comprehensive ran files quick malicious security &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.046: &amp;lt;&amp;lt; &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.046: &amp;lt;&amp;lt; them reside ubiquitous to vulnerable ubiquitous attacks currently security &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.046: &amp;lt;&amp;lt; &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.046: &amp;lt;&amp;lt; patches operated no to vulnerable legitimate ubiquitous code north range &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.062: &amp;lt;&amp;lt; comprehensive are other applets The system which technique making asked &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.062: &amp;lt;&amp;lt; legitimate security making the product across are files other animate Internet &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.062: &amp;lt;&amp;lt; &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.078: &amp;lt;&amp;lt; files organizations files ubiquitous are graphics and in hundred institutions &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.078: &amp;lt;&amp;lt; &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.078: &amp;lt;&amp;lt; quick into sites patches are reside asked injected agencies hundred need &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.078: &amp;lt;&amp;lt; &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.093: &amp;lt;&amp;lt; north range making found also going building and are ran security graphics &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.093: &amp;lt;&amp;lt; them strings vulnerable and product scripting malicious and comprehensive &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.093: &amp;lt;&amp;lt; injected range reside comprehensive code in The and into currently The &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.093: &amp;lt;&amp;lt; quick as currently taking asked across helps technique across animate agencies &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.093: &amp;lt;&amp;lt; and government which them The by financial building the to injected dedicate &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.093: &amp;lt;&amp;lt; helps patches injected product comprehensive the blocks asked attacks there &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.093: &amp;lt;&amp;lt; &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.093: &amp;lt;&amp;lt; patches product to are comprehensive dedicate going found sites as into &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.093: &amp;lt;&amp;lt; building legitimate no range and blocks the other free through patches &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.093: &amp;lt;&amp;lt; into for graphics The comprehensive scripting haunted other through north &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.093: &amp;lt;&amp;lt; in north in across that need known hundred as blocks they The free helps &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.109: &amp;lt;&amp;lt; security taking in ran range building in the graphics which by the asked &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.109: &amp;lt;&amp;lt; by patches ran building and which going injected animate ubiquitous blocks &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.109: &amp;lt;&amp;lt; also haunted institutions which which welcome helps ubiquitous organizations &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.109: &amp;lt;&amp;lt; making through that legitimate injected operated found by that found making &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.109: &amp;lt;&amp;lt; &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.109: &amp;lt;&amp;lt; animate quick scripting they are no security to blocks found ran hundred &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.109: &amp;lt;&amp;lt; they haunted also animate graphics sites them government dedicate for attacks &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.109: &amp;lt;&amp;lt; asked also and in ran they welcome making animate patches reside attacks &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.109: &amp;lt;&amp;lt; the bugs code haunted dedicate hundred making as organizations quick which &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.109: &amp;lt;&amp;lt; found as as attacks technique also are free scripting comprehensive scripting &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.109: &amp;lt;&amp;lt; .&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.203: &amp;gt;&amp;gt; 250 OK B0/50-11301-24586DE4&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.218: &amp;lt;&amp;lt; RSET&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.250: &amp;gt;&amp;gt; 250 RSET OK&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.250: &amp;lt;&amp;lt; MAIL FROM:&amp;lt;yyy@yy.yy&amp;gt;&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.281: &amp;gt;&amp;gt; 250 MAIL FROM accepted&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.281: &amp;lt;&amp;lt; RCPT TO:&amp;lt;xxx@xx.xx&amp;gt;&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.312: &amp;gt;&amp;gt; 250 RCPT TO accepted&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.328: &amp;lt;&amp;lt; DATA&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.359: &amp;gt;&amp;gt; 354 continue. finished with &quot;\r\n.\r\n&quot;&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.359: &amp;lt;&amp;lt; Received: from Spooler by 87.57.133.33 (Mercury/32 v4.73) ID MO00002E;&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 30 Nov 2011 20:34:25 +0100&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.359: &amp;lt;&amp;lt; Received: from spooler by [&quot;192.168.177.176&quot;] (Mercury/32 v4.73); 23 Nov 2011 21:15:40 +0100&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.359: &amp;lt;&amp;lt; From: &quot;E-Mail Administrator&quot; &amp;lt;postmaster@[&quot;192.168.177.176&quot;]&amp;gt;&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.375: &amp;lt;&amp;lt; To: xxx@xx.xx&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.375: &amp;lt;&amp;lt; Subject: test&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.375: &amp;lt;&amp;lt; Date: Wed, 23 Nov 2011 21:15:37 +0100&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.375: &amp;lt;&amp;lt; MIME-Version: 1.0&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.375: &amp;lt;&amp;lt; Content-type: Text/plain; charset=US-ASCII&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.375: &amp;lt;&amp;lt; Message-ID: &amp;lt;C0D51AC.4ECD627C.000E@[&quot;192.168.177.176&quot;]&amp;gt;&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.375: &amp;lt;&amp;lt; &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.375: &amp;lt;&amp;lt; reside blocks technique there found the asked the range operated known &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.375: &amp;lt;&amp;lt; currently they them patches the bugs helps institutions the security organizations &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.375: &amp;lt;&amp;lt; &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.390: &amp;lt;&amp;lt; haunted helps animate the ran in and hundred movies that animate ubiquitous &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.390: &amp;lt;&amp;lt; institutions building as need no other dedicate and animate strings across &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.390: &amp;lt;&amp;lt; &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.390: &amp;lt;&amp;lt; malicious welcome by currently ran currently helps for for across and asked &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.390: &amp;lt;&amp;lt; known to haunted vulnerable technique institutions product product graphics &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.390: &amp;lt;&amp;lt; &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.390: &amp;lt;&amp;lt; technique patches range to sites no into ran graphics movies for dedicate &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.390: &amp;lt;&amp;lt; in making they injected taking there quick ran institutions them asked &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.390: &amp;lt;&amp;lt; scripting there organizations legitimate there government which vulnerable &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.390: &amp;lt;&amp;lt; &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.406: &amp;lt;&amp;lt; security the ran no comprehensive across organizations free by bugs reside &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.406: &amp;lt;&amp;lt; government patches making institutions also graphics animate by comprehensive &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.406: &amp;lt;&amp;lt; currently government and free taking the injected quick haunted code graphics &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.406: &amp;lt;&amp;lt; product north haunted product ran currently vulnerable haunted animate &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.406: &amp;lt;&amp;lt; &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.406: &amp;lt;&amp;lt; across scripting by scripting comprehensive vulnerable blocks that ran &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.406: &amp;lt;&amp;lt; haunted asked range animate scripting applets are and security patches &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.406: &amp;lt;&amp;lt; found free north found quick for legitimate blocks also asked which comprehensive &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.406: &amp;lt;&amp;lt; &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.421: &amp;lt;&amp;lt; the code haunted ran The range the into applets need organizations through &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.421: &amp;lt;&amp;lt; making legitimate quick The and ran making technique security to making &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.421: &amp;lt;&amp;lt; &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.421: &amp;lt;&amp;lt; quick taking blocks currently which need helps across injected them and &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.421: &amp;lt;&amp;lt; they system Internet product sites in making building malicious legitimate &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.421: &amp;lt;&amp;lt; &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.421: &amp;lt;&amp;lt; are &amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.421: &amp;lt;&amp;lt; .&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.500: &amp;gt;&amp;gt; 250 OK D0/50-11301-24586DE4&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.515: &amp;lt;&amp;lt; RSET&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.546: &amp;gt;&amp;gt; 250 RSET OK&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.546: &amp;lt;&amp;lt; MAIL FROM:&amp;lt;yyy@yy.yy&amp;gt;&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.578: &amp;gt;&amp;gt; 421 4.5.1 No more messages on this connection, se venligst http://postmaster.tdc.dk/publish.php?id=23413&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.593: &amp;lt;&amp;lt; RSET&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.609: &amp;lt;&amp;lt; QUIT&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 20:34:25.609: --- Connection closed normally at Wed Nov 30 20:34:25 2011. --- 20:34:25.609: &lt;/p&gt;&lt;p&gt; &lt;/p&gt;&lt;p&gt; &lt;/p&gt;
The session logs shows error messages from TDC referring to this link:
The linked page says:
ASMTP: Domænet findes ikke
Fejl:
Domænet (delen efter snabel-a) i mailadressen findes ikke.
Løsning:
Kontroller mailadressen for stavefejl og prøv igen.
which translated from Danish means that the domain in the mail address doesn't exist. This is true as "Admin@87.57.133.33" actually isn't a valid email address. To use a numerical IP address as domain it has to be in brackets like this: Admin@[87.57.133.33]
Please note that I've edited your post to remove the login details.
&lt;p&gt;The session logs shows error messages from TDC referring to this link:&lt;/p&gt;&lt;p&gt;&lt;a href=&quot;http://postmaster.tdc.dk/publish.php?id=23421&quot; mce_href=&quot;http://postmaster.tdc.dk/publish.php?id=23421&quot;&gt;http://postmaster.tdc.dk/publish.php?id=23421&lt;/a&gt;&lt;/p&gt;&lt;p&gt;The linked page says:&lt;/p&gt;&lt;blockquote&gt;&lt;p&gt;&lt;i&gt;ASMTP: Dom&aelig;net findes ikke&lt;/i&gt;&lt;/p&gt;&lt;p style=&quot;line-height: 17px; width: 447px; padding-top: 0px; padding-right: 0px; padding-bottom: 0px; padding-left: 0px; margin-top: 0px; margin-right: 0px; margin-bottom: 12px; margin-left: 0px; font-size: 12px; font-family: verdana, arial, sans-serif; text-align: left; &quot;&gt;&lt;i&gt;&lt;b&gt;Fejl: &lt;/b&gt;Dom&aelig;net (delen efter snabel-a) i mailadressen findes ikke.&lt;/i&gt;&lt;/p&gt;&lt;p style=&quot;line-height: 17px; width: 447px; padding-top: 0px; padding-right: 0px; padding-bottom: 0px; padding-left: 0px; margin-top: 0px; margin-right: 0px; margin-bottom: 12px; margin-left: 0px; font-size: 12px; font-family: verdana, arial, sans-serif; text-align: left; &quot;&gt;&lt;i&gt;&lt;b&gt;L&oslash;sning: &lt;/b&gt;Kontroller mailadressen for stavefejl og pr&oslash;v igen.&lt;/i&gt;&lt;/p&gt;&lt;/blockquote&gt;&lt;p style=&quot;line-height: 17px; width: 447px; padding: 0px; margin: 0px 0px 12px; font-size: 12px; font-family: verdana,arial,sans-serif; text-align: left;&quot;&gt;which translated from Danish means that the domain in the mail address doesn&#039;t exist. This is true as &quot;&lt;span class=&quot;Apple-style-span&quot; style=&quot;line-height: normal; font-family: Tahoma,Arial,Helvetica;&quot;&gt;Admin@87.57.133.33&quot;&lt;/span&gt;&lt;span class=&quot;Apple-style-span&quot; style=&quot;font-family: Arial,Helvetica,sans-serif; font-size: 13px; line-height: normal;&quot;&gt;&amp;nbsp;actually isn&#039;t a valid email address. To use a numerical IP address as domain it has to be in brackets like this:&amp;nbsp;&lt;/span&gt;&lt;span class=&quot;Apple-style-span&quot; style=&quot;font-family: Tahoma,Arial,Helvetica; line-height: normal;&quot;&gt;Admin@[87.57.133.33]&lt;/span&gt;&lt;/p&gt;&lt;p style=&quot;line-height: 17px; width: 447px; padding: 0px; margin: 0px 0px 12px; font-size: 12px; font-family: verdana,arial,sans-serif; text-align: left;&quot;&gt;Please note that I&#039;ve edited your post to remove the login details. &lt;/p&gt;&lt;p style=&quot;line-height: 17px; width: 447px; padding-top: 0px; padding-right: 0px; padding-bottom: 0px; padding-left: 0px; margin-top: 0px; margin-right: 0px; margin-bottom: 12px; margin-left: 0px; font-size: 12px; font-family: verdana, arial, sans-serif; text-align: left; &quot;&gt;/Rolf&amp;nbsp;&lt;/p&gt;&lt;p style=&quot;line-height: 17px; width: 447px; padding-top: 0px; padding-right: 0px; padding-bottom: 0px; padding-left: 0px; margin-top: 0px; margin-right: 0px; margin-bottom: 12px; margin-left: 0px; font-size: 12px; font-family: verdana, arial, sans-serif; text-align: left; &quot;&gt;&amp;nbsp;&lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;
