Maybe I found where is the problem.
Here is the QCF/QDF of a test message in the queue folder of the first instance:
[quote]
ST: R 000000000000 00 000001 000000 000000
FR: <pinco.palla@pec.it>
DF: MG000022.QDF
FL: 65536
OS: 120112111502
BA: <myhouse@blabla.it>
ES: R 120112111502
RI: 000.000.000.000 000.000.000.000 000.000.000.000 000.000.000.000
DI: --------.---
EA:
Return-path: <pinco.palla@pec.it>
Received: from ugenerico2 (192.168.1.8) by palla09.local (Mercury/32 v4.72) with ESMTP ID MG000022;
12 Jan 2012 11:15:02 +0100
To: <myhouse@blabla.it>
Subject: prova 12genn h.11.14
Date: Thu, 12 Jan 2012 11:15:02 +0100
Message-ID: <00f201ccd113$0c3d9cd0$24b8d670$@palla@pec.it>
MIME-Version: 1.0
Content-Type: multipart/alternative;
boundary="----=_NextPart_000_00F3_01CCD11B.6E0204D0"
X-Mailer: Microsoft Office Outlook 12.0
Thread-Index: AczREwwXeQjdos+cQ1+Jps9WknKHzw==
Content-Language: it
...cut......cut......cut...
As already seen, this message is moved by an outgoing rule to the
PEC-out mailbox, and sits there waiting to be picked up by Wsmtpex; the
following is the Header of the message found in the CNM file in the
PEC-out folder
[quote]
Received: from spooler by palla09.local (Mercury/32 v4.72); 12 Jan 2012 11:17:50 +0100
MIME-Version: 1.0
We can see that the "Return-path: <pinco.palla@pec.it>" line disappeared.
Now, as stated in the wsmtpex.txt file
[quote]
WSMTPEx looks into .CNM file and search for header 'Return-Path' for
SMTP envelope MAIL FROM address. Uses "<>" if none is found.
So, I was thinking that this may lead to the QCF with the empty "FR: <>" field in the queue of the second instance (and to the subsequet problems).
May this be so?
I'm wondering what to do... Any idea?
Best regards
Filippo
<p>Maybe I found where is the problem.
[quote]
FR: &lt;pinco.palla@pec.it&gt;
DF: MG000022.QDF
FL: 65536&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;
OS: 120112111502
BA: &lt;myhouse@blabla.it&gt;
ES: R 120112111502
DI: --------.---
EA:
Return-path: &lt;pinco.palla@pec.it&gt;
&nbsp;&nbsp; 12 Jan 2012 11:15:02 +0100
To: &lt;myhouse@blabla.it&gt;
Message-ID: &lt;00f201ccd113$0c3d9cd0$24b8d670$@palla@pec.it&gt;
MIME-Version: 1.0
&nbsp;&nbsp; &nbsp;boundary="----=_NextPart_000_00F3_01CCD11B.6E0204D0"
PEC-out folder
[quote]
MIME-Version: 1.0
We can see that the "Return-path: &lt;pinco.palla@pec.it&gt;" line disappeared.</p><p>&nbsp;</p><p>Now, as stated in the wsmtpex.txt file
[quote]
SMTP envelope MAIL FROM address. Uses "&lt;&gt;" if none is found.
So, I was thinking that this may lead to the QCF with the empty "FR: &lt;&gt;" field in the queue of the second instance (and to the subsequet problems).</p><p>May this be so?</p><p>I'm wondering what to do... Any idea?
</p><p>
Best regards
Filippo</p>
