For a variety of reasons, Mercury is quite strict about enforcing the syntax of the MAIL FROM: and RCTP TO: SMTP commands. The main reason is that syntax errors in these commands are a common indicator of spam (no properly-written SMTP client should ever be getting the protocol this badly wrong). The secondary reason is that a number of open relay testers use deviant or invalid forms like this as part of their test, and evaluate the server based on how it handles them.
As Thomas has pointed out, the syntax for these commands in RFC2821 is quite specific - you can't just throw any address format in there. If your mail clients are getting this so badly wrong, you need to get back to their authors and suggest that they re-read RFC2821, then correct their code.
-- David --
-- David --
